Question about Kodak EasyShare C743 Digital Camera
Unable to download to computer usb port does not recognize device
  • infraxes Jan 06, 2009
    Mac OS 10.4, computer doesn't recognize device via USB. Can't tell if the camera even turns on with the cord plugged into it.
    Genius:
  • 1,027 Answers
Have you installed the software on the computer?
Try this link and select OS and download and install.
Posted on Mar 18, 2008
    New Friend:
  • 136 Answers
Your computer may be to old just download a driver for your camera and it should work you can find it underfreeware if you search on google
3 Suggested Answers
SOURCE:
  • 34 Answers
SOURCE: EasyShare DX6440 "USB Device not recognized"
What operating system are you using?
If you have xp or vista, you can uninstall the software and transfer the pictures since these operating system has built in drivers.
Posted on Jun 23, 2009
  • 11967 Answers
SOURCE: I have a Kodak EasyShare M1063 USB Device not
Use a cardreader to download your pictures.
Posted on Aug 16, 2009
Unable to download pictures
I do know that sometimes a usb port will fail, for whatever reason, to recognize a device. It's happened to me before, and you can try a couple things. First, unplug and plug the usb port back in while it's connected to the camera. If the computer fails to recognize it, try you different usb ports, and the computer may respond. Aside from that, if you're running the XP or later versions of windows, you might try restoring your computer to a time before this problem occurred. Also, an update to Windows could have adversely caused this to happen, and restoring to an earlier date would hopefully reset the usb software's ability to recognize the port. Perhaps someone else will have suggestions if none of these things work, but that's the limit of my dealings with this problem. There's always the possibility that a hardware issue is at work here, but I hope not. If you do discover the port is bad, you can always get a hub and deal with it that way, leaving it connected to a known, good usb port. Just make sure you get a hub that is aided by a power source to relieve the computer from the burdon of powering up the hub. Good luck.
Apr 03, 2010 | Canon Cameras
Usb devics not recognized
try it to a known good USB port. if still unsuccessful connect it to another PC that has a known good USB port. if still unable to work. you might have a bad USB stick..
Hope it helps!
Feb 18, 2010 | Electronics - Others
Unable to get message from computer to printer. Message always appears : "Does not recognize USB port " I have tried all ports. Printer works as I tested on another computer.
Go to BIOS .For BIOS please press del or F2 button on your computer POST .After enter in the BIOS select on board devices or Integrated devices.select USB option and select AUTO option in Legacy USB devices if more than one USB Port then enable all USB port in BIOS.After that if printer not working then pls re-install the printer driver again.
Nov 16, 2009 | Compaq Presario S6000NX (DQ178A#ABA) PC...
The computer does not accept the Kingston usb!
Kingston is a decent brand device. Does the port recognize the device and is just unable to install drivers? Does the USB port work for other devices? Have you tried other ports? Go to device manager (start, control panel, system, hardware, device manager). Are there any rec X's? Any yellow asterisks? Fix whatever you find. These are just some hints that I hope will help you find your problem. I assume your device is a jump drive. You might try another also... perhaps yours is faulty.
Nov 14, 2009 | Computers & Internet
USB not working
if the usb detects other devices and not your drive,the drive itself may be faulty.If you plug in other devices in the usb and it detects them the usb drive or its connector is most likely bad.If it won't detect any devices the port is bad and drivers won't help.Possibly a motherboard issue.
Oct 09, 2009 | HP Compaq nx5000 Notebook
Thinkpad T20 won't recognize usb port
You can get a PCMCIA adapter with 4 USB v.2.0 slots on eBay. It requires power from the USB port on the laptop, but the pigtail connector is included. Works like a charm! Comes from China just like everything else in this country.
Nov 16, 2008 | IBM ThinkPad T20 2647 Notebook
Connection problem with msr206
1. Try plug in the device to the back of your computer instead of the front USB port (this is because some computers don't have enough power in the front USB ports) 2. Some USB 2.0 device are not backward compatible with USB 1.1 ports. Try plugging in with USB 1.1 and 2.0 port to see that's the cause of the problem.
3. Try downgrade all your USB port from 2.0 down to 1.1, you can do that in your BIOS.
4. if all failed, try the USB device on a different computer. Then you can determine if the USB device or the USB port is the culprit of the problem
also, if you can't find your solution here, you might be able to find it on the link below...
http://dan.hersam.com/archives/2005/07/18/usb-device-not-recognized
please give a fixya rating for my help to you , thanks and if you need further assistance , i'll be glad to continue to help if needed
electech
Nov 07, 2008 | Computers & Internet
USB port problems with hp printer
There are few things to remember using USB.
  • If your System is in hybernation mode, don't remove any attached USB device, because it will damage your USB driver. This is one of the known problem from microsoft.
  • If you have to remove any USB device use 'Safely Remove Hardware'.
To remove currepted USB drivers its not enough to remove your printer drivers.
  1. You should un-install the 'Universal Serial Bus Controllers' from Device Manager.
  2. Then re-boot to clean registry.
  3. Install the 'Universal Serial Bus Controllers' using XP Setup CD.
  4. Then check the Mass storage, PDA etc, it should recognized by XP.
  5. Then install printer driver (don't attach printer to system untill setup finish or setup says to connect).
I think it will fix.
Please let me know your feed-back.
Thanks
Iqbal
Apr 15, 2008 | HP Photosmart C3180 All-In-One InkJet...
Kodak EasyShare C743 Digital Camera Logo
62 people viewed this question
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
