Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
S catch i have taken the top part of handle off, removed the screws under hose wrap, and layed the bottom part of handle down, i cannot find the s catch, can you tell me exactly where it is and what it looks like. i have looked all over this thing. thanks randy the model # is 8905
    President:
  • 1,673 Answers
Just pull where I marked, it should come loose.
Posted on Mar 18, 2008
How do I remove the hose from the handle on a Lux Legacy?
You first have to knock out the plastic "plug" under the bottom of the handle and also pop off 2-3 small screw covers, about the size of a pencil eraser, on the top of the handle. Now remove the screws with the proper jewelers screwdriver or star driver and gently pull the handle apart (top and bottom). Be careful to pay attention to where the wires lay inside the handle then remove the handle from the hose. Voila! There's your answer....Hope that helps!
Oct 11, 2014 | Electrolux Vacuums
How can I separatte the ****** handle of my Epic 6500 fromthe hose? I have a wrapped pair of socks stuck in it at the handle
There are two different styles of hose for the 6500 vacuums. Please be careful when you take the handles off and also when putting it back togeather. To remove the handle there are two screw caps that you need to remove to get to the screws. You can do this with the tip of a knife or something similar inserted under the edge of the screw cap and pry up. The screws can either be a Phillips head or a torx bit. Remove the screws and then separate the top part of the handle from the bottom. Make sure to notice the position of the wires and do not unplug them from the switch or the contact block.The contact block at the hose end of the handle has two contacts that transfer the power from the hose to the handle and will bend out of shape if you are not careful. To remove the contact block, use a flat head screw driver under the block and pry up. On the older models, the handle will slip right off. If you have a newer model, there is a handle retainer at the base of the handle and will push out with a screw driver. It only goes one way and
the handle will slip off.
To replace the handle just reverse the procedure. Good luck.
Aug 28, 2014 | Electrolux Epic 6500 Vacuum
How to get to wiring plug
If you're talking about the cord that you pull out from the reel located at the rear of the machine, you'll have to take the top cover off first. Usually two philips head screws located under rear exhaust cover and one maybe two near the front end. Once that is removed, there will be two more philips screws, one on each side of the top rear of the machine and one on the bottom. Remove all three of them, pull about a foot of cord off of the reel and get it to catch, the using the heel of your right hand, hit the very back of the machine, (the rubber bumper part) on the top with a motion pulling toward the back. This may take a couple of tries if you're not used to removing this part, but one or two swipes should eventually loosen the rear cover. Once it is loosened you may carefully pull it out of the back end of the machine and take off the two wire connections. This will free up the cordwinder assy. so you can take it to a spot where you have some room to work. Now lay the assembly on it's back and take the four screws, one from each corner of the rear cover, out and lay them aside. Thread the cord plug through the opening and wind the free cord back onto the reel, allowing the spring to pull it slowly out of your hand and then wrap the plug end around and around the reel till the spring is unwound, then you can remove the "C" clip from the center post, sometimes hidden under a cardboard washer. With the clip removed you can gently pull the cord reel up and off the post, carefully bringing the rewind spring up and off it's post as well. If you've tested the cord and are sure that it's your problem then you can cut the remainder of the cord from the reel and throw it away. The reel is easier to deal with without the cord on it. Turn the reel over so the back cover is exposed, there should be three screws that can be removed so you can take the connections loose from the posts inside and make ready for the new cord. Once you've attached the new cord and tied your strain relief knot, like the one you removed, you're ready to wrap the cord onto the reel and just reverse the procedure. When you get ready to put the loaded reel back into the cordwinder body, just before you put the cover on, wrap the plug end around the reel three times. This loads the spring so that it will pull the cord completely back into the unit. And it doesn't hurt to drop a spot of oil onto the top of the post for the spring.
Nov 11, 2013 | Electrolux C101 Bagged Canister Vacuum
No electrical continuity on one lead in hose. Cause is probably in the wiper assy. How do I disassemble hose ends to check electrical connections without breaking or cutting into plastic parts?
We have here the user manual. The page 8-9 you will see the instruction for replace the power nozzle which shows how to desmandle the vacuum and you will find the power cord connetion point. A big advice use your camera to take picture every step you make and especialy before remove the wires since in any case you will forget anything when you will try to assemble it back they will bevery helpfull.
Aug 06, 2011 | Hoover S3670 Bagged Canister Vacuum
Clog somewhere how do i get inside to empty
There is a single screw that holds the handle and bag housing in place. Lay the handle down and you should be able to see the screw on the motor outlet. Remove the screw ( or nut and bolt on some models ) and wiggle the handle upward to remove it and check for blockage. If you set the upper assembly down, be careful not to break the plastic switch rod which protrudes from the bottom.
Feb 21, 2011 | Hoover Breathe Easy U5250-930 Bagged...
Dyson DC07 Filter Release Catch removal
yes sorry i know what mean you need to remove the motor casing to reduce the risk of breaking any parts. Lay dyson on the front and remove the bottom plate and roller bar. Now you need to remove the belt from the motor pin lay on left side look t the round clip located next to the wheel which is holding the whole floor atachment to the chasse. Remove the clip with a flat ended screwdriver then flip to opposite side and repeat the same. The floor atachment should be moved to the down position as far as possible. now you can remove the the bottom attechment starting from the opposite side to the belt now undo the four screws on the bottom of the chassis and remove the screws under the other filter on top of the moter now remove the top cover now the piece in the way should move out.
Nov 11, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
BISSELPRO HEAT CARPET CLEANER
With the top part of the handle off, lay the handle back and at the top in the middle, there is a catch, just push it in to release it and the front of the handle will come off.
Jul 21, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell Proheat Clearview 1669
Take out the 2 long screws with the nuts on them, then furher down just beneath the hose wrap asm, there are 2 more screws to remove. Put the top part of the handle off, lay the handle down, on the front, at the top and in the center is a tab, push it in and pull the top half of the handle away from the bottom half. Then you will see the heater, don't mix up the hoses after you are done.
Jun 23, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Take off the 2 long screws and remove the top part of the handle. Then from the back, just undr the hose and cord wrap asm, there are 2 screws set deep in the holes to remove. Don't remove the cord and hose wrap. Then lay the handle back, at the top, in the center, there is a catch to push in, then the top half will come off and you can get to the heater. Remove the hoses, one of the hose ports maybe clogged, clean them out, sometimes stuff in them gets pretty hard and hard to clean out.
After you may want to run a mix of vinegar and water thru the system to clean it all out.(not on your carpet tho)
Jun 04, 2008 | Bissell 1699 ProHeat Clear View Upright...
Splitting the case
The heater is in the handle. Take out the 2 long screws and nuts, remove the handle. Then on the back, below the cord and hose warp, there are 2 more screws, then lay the handle down, you will see s catch. push it in and the handle pieces will come apart. Pull the 2 lines off of the heater,( remember which ones goes where)Use a nail or something small that you can push in the ports that the lines were hooked to and clean them out, try to blow thru to see if if is cleared out. Then re-asemble.
Mar 18, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
