Question about Samsung PCL545R 54" Rear Projection Television
White dots appearing on tv screen
Have a samsung projecter tv seems to have white dots on the screen
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
Will need model number, but sounds like digi board problem
Craig www.classtorations.com
Posted on Jun 10, 2008
SOURCE:
White dots on screen
http://www.metacafe.com/watch/yt-XeIOwN1CIp8/samsung_mitsubishi_toshiba_dlp_hd_tv_repair_tips_black_white_dots_on_tv_problems_bad_dlp_chip/
I believe it is the digital projection chip that is beginning to fail. Causing white and black spots to appear. To repair this may cost more than a new tv. If you want to attempt it yourself check out the above link. Hope this helps
Jan 12, 2014 | Samsung Hl61a750 61" LED Powered DLP HDTV
Our 55" Samsung DLP television has white dots all over the screen. Day after day, more seems to appear.
The DLP tv projection light engine is the cause.This problems,very expensive to repair or replaced the projection light engine.Samsung know about this flaw in the tv design.Talk to them,make a deal with them about it.Help u repair it.
Sep 27, 2010 | Samsung HL-T5676S Television
White dots
Samsung DLPs, means Bad Light Engine
Call Encompass Parts 1-800-638-3328
or UED 1-800-648-6657
Apr 15, 2010 | Samsung SP 56 K 3 HV 56" Projection...
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
Feb 06, 2010 | Televison & Video
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
White dots appearing on Samsung TV screen and multipling each day
It seems you might have an issue with the dmd board. Go to the menu, and if the dots still show on the menu, the issue definitely is with the dmd board but if they don't come up on the menu, the issue will be with the video board.
Aug 20, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have white dots appearing on my samsung dlp.
If the white spots are appearing in different spots or "Moving" it is the DMD board beginning to fail. Samsung DLPs seem to have a lot of DMD board failures. I would expect it to completely fail in the next couple months.
If there are only a couple small white spots that never go away it could be a mirror that is seized on the chip, but it's far more likely that the DMD board is going bad.
Aug 10, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Hls 5065 samsung rear projection tv
This could actually be an issue with either your DMD board or your Video board. With the TV on, select your menu, if the white dots are still there, the issue will be with the DMD board, but if they don't appear on the menu, the issue would be with the Video board.
Jul 30, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
I have white dots on the screen of my hsl4266wx/xaa?
If these dots are only seen when the picture is on I would look for the Optical Block to be causing it. Are the dots in the same place each time you turn it on?
Jul 17, 2009 | Samsung HLS4266 TV
White dots all over screen
this seems to be an issue either with your DMD board or with your Digital Video board... turn on the tv and go to the menu if the white dots appear on the menu the issue is with your DMD board but if they don't show on the menu, the issue would most probbaly be with your Digital Video board
Jun 26, 2009 | Samsung HLS4266 TV
Samsung PCL545R 54" Rear Projection Television Logo
103 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
