Right clicking on the windows desktop will allow you to bring up the properties, and then the display settings. Here is where you can change from 640x480 to a higher res. If higher than that is not available, it means you are running a generic video driver and not the video drivers intended for your laptop model. In this case, reload your video drivers for full functionality.
I hope that helps.
Open Screen Resolution by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering Display in the search box, tapping or clicking Settings, and then tapping or clicking Display.
Tap or click Adjust resolution.
Tap or click the Resolution list and find the resolution marked (Recommended). This is your monitor's native resolution-usually the highest resolution your monitor can support.
Monitors can support resolutions that are lower than their native resolutions, but text won't look as sharp and the display might be small, centered on the screen, edged with black, or stretched.
Open Screen Resolution by clicking the Start button , clicking Control Panel, and then, under Appearance and Personalization, clicking Adjust screen resolution.
Click the drop-down list next to Resolution, move the slider to the resolution you want, and then click Apply.
Click Keep to use the new resolution, or click Revert to go back to the previous resolution.
Screen resolution refers to the clarity of the text and images on your
screen. At higher resolutions, items appear sharper. They also appear
smaller, so more items fit on the screen. At lower resolutions, fewer
items fit on the screen, but they are larger and easier to see. At very
low resolutions, however, images might have jagged edges.
For example, 640 × 480 is a lower screen resolution,
and 1600 × 1200 is a higher one. CRT monitors generally display a
resolution of 800 × 600 or 1024 × 768. LCD monitors can better support
the higher resolutions.
Whether you can increase your screen resolution depends on the size and
capability of your monitor and the type of video card you have.
Text and images are sharper and smaller at high screen resolutions
Text is larger and easier to read at low screen resolutions, but images are blocky and fewer items fit on the screen
Open Display Settings by clicking the Start button , clicking Control Panel, clicking Appearance and Personalization, clicking Personalization, and then clicking Display Settings.
Under Resolution, move the slider to the resolution you want, and then click Apply.
