Question about HP 49g+ Calculator
Back small orifice where??
How to reset can't find small orifice
Next to the serial number, above the last line (the one with some symbols) in the written area, on the calculator's back.
Posted on Apr 03, 2008
SOURCE:
My dryer will not heat up
What kind of dryer is it? gas/electric? On some electric dryers you can find a reset button, small red or white, common location is close to the element, may be a small removable panel on the back but most you access from underneath, or the element could be burned and creating a open. Gas, it could be a bad ignition switch or clogged orifices. Check those that apply first.
Sep 11, 2016 | Dryers
Where do I find the orface and air intake on the GE Range
Sealed burner ranges the orifice is in the center of each burner, down inside(brass color). Open style burners the orifice should be under the lift off burner or in some case where the burner tube goes back to the control panel at the control knob. Almost all will be brass color. Oven orifices are at the end of the burner tube where the gas would come into the burner. Air adjustments are usually right near the orifices. A small sliding window with 1 screw holding the adjustment in place.
Mar 23, 2015 | GE 30" Self-Cleaning Freestanding Gas...
How do you change the speedometer on a Horizon T103 treadmill from Miles to KMs
you must go under the display board, or monitor, see the small orifice, and put the point of erase pencil in the small orifice and touch the small switch, and ready.
God bless you
Nov 25, 2012 | Horizon Fitness Horizon T103 14 Program...
Hozelock telescopic watering lance 2644 mist spray blockage
Try soaking in white vinegar or any anti-water scale product. Misting requires a very small orifice and clogging is common. If you can back wash compressed air thru the holes, try that. A guitar string might be run thru the orifice and then back-flushed.
Oct 18, 2012 | Garden
Covert from klg to Mph ?
under the display board cover, with small pencil point there are small orifice , click the microswitch, and change to MPH, and fix it.
God bless you
Jul 18, 2012 | Exercise & Fitness
What the best way to get the orifice tube in my 2003 ford windstar.
ORIFICE TUBE IS IN SMALL REFRIGERANT LINE GOING INTO FIREWALL YOU WILL SEE LARGER REFRIGERANT LINE ABOVE SMALL REFRIGERANT LINE.USE NEEDLE NOSE PLIERS TO REMOVE ORIFICE TUBE.
Jun 26, 2011 | Ford Windstar Cars & Trucks
My 30000 btu pro com blue flam has about 35% orange flams
You probably have a plugged orifice. The gas is injected into the burner via a small orifice and, when this plugs, the air / fuel mix is altered, causing the orange flame. Find your owners manual to find out how to replace the orifice or you could take it to a small engine repair facility locally who should be able to fix your problem.
Hope this helps!
Nov 05, 2010 | Procom ML300TBA Heater
Only 1 half of the element works with both valves on. We bought this bbq off of craigslist. it had never been used. Rock were still in the bag and the grilles have never been used.
By "element" you mean the burner? each valve will control one side of the burner but if unused for so long it is Very likely the orifices and valve (small cavity behind orifice when installed) are plugged. Although not common in general this is fairly common in barbecues unused for long. small insects can crawl inside the orifice hole to live in the valve and sometimes packing grease gets hard in the tiny orifice opening.
Aug 23, 2010 | Sunbeam Grill Series 550
Where do I find the AC Orifice tube
The orifice tube will be on the small line joining the evaporator,the ac line will be swelled where the orifice tube is at,you may not can see it,but use needle nose pliers to remove it,and to install it.
Jun 28, 2010 | 1997 Mercury Cougar XR7
Heater will not stay light
I had this same problem and the only thing that I found was a small spider web in the pilot air intake which had traped a small piece of lint I blew this out and the heater worked great
Jan 10, 2009 | Procom QL300TYLA Heater
HP 49g+ Calculator Logo
48 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
