No sound output
I have an AVR-688 and I can't get any inputs (dvd,tv,radio) to come out of the speakers. I did the mic set up and the speakers work. I have opt 1 connected to my dvd player, opt 2 connected to my tv, and component video cables from my dvd to my tv.
I went to "2.In" in the set up and set opt 1 dvd, opt 2 tv. Still nothing. What am I missing here?
  • 97 Answers
Sounds like you sorta know what your doing but the most obvious answer is the source and output (selection) dont match. Double check your mute button and all the obvious things first, make sure your connections are to Zone1 inputs as well. None of those are it? Do you get sound from the Radio? Try unhooking all inputs (video also) and hooking up just one at a time till you get it right.
Posted on Mar 18, 2008
Can't get balance, bass and treble to work when connecting Bose Acoustimass 5II to HK AVR 525
On my yamaha 375 receiver if I connect digital or hdmi it disables the balance/bass treble etc but they work with anolog don't know if yours might be the same just abit strang if anolog doing it aswell
Jan 15, 2014 | Harmon Kardon Harman Kardon Avr 525 7.1...
Hi. We have a Harman Kardon DVD and AVR and a Proline TV. When playing DVDs the sound from the AVR is not playing all tracks (usually the voice track is missing) - just background music and the odd door...
Your HK DVD probably has outputs for left and right audio and video (possibly color coded red, white, and yellow). These should connect to the corresponding DVD (or VCR) inputs on the rear of your AVR. When you play a DVD with your AVR set for DVD/VCR input, you should hear all of the stereo audio (there are no "missing tracks"). Next, review your speaker connections. They should be connected + terminal to the corresponding + terminal on the AVR, etc. One or more speakers may be connected backwards. If your AVR has speaker system A B provisions, be sure that speaker (system) A only has been selected.
Dec 23, 2013 | Harman Kardon AVR 225 Receiver
Denon avr-587
Make sure that the volume is not muted or too low on the TV...the TV volume output to your receiver will be performing the function of a pre-amp to your receiver. Then select the appropriate input on the receiver that you have the TV audio connected to.
Jul 17, 2010 | Denon AVR-587
No speaker output from television input. Other inputs (DVD, CD) work fine.
Check to make sure you have the TV input connections in the correct
slots. Sometimes there are two possible inputs for a TV. One being a monitor 1 and the other a monitor 2. There could also be speaker select buttons on the receiver that correspond to each.
Also check the TV audio settings to make sure the output connections are sending an audio signal, also known as external speakers.
Jul 29, 2009 | Denon AVR-1082 Receiver
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
I have the denon avr-688 - when i use the mic to auto setup, i have sound from each of my speakers, but when trying to watch tv or a blu ray movie there's no sound at all
Check your blu-ray connection. Is the HDMI cable going from the player to the receiver, then another HDMI cable going from the receiver to the television? What about your TV input? Is there a cable going from the cable converter box to the receiver's input?
Dec 29, 2008 | Denon AVR688
No HDMI video output from AVR-588 receiver to plasma TV ???
the avr-588 apparently cannot carry sound via hdmi - don't know why; just what i found out from the geek squad at best buy; solved the problem by connecting optical cable from cable box to receiver; be sure to change the input on the receiver for opt-2 (system setup >2 inputs) to correlate with tv
Feb 16, 2008 | Denon AVR588 Receiver
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
138 people viewed this question
 Grubhead
Grubhead
