Maytag washer just died on me
Maytag washer model no mav5057aww stopped working after an unbalanced load it's not the outlet or fuse box or belt, checked the switch assembly by only looking at it not with a meter yet until i get one, but none of the assembly is broken i keep reading about a reset button where is it and i always read it's supposed to reset after putting lid up which it hasn't plz help me with finding it or another solution the washer does nothing at all btw thanks in advance
  • 2 more comments
  • jamiejame Mar 18, 2008
    yea i made sure last night that the plunger was hitting the switch and it is, i have the wiring diagram that says there is a fuse but from where i checked i didn't see one unless it's on the back but i'm gonna check again i can't seem to get the front of the washer off it says two screws on the bottom which there isn't, thanks for ur help
    well i guess if there's no reset on the motor like people say then i don't need to open the front huh?lol
    nope don't see a fuse anywhere so it must be the switch is bad right?
    ok i replaced the switch lid and it works thanks a bunch
    President:
  • Washing Mach... Master
  • 2,651 Answers
The reset button is usually built into a switch that resets automatically when the lid is opened and tub recentered, you rmodel doesnt show one, but there is a mention of a 10 amp fuse( if so equipped) on the wire diagram. shows it connected right to the L1 wire(line 1) trace the linecord in and see if it gets you to a fuse. possible a bad lid switch and/ or plunger for the switch, not making contact when door is closed
Posted on Mar 18, 2008
SOURCE:
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Maytag washer drum belt worn out....does that damage other parts?
First thing I would do is replace the belt as the old one may have streched
Apr 01, 2017 | Maytag PAV2300 Top Load Washer
Unbalanced load stopped machine will not restart why?
On some of the maytag washers when an unbalanced load stops the maching it blows an internal fuse located behind the front panel on some stacking washer and dryer machines and under the counsel on some of the top load machines. ON the top load machines it is recomended that you change the lid switch with the fuse that comes with it.
There are two screws located on each side of the counsel. Remove the two screws and tilt the counsel up and locate the lid switch, fuse assembly. You can check the fuse at this point.
Dec 28, 2009 | Maytag Washing Machines
When on spin cycle, Maytag MAV5057AWW vibrates excessively more so than just an unbalanced load. When I open the lid the whole tub and agitator is moving around alot forward and back as well as side to...
make sure you loads are balanced, put heaviest clothes in first... if you can rock it by hand then the legs are not adjusted properly. If you stand 2 feet away from front of machine, jump up and down and see it move the floor is soft and you need 2 sheets of plywood to make 1 1/2 inches put under the machine
Aug 16, 2009 | Maytag MMV4205 Microwave Oven
Front load washer not spinning correctly
I had the same problem, once I remove the shipping bolts on the back of the machine it worked fine.
Feb 01, 2009 | Maytag Neptune MAH9700 Front Load Washer
Maytag Washer not working...
bushes on electric motor worn need new ones this will cut supply to washer
Jan 11, 2009 | Washing Machines
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Atlantis Washer
This sounds like a foreign object in machine, possible bra wire. Regards Advisor
Aug 22, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Maytag washer will not spin
If your washer does everything but does not spin, it is your outlet filter which is blocked. Locate this and clean out, it has to work fine. Refer user's manual.
Jun 02, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Washing Machines Logo
1,286 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
