Question about Sewing Machines
Help cannot use my singer cg 590!
Everything is threaded the correct way but the bobbin thread won't come up
  • 2 more comments
  • NEW SEWER Apr 07, 2008
    everything is threaded the correct way but the bobbin thread won't come up
  • Anonymous May 23, 2008
    My Singer CG590 jammed up within 1 hour of use. The threads on the bottom were intermittently loose. Now the needle will not pick up the bobbin thread. Singer told me it is "Out of time". I was using upholstery thread as I was sewing vinyl. Singer claims the machine will not sew with this thread, only what I call :wimpy" thread. This is described as a Work Horse able to sew leather. Leather being sewed with wimpy cotton thread? This machine is only good for sewing little cotton items like hankies. Any brand new machine, purchased from a Singer store should not need to be serviced after only 1 hour. My 80 year old Singer is still running smoothly and was NEVER serviced, other than oil. I plan on fixing the problem by returning the machine which I consider a piece of junk.
  • cookie maria Oct 02, 2008
    Bought Singer CG 590 after 2 demos School Machine Distributors rep . (demo'd 8 layers leather/16 of denim OK) Mine knotts terrib. under most fabric despite tension/stitch/needle readjusts. Threader never funct. Bulb weak/bad aim.Presser foot up/down & not 3 posit. in manual/can't climb 2 layers cotton tee/folded seam allow.Face plate teeth adjust inadeq. to compens. lack flex presser foot.Manual good thread/needle/stitch charts. "How to" info incomplete or inapplic this mach.Sturdy frame. MANY lost hrs/max, frust/estim. my fault.Junk mach& tech attitude (said see video/call back, despite my deadline/urgency.(I have 40+yrs sew exper) Mach needs better owner !?
  • Carol Sutton
    Carol Sutton Sep 10, 2012
    That's funny because I use upholstery thread in mine all the time. Just in the bobbin for the most part, but it works well. I still use my Pfaff 230 for actual upholstery, though.
Threading a bobbin on a singer is backward to most other machines.
The thread goes under and you bring back through the 2nd slot and your home free . Had one for seven years and it wasn't worth anything after having a Kenmore verticle and then buying this one that threads actly backwards. Works fine after I figured it out. I use it for quilting.
Posted on Aug 10, 2008
I have also bought a Singer CG590 and after a few days of sewing almost threw it out the window!!!...a waste of money is what I say!
Posted on Jul 25, 2008
I have a singer CG 590C. It didn't come with manual. I'm just learning to sew. My bobbin was hung up with thread when I pulled on it I pull the whole bobbin casing out. How do I get it back in? Help
First thing, you should probably get a manual for your machine.
Singer CG 590 Commercial Grade Manual
How to thread Singer CG 590
This machine is listed as a commercial grade professional sewing machine, so you are going to have some additional learning curve if you are just beginning to sew.
Nov 23, 2015 | Singer Sewing Machines
What should the tension be on for this machine?
Most of the time if the bobbin thread is coming through on top it means that the bobbin thread is too loose and/or the top thread is too tight and is pulling the thread too much. check and make sure that there isn't anything in the top tensioner that could be increasing the tension like lint. Good luck.
Feb 17, 2015 | Singer CG-590 Commercial Grade Sewing...
How do I adjust needle depth on my Singer 590 c?
There is an Allen screw on the shaft of the needle bar that you can loosen to be able to adjust the height of the needle. Some machines also have markings as to where the needle height needs to be. If you still have trouble talk to the people at the link below. They may be able to help. good luck Sewing Machine Repair Repair Sewing Machines Sewing Machines Repair Fix...
Nov 23, 2014 | Singer CG-590 Commercial Grade Sewing...
How to fix timing on CG 590 singer sewing machine?
It would be best to have a sewing machine technician do that; depending on your machine, it can be complicated to even to GET to the area to retime the machine.
Jul 22, 2014 | Singer Sewing Machines
I just received a new Singer CG-590. Have threaded the machine and bobbin. Each time I try to pick up the bobbin thread, the top thread wraps around the bobbin case. It will not pick up the bobbin...
try turning the bobbin the opposite way, and if that doesn't help then take the machine back and get another one, maybe even a different model
Dec 26, 2013 | Singer Sewing Machines
Needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Dec 12, 2009 | Singer Sewing Machines
I have a singer cg 550 sewing machine and I am not sure which slot to put the bobbin thread in first
If you put the bobbin in the case with the thread coming off in a clockwise direction, the thread should just fall into a slot and gently tug on the thread and it will slide through the tensions. Lay it across the bobbin case and then pick up the thread with the needle.
Dec 20, 2008 | Singer 5050 Mechanical Sewing Machine
Singer CG-590
You can find a Users Manual plus a workbook that you can get in PDF and print. Users Manual is 44 pages and workbook is 58 pages. Go to www.mannualowl.com and search for Singer CG 590n manual. It's all free.
Apr 19, 2008 | Brother CS-8072 Computerized Sewing...
Threading CG-590
I have a CG590 SEWING MACHINE AND CAN NOT THREAD IT WITH THE DIRECTIONS THAT CAME WITH IT. CAN YOU HELP THANK YOU, SANDY
Sep 21, 2007 | Sewing Machines
Sewing Machines Logo
653 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
