Question about Compaq ARMADA M300 11.3" Flat Panel LCD Monitor
Compaq Armada M300 Loose Display Screen
How do I tighten up the supports on my Compaq Armada M300 display screen? The screen feels loose/slack when going from a closed position to an open position and vice versa.
  • Anonymous Oct 23, 2008
    My lapton screen will no longer stay in an upright position. I would like to find some sort of brace or clip or leg that might solve this problem without having to take apart my monitor.
  • tkrantz May 04, 2009
    I also have a loose screen on a compaq amada m700, where can i get neww hinges?
    Genius:
  • 1,027 Answers
There is no adjustment on the m300 v300 m700 v700. These hinges will have to be replaced. I do have a set from an v300 am not sure if they are compatible but you can have them if you want.
Posted on Mar 18, 2008
Tighten hinge on presario 700
There are no adjustment available to tighten the hinges on a laptop. They need to be replaced.
These WEB site will assist you in replacing hinges.
Replacing a hinge, or both of them, isn't very tough.
http://www.insidemylaptop.com/replace-br...Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/b>Laptop repair infohttp://www.laptoprepair101.com/
Mar 28, 2012 | Compaq Presario 700 470024-192 Notebook
I have a dell inspiron 6000 laptop..the bottom third of the display has lines in it and i cannot see the mouse..but if i hold the corner towards me it clears up, but as soon as i let go i happens again
the screen may be loose or broken. If loose, you'll need to tighten up the screws that hold the screen and the cover together. If the screen is broken, you'll need to replace it.
Mar 19, 2010 | Compaq Presario M2000 Notebook
My compaq armada m300 wont recognise new hardrive
just try with fixing the hard drive connection properly and in bios also check how much capacity motherboard can support .according to your specification it will not support the higher capacity hard disk .make sure you installing the new hardidsk as same capacity of your older hard drive.
Nov 25, 2009 | Compaq Armada M300 Notebook
Red line top to bottom in center of display ?
you lcd screen went bad-only way to fix it is to get a new lcd
Oct 22, 2009 | Compaq Armada M700 Notebook
"Rolling Screen/Static"
take the display apart and check the ribbon connectors to display unit sometimes your are lucky and find a loose plug connector
Aug 26, 2009 | Compaq Computers & Internet
The screen on my compaq armada is blank. i can
The display panel itself is probably fine, but its backlight isn't working. Without the backlight you can't see the display. There's a small circuit board called the inverter inside the display that provides power for the backlight.
It's pretty easy to replace the inverter. You need to take out whatever screws are holding the front half of the display to the back and remove the front. The inverter is at the bottom of the display, held in by a couple of screws. A couple of cables plug into it.
Here is a place that claims they have the inverter in stock for $7.39. That is one fantastic price! Get one of those and a set of miniature Phillips screwdrivers and you'll be able to fix this yourself.
Apr 18, 2009 | Compaq Armada 7800 PC Notebook
Compaq armada e5oo laptop...right side of screen looses brightnes
It sounds like the inverter on your LCD screen is going bad on you.  You can sometimes find inverters for cheap on eBay, but you will need to get the part number from Compaq to be sure that you are buying the correct thing, and I usually say not to buy any that ship from Asia even though they may be cheaper, as many times they are knock offs.
Mar 30, 2009 | Compaq Armada E500 Notebook
Armada m3000 screen
you can mess around and try to fix it but on those old machines its really not worth it(I own 5 of these).Might I suggest the Armada M700 or the E500--e500 is what im on now and it runs better than a brand new dell or compaq)you might get a new screen on ebay for about 40 bucks. It might be a better idea to buy a new one and save the parts from your old one. You can get a new one for 70 bucks on ebay.
http://cgi.ebay.com/COMPAQ-ARMADA-M300-Intel-Pentium-3-LAPTOP_W0QQitemZ200297181300QQcmdZViewItemQQptZLH_DefaultDomain_0?_trksid=p3286.m20.l1116
Jul 24, 2008 | Compaq ARMADA M300 11.3" Flat Panel LCD...
Compaq Armada M700, Dim Screen
There is a dimmer function that is part of the keyboard on most notebooks. You use the Fn key and some other key (Mine is F1 and F1) Look for what looks like Sun in blue print on the key. You should find 2 of them. One will be the brightness up and the other brightness down. You can try those.
More likely, something has come loose internally.
1. It could be the backlight for the screen is broken or a connection loose. You should be able to see the light when you look at the side of the display.
2. The AC power connector may have been broken and the notebook is only on battery power. By default most systems are dimmer when on battery power. Check to see if your charge indicator light is on. If not, that may be the problem.
I hope this helps.
May 07, 2008 | Compaq Armada M700 Notebook
Armada E500 display/ screen flicker :(
Sounds like A. The LCD Lamp is going bad, or B. The screen cable is loose. If you want, you contact me directly at itolovell (at) cox.net, and ill help you diagonose, and solve the problem
Aug 17, 2006 | Compaq Armada E500 Notebook
Compaq ARMADA M300 11.3" Flat Panel LCD Monitor Logo
686 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
