Question about Hitachi 65S700 65" Rear Projection HDTV
UPGRADE MY HITACHI
Where can I find or get mmc upgrade for my hitachi 65s700. Thanks Eddy M
Go to MENU>SETUP>UPGRADES. Jot Down Your Software version. Call Customer Support at (800) 448-2244. Give them your current software version, Model number, and TV Serial Number, and they will tell you if you need upgrade. If upgrade needed, they will mail out MMC card with instructions for upgrade.
Posted on Nov 23, 2008
  • Bob Scammell
    Bob Scammell Feb 14, 2014
    NO they will not send you a card, you have to buy one and then they will "tell you where to go" to download it yourself - poor customer service.
Where is the projection bulb on my Hitachi 65s700 65 inch
Hi Anonymous,
There is no "Projection Bulb" for this model. It as a 3 tube Rear Projection TV. The most common problem is Convergence Failure as in the link below.
Calgary Hitachi Big Screen In Home TV Repair Service
Robert
Nov 12, 2015 | Hitachi Televison & Video
My television turns on has sound but no picture can you help please?
Make sure the video input is properly selected with where you have it plugged in
Nov 17, 2013 | Hitachi 65S700 65" Rear Projection HDTV
Eddy current
Make sure that the video cable is connected to the same input that the audio is connected to. (ex. video 1 input matched to audio 1 input) If not that I would replace the video cable.
I am trying to upgrade firmware on a hitachi 42hds69, using a 2 sd card, I formatted the new card before uploading the file, I did unzip the file on my desktop. The tv won't do the upgrade. any Ideas
I had an issue (OTA no audio in channel 2-1 and 11-1) on my Hitachi 42HDS69 so I tried to upgrade the firmware. The manual as well as the instructions on TV all state to use a MMC card. Someone on an internet forum also stated that a 7-pin MMC is needed. I tried exactly that but it did not work. Finally I tried a 128MB SD card and it worked like a charm. The firmware upgrade fixed my OTA audio issue. I went from V0108 to V0125.
All you need to do is to extract out the .F02 file and place it in the root directory of the SD card.
BTW, I did call Hitachi customer support. They refused to help due to the TV is too old (about 10 years old).
I guess it all depends on who you speak to at Hitachi?!
Feb 09, 2011 | Hitachi 42HDS69 42 in. Plasma Television
I have a hitachi 65s700. why would i need to upgrade the software?
software change all the time. If you want everything to work properly you need to keep it up to date. Programs may stop working or freeze up if they are not in sync. It is up to you, but it is a good Idea.
Sep 08, 2009 | Hitachi 65S700 65" Rear Projection HDTV
Hitachi HDTV "no sound" or "no audio" OTA channels *SOLUTION*
Thank you for posting this. I will attempt to post this information in a more permanent place that can be found easily.
Thanks again,
Dan
Feb 10, 2009 | Hitachi 51F59 51" HDTV Projection...
Whining sound from back of tv sounds like fan must turn volume up to cover noise
This is a 15 k frequency sound
It is usually caused by one or more of the components in the High voltage circut,
with the set on and the back off, take pencil with an eracer.
Then push on each of the coils or transformers to see if it stops or diminishes.
if so coat the part with silicone sealer spreading to at least 2 components nearby. let dry.
This may help.
Thanks guy9
May 03, 2008 | Hitachi 65S700 65" Rear Projection HDTV
LOCKED HITACHI TV
need model and chassis number and I' may help you email me
Mar 20, 2008 | Hitachi C21RF39 21" TV
The TV flickers screen goes black then comes back in 15min and is fine? Anyone?
check for loose plugs or bad solder joints on the main circut board.
Espescially on the vertical output I.C.
Thanks guy9
Jul 10, 2007 | Hitachi 65S700 65" Rear Projection HDTV
Hitachi 65S700 65" Rear Projection HDTV Logo
2,437 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
