Question about Intel Motherboard
As a fellow technician...
It usually isn't good practice to put down other people trying to help others out. If my answer to a question wasn't up to your expertise thats fine, just don't bash others. The reason Diego most likely rated you as inappropriate was probably your comment towards me.
    Sergeant:
  • 261 Answers
I completely understand. But why would you not tell someone you don't know or your not sure. Bad info is as bad or worse then no information. I guess one bad inappropriate deserves another. cheers.
Posted on Mar 18, 2008
SOURCE:
Tip
Tips for Learning Magic
Magic is as much about the performance of the trick as it is about the trick itself.
All magicians put in hours and hours of practice in order to get good enough to 'trick' their audience.
  • Before you take your tricks to an audience, practice them infront of a mirror again and again. There's no such thing as too much practice. Once you've really mastered the technicalities of the trick.
  • Get a volunteer such as a family member or good friend to show your tricks to before you take them to a wider audience. They can be honest with you if they think it wasn't great or they were able to see how you did it.
  • You can join a magic club, either on the internet or even better a local one, where you can meet up with other magic enthusiasts to swap tricks and tips.
  • Try and find yourself a magician mentor. Basically anyone with more experience than you and with tricks that you respect.
Practicing is the key but having fun is just as important.
Good Luck!
on Oct 14, 2013 | Crafts & Hobbies
When turned on shredder runs, dose not stop when items are finished, but must be turned off manually. is there anything I can do to fix this?
stuck ,faulty reader switch or debris is blocking or covering the sensor unplug unit and carefully look and try to clean any paper or debris in shredder
Aug 11, 2016 | Shredder Office Equipment & Supplies
How do I oil the shredder
Found this that should help:
Oiling Instructions for Fellowes Shredders
Why and How Often: Regular oiling of cross-cut and micro-cut shredders is a necessary maintenance step to help keep your shredder functioning properly and prolong its life. Several factors determine how often you should oil your shredder-such as the type of paper being shred, the amount of paper being shred, and whether you shred only occasionally or continuously for long periods of time without stopping.
  • As a general rule, it is a good practice to oil your shredder each time you empty the wastebasket, or once a month.
  • Micro-cut shredders need to be oiled more frequently-ideally after every 15 minutes of use.
How To: Press and hold down the reverse button on your shredder. Put the tip of the oil bottle in the paper entry and make one or two sweeps across the cutters while gently squeezing the oil bottle. Continue to run the shredder in
reverse for another 10-15 seconds.
What to use: It is recommended that you use Fellowes Oil to oil your shredder. You may also use other oil designated for shredder use.
Do not use any oil or lubricant that is dispensed from an aerosol container.
Do not use any petroleum-based oils or lubricants. Use of such oils or lubricants will void the warranty on your shredder and could cause serious injury, as they are fire hazards when used with electronic devices.
http://shop.fellowes.com/oiling-instructions.aspx
Jul 04, 2014 | Fellowes Office Equipment & Supplies
Car Won't Work. HELP!!!
did you check battery could be death.Gas pedal is moving,under steering wheel any wires damaged.It is full park position.
Apr 30, 2013 | 2002 Pontiac Grand Prix
Machine says it's FULL, and won't shred, but it isn't/
there is a sensor that detects when the basket is full, if you remove the basket, look up for the sensor that would point down into the basket. it is probably dirty, clean off sensor.
hope this helps
Jul 05, 2012 | Fellowes SB85C Shredder
Key stuck in ignition of ford focus. column not locked
I had this same problem with my 2006 ZX4 Ford Focus. My focus has an automatic transmission. In order to get the stuck key out of the ignition, I discovered that there is sort of a "ring" on the gear shift that will sometimes slip down a little and cause the ignition to lock the key in place. The ring is located just benenth the plastic gear shift handle, right on the end there. If you push the ring up, you should be able to get the key out of the ignition. I found this out by accident. I know that sounds weird, but it actually works; at least it did for me. At first, I thought I hadn't put the gear in park. The ignition will not release the key if the gear isn't in park or if the steering wheel isn't in its lock position. I think most cars work on this principle; that wasn't the case here. For all of you 2006 Ford Focus owners out there having this problem, try my suggestion and I would also spray some WD-40 in the ignition hole too ( after you get the key out) . I hope this helps you folks out there. Good luck and have a nice day!:)
Sep 09, 2011 | 2006 Ford Focus
My 2002 crf450 r workef fine prior to fall storage now I can't get it started. I put a new plug in and it had new oil when it was stored. This is my first 4 stroke I always had 2 stroke bikes are they...
Go easy on twisting the throttle. Every time you twist, a shot of raw gas goes into the carb. The bike will flood easily. Put in a new spark plug, clean the air filter and drain the carb float bowl. Then get a can of starting spray. Spray into the air filter and then try to start it. The gas valve is turned on isn't it? Please rate my answer. Thanks.
Apr 23, 2011 | 2002 Honda CRF 450 R
Fellows S701CM shredder won't respond
unplug in and check the fuse in the back side of the shredder
good luck
Jan 24, 2009 | Fellowes 3011001 Shredder
Intel Motherboard Logo
35 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Ekse
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
