Question about Vector 995 Radar Detector
Beltronics Vector 995
Hi, I have problem with my Vector 995, when I plug it in it says "SERVICE REQUIRED". I have it for 3 yrs now so its now covered by waranty anymore and sending it to manufacturer cost a lot of money and I think its not worth it.
Any advice for me how to fix it?
Thanks
Tiger
  • EZRIDER May 03, 2008
    I HAVE A BELTRONICS VECTOR 995. AND WHEN I POWER IT UP I HAVE NO SOUND AND IT GOES TO SAY SERVICE REQUIRED, WHAT CAN I DO TO FIX THAT?
  • Anonymous Mar 15, 2014
    It's telling me to service, it stopped working
You may have a voltage issue.Try to reset your detector. Hold the city and bright buttons until it resets. This should solve the message problem.
Posted on Apr 18, 2008
    New Friend:
BETRONICS VECTOR 995 / 996 SERVICE REQUIRED FAULT DURING POWER ON REPAIR !!
2014 Greetings from Commander Tony. Here is the hidden treasure of information desperately needed by Beltronics 995 / 996 owner's to save on the service charges mailing it in. You can do a great a job yourself with the required information to clear the SERVICE REQUIRED glitch fault during power ON and/or during SELF CALIBRATION RESRT MODE. To fix your 995/996 and get it back to new:
Remove the 2 screws under the bottom of the case. The 1 on the top right corner and the other screw is under the serial sticker.
Inside the case the laser portion is mounted to the circuit board with 3 screws. Once you remove the screws lift the laser unit straight up off of the circuit board revealing 2 seperate pin style connectors that went up into the laser unit.
Basically the SERVICE REQUIRED circuitry is not faulting because of the LASER UNIT attached to the board at all. Though while you have it off from the board it is advised to clean the bottom side of the laser unit's female pin style connectors with iso-propyl alchohol and immediately blow it clean with compressed air. Do the same for the circuit board pin style connectors that go into those connectors for the laser unit.
Here's the fix!: SERVICE REQUIRED glitch is caused by the main ground the screw from the case squashes itself to once reassembled. That small circle amount of steel on the circuit gets dirty through the years from all of the movement/vibrations of the case and what not and the screw moves around enough after a while to scrape the base of the ground on the circuit board to become dirty. (YOU WILL FIND THE GROUND BASE ON AT THE TOP CORNER OF THE CIRCUIT BOARD.) One of the screws that holds everything together gets tightened down onto the ground circuit. It is in combination directly with the small aluminum looking box/square tab at the top corner of the circuit board.
Clean the small round ground circuit with rubbing alchohol and let the liquid run underneith the small aluminum looking box tab that gets squashed tight along with the ground base circuit and immediately blow it clean with compressed air.
Reassemble everything and " PRESTO !! " you are good to go!
I hope this helped and change the future in small way or in a large sense for the better. Later people... Tony.
Posted on Apr 08, 2014
    New Friend:
  • 136 Answers
Repair Master ARMX300 XchangeCard 1-Year Warranty Replacement Service Plan Replacement of any battery or AC powered electronics product / Effective for one year from date of expiration of manufacturers labor warranty under $300 ... more info J&R Item # WAR ARMX300 Mfr. Part # ARMX300 Beltronics Vector 995 - war.png?cell=100,65&qlt=67&cvt=jpg
p.gif p.gif BUYING INFO Was $39.99 You save - $10.00 Your price $29.99 Usually ships in 1 - 2 business days
Shipping Info
Also available in store at:
Our Low Price Guarantee p.gif Replacement of any battery or AC powered electronics product / Effective for one year from date of expiration of manufacturers labor warranty under $300
The Warrantech ARMX-300 Repair Master Warranty XchangeCard is a special Performance Guarantee service plan that will provide a replacement for any defective electronic product (that is powered by either an AC cord or battery) valued at $300 or less. If an exact replacement is unavailable, a similar replacement will be provided of equal or comparable monetary value to the original product.
  • Xchange card guarantees you a replacement product should it fail for up to one-year after original warranty expires
  • HOW DOES THIS WORK? - If your product has a 90 day manufacturer's labor warranty, the Warrantech replacement coverage begins at the 91st day. If your product has a 1-Year manufacturer's labor warranty, the Warrantech replacement coverage begins the day after that manufacturer's warranty expires. Simply follow instructions inside your Warrantech package
  • This Performance Guarantee goes into effect immediately after the shortest warranty period of your original manufacturers warranty expires
  • The card is easily activated through a Toll-free number and is insured by a carrier rated “excellent” by A.M.-Best*
  • Warrantech Corporation is a leader in the field of extended warranties
  • Posted on Mar 18, 2008
    Blinks service required constantly
    This means that your V995 has repeatedly failed its internal self-calibration procedures. Like the message says, you need to send it to Beltronics for service.
    Aug 12, 2009 | Vector 995 Radar Detector
    No sound on my vector 940
    Beltronics is now using a special "high temperature" speaker which resolves issues with speakers blowing due to high ambient temperatures. Contact Beltronics and schedule service for your V940. Not only will Bel replace the speaker with the newer model, but they will also test and calibrate your V940 and install whatever the current firmware is for your V940.
    Jun 22, 2009 | Vector 995 Radar Detector
    Manual to vector xr950
    My radar was constantly scaling from low to high volume on my vector xr950 but now it does not power up at all. Has anyone got suggestions.
    May 17, 2009 | Vector 995 Radar Detector
    Beeps and says service required
    This message occurs if your V995 can't properly calibrate its internal circuitry for the antenna. As the message implies, you need to send in your V995 for factory service.
    Jan 02, 2009 | Vector 995 Radar Detector
    I have a beltronics 995 radar detector and i have a problem with it. The message "Service Required " appears.Please help . Thank you
    This means that your RD has failed several attempts to self-calibrate its internal antenna. Like the message says, you must send in your V995 for service. Bel will fix whatever the issue is, and they will install the latest firmware too. Also, be sure to ask Bel to check and see if they need to replace the existing speaker with their new "high temp" speaker. The new speaker resolves potential issues of the original speaker failing due to high heat conditions.
    Dec 03, 2008 | Vector 995 Radar Detector
    Beltronics Vector 995 Radar Detector Problem
    this means it needs to be sent in for repair. Heres bels num
    1-800-341-2288.
    Oct 17, 2007 | Vector 995 Radar Detector
    Beltronics Vector 985
    If its still under warrenty Call Beltronics 800-341-2288 I had the same problem and they re-tuned the Detector and updated the firmware my Vector 985 was out of warrenty by 5 months and Bel repaired it for free. Hope this helps
    Jun 17, 2007 | Vector 985 Radar Detector
    Vector 995 Radar Detector Logo
    1,341 people viewed this question
    Top Beltronics Vehicle Parts & Accessories Experts
    John Nolan
    Steve
    Jerry Greenberg
    Jerry Greenberg
    Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
