Question about DeLonghi TRD0715T Oil Filled Radiator Heater
Oil radiating heater won't heat
Should I toss it out, or try to repair?
If I try to repairs, what do I try first?
  • Anonymous Jan 11, 2009
    my heater just stopped working...lights dont come on. Is there any kind of reset or fuse?
    DeLonghi TRD0715T
  • 537 Answers
It could be many things, but the first thing to check is if the heating element is good. You'll have to (carefully) disassemble the unit.
Another thing that is possible, depending on the unit, is that the fuse is blown on the internal circuitry of the oil heater. A third possibility is that the thermostat is defective or has a short circuit.
If you are not comfortable monkeying around in the guts of the unit, call the company and ask what service options are available.
Posted on Mar 18, 2008
SOURCE:
Honeywell oil heater tipped over and will not powerback up
I don't have a definitive answer but I have an idea you could try. With the power plug removed from the socket, pick the unit up and give it some really good shakes and possibly turn it upside down. I am guessing the unit contains an internal "tip-over" sensor which I'm hoping will become unstick and reset itself. After you've given it a good shake, let it settle for fifteen minutes or more, and restore electricity. If your actions reset the sensor (and you're "lucky"), it should heat up and operate normally. If that doesn't solve it, I fear you're SOL and you may need to toss the unit.
Nov 02, 2014 | Honeywell HZ-709 Oil Filled Radiator...
Heater won't operate
If the switch is easy to access, you could simply replace it -- but finding the switch may be nearly impossible, because of the type of unit you are talking about. Also, some of these oil gel heaters have the electronics encased in a non-acessable area, meaning if one component goes bad, the unit is basically done. Your best bet to find the switch is to start with the manufactures website. if there are no diagrams or repair manuals, you should be able to find some contact information about repairs
Oct 01, 2012 | Lakewood Oil-Filled Electric Radiator...
My Comfort Zone Oil filled CZ7007J Radiator is not heating, it was working just fine when I turned it off, but when I turned it back on, no lights, no heat, like it's getting no power. Bought it
doubt there is any warranty being made in 2010 but they do have a heating element very similar to an electric water heater .I know of no repair shops that work on them.nor where you might find an element . SORRY Personally I found these oil filed heaters cost more to operate than the ceramic. types
Dec 30, 2017 | Comfort Zone CZ7007 Oil Filled Electric...
My heater works sometimes but mostly cold air
I recently tried the DIY service and repair manuals from a website and it actually helped me repair transmission problem in my jcb 3cx site-master. It would'nt move forward or reverse, engine was good both solenoids for forward and reverse worked, but still couldn't diagnose the problem.
I don't have much technical knowledge but I just followed it step-wise, and now it works perfect! covers wiring, diagrams, torque specs, PCV, everything
got it from www.reliable-store.com
Feb 26, 2018 | 2002 Pontiac Grand Am
Hi Our Delonghi Rapido heater has just started leaking oil, maybe a mL or 2 a day. Can this be repaired?
When a compresser leaks oil it is dead. If this is an air/heat unit you are out of luck. If anything I said does not match the facts of your system disregard my comment.
Jul 18, 2011 | DeLonghi 6507L Oil Filled Radiator Heater
It is not heating as strong as it recently was and this morning I found a small leak of oil on the hardwood floor. Can it be repaired and is it ok to use?
If it is leaking ,when it gets low enough,the heating elements will burn up,it is best to trow it away,and buy a new one,getting parts for these are an act of congress and you can buy a new one for the cost of repairs,and the tanks can not be fixed,or filled.
Jan 04, 2011 | Honeywell HZ-680 Oil Filled Radiator...
Reposting: I have a lakewood oil filled radiator heater that will NOT turn on. Is there someplace or something I can do to have it fixed?
Depending on its age, you can return it to the place of purchase. Because the cost of repair will almost certainly exceed the cost of replacement, it is not a practical option. If you have a friend who is comfortable with electrical systems, you could try that. There are a few brands of oil filled heater that have recalls. The consumer safety bureau or the manufacturer may have information about a recall on your product. This is a good time of year to purchase a new one as many stores are just starting sales on heating appliances. Farmerbear at FixYa
Oct 23, 2010 | Lakewood Oil-Filled Electric Radiator...
DeLonghi TRD0715T Oil Filled Radiator Heater Logo
656 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
