Question about Frigidaire FEF366DC Electric Kitchen Range
Kenmore fault code
Every time i preheat the oven the cod F-10 comes out. what can i do.
  • 1 more comment
  • Robin42057 Apr 24, 2008
    I have a frigidaire FEF366DC that gives me fault code 10 almost every time I try to use the oven. Help please
  • mrfrank Jun 17, 2008
    Sir, Same problem F-10 code on a Frigadaire electric stove top. This only happens when I use the oven. Drives me crazy. Could it be the oven sensor, is this the RTD Sensor?
  • tandra_eros Jan 05, 2009
    I have the same problem the unit is not even two years old, can I go to a hardware store or appliance store and get the part/piece, I am clueless on what to do.
    President:
  • 1,314 Answers
You need to check or replace the oven temp probe its the gold looking rod that sticks out in the oven check the connectors under the back panel and plug and unplug it from the control board in case there is any Resistance on back of the range you should find a tech sheet will give you more specifics and if you have an ohm meter do the rtd test on the sheet
Posted on Mar 18, 2008
SOURCE:
Orange glow after oven burners were lit, thenflames in oven
Sounds like maybe some grease or something had been spilld and then caught on fire while you preheated the oven
Jan 07, 2018 | Kitchen Ranges
Is preheating this toaster oven necessary? How do you preheat?
Preheat is helpful when you're not cooking for more than a few minutes. If you're going to cook for 20 minutes or more, then most likely you don't need to pre-heat.
To pre-heat, simply turn your toaster-oven on 10 minutes before you put the food in.
Feb 27, 2016 | Toaster Ovens
Oven kicks on gas lights runs for 10 sec then beeps showing preheat is done then kicks off
I had to replace my igniter to get mine to work. I did it myself for $65.00 Mine the gas just would not stay on to heat up.
Mar 13, 2015 | Maytag Ovens
My oven bakes, but it takes 30 minutes to preheat
Hi friend, thank you for your post!
I know from your post that your Frigidaire oven is working but the preheat takes 30 minutes. This does sound like lengthy amount of time for preheat to be completed. From what you are describing it could be an issue with the panel, element, or thermostat. Since it could be anyone of these underlying issues I would recommend having a professional come out to diagnose your refrigerator to determine the root cause to reduce the risk of unnecessary parts. -Matt
Aug 06, 2014 | Frigidaire 30 in. Electric Gallery Series...
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
My oven, model 38HN-6TVW won't preheat
I was unable to get the full model to come up. I was able to get a Magic chef range to come up. I would replace the control and oven thermostat.
Aug 14, 2009 | Magic Chef 9815 Electric Single Oven
Whirlpool accubake doesn't preheat properly
Are both of your heating elements lighting up when you are preheating? It sounds like the oven thinks it is pumping power into both elements and one isn't working. Oven elements are generally easy to remove and replace!
Jan 08, 2018 | Whirlpool Kitchen Ranges
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Frigidaire FEF366DC Electric Kitchen Range Logo
389 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
