Question about Casio ClassPad 300 Calculator
Os 3 upgrade
I have been upgrading several classpad 300 plus to version 3. two of the calculators came up with the following message and the upgrade finished.
No Boot Block with a picture of a computer and calculator and a cable between them. The calculators can not be turned on at the moment. They both have new batteries. Can you help?
How to update my classpad 300plus toclasspad330?
Posted on Jun 27, 2008
Hi, On the classpad when I enter solve(9=15+6sin(pi x/3)) it returns the answer {x=6.constn(1)-3/2} rather than actually solving. This constn is coming up regularly when solving similar types of...
The calculator did solve the equation and give you the result. But because the function is periodic there is an infinite number of angles that satisfy the equations. That is where the constantn(1) intervenes. constantn(1) is the ClassPad way of signifying an arbitrary integer.
Your solutions are x=-3/2 plus or minus 6 times N, where N is an arbitrary integer.
Jun 27, 2011 | Casio ClassPad 300 Calculator
How do I enter degrees minutes seconds on casio classpad 330
This is valid for the ClassPad 300Plus (OS version 2.2) but it should work for the ClassPad 330 OS version 3.x
In the MAIN menu screen press the Action menu, then Transformation sub menu. At the bottom of the drop down list you have dms an toDMS.
If you enter toDMS(18.58) you get dms(18,34,48). Then if you use dms( on the calculated result: dms(ans) you get 18.58
So if you have a result in deg, min, sec you convert it to decimal degrees by making use of the dms( command.
May 12, 2011 | Casio ClassPad 300 Calculator
Can you update a classpad 300 to a 330 operating system
It depends. If the ClassPad has OS 1.x you can upgrade it to 2.x freely. However you need to buy (separately) the ClassPad manager 3.x to be able to upgrade the OS to version 3.x. After that further upgrades appear to be free.
Feb 05, 2011 | Casio ClassPad 300 Calculator
How do i enter a degrees/minutes/seconds value on a casio classpad 330
Jan 30, 2011 | Casio ClassPad 300 Calculator
My son has a TI-84 Plus calculator and it is completely frozen. There is a message on the screen that reads " RAM cleared". Below that message it says "Press ALPHA F1-F4 to locate shortcut menus" but it...
The calculator OS has been upgraded to the version 2.53 MP.
For this version, whenever you remove batteries (or replace them) and turn calculator ON, you are reminded to Press [ALPHA][F1-F4] to locate Shortcuts Menu.
The calculator also asks the user to press either
[1:Do NOT show Again]
[2:Continue].
Here is what these cryptic messages mean.
Certain functions implemented on the new OS are available by pressing the [ALPHA] key followed by F1, F2, F3 or F4.
Since you may forget how to get to them, the calculator gently reminds you that there are other functions accessed only by pressing the [ALPHA] key.
It also gives you the option to flash the reminder every time the calculator memory is reset (CONTINUE) or NOT to SHOW the REMINDER again.
Usually after the RAM cleared message, press [2:Continue] or any other key but [1: ] to keep being reminded how to access the new functions.
Once a key is pressed the screen is cleared and you have the solid blinking cursor.
Oct 06, 2010 | Texas Instruments TI-84 Plus Calculator
How do i enter degrees minutes seconds on classpad 330?
Sep 06, 2010 | Casio ClassPad 300 Calculator
How do i do a fraction on a TI-83 plus calculator
  1. Enter a numerator, the division sign /, then the denominator.
  2. Instead of pressing the [ENTER] key, press [MATH] and [1:|=>Frac]
  3. The command line displays the fraction you entered, followed by the [|=>Frac] command.
  4. Press [ENTER] to display a reduced (equivalent) fraction.
  5. If you keep using the sequence [1:|=>Frac][ENTER] with all your fractions you can keep getting fraction results.
The OS of the calculators Ti84PLUS and TI84Plus SE has been upgraded recently to the 2.53MP (math Print) version, which provides some significant improvement to the handling of Fractions, Logarithms, etc. Unfortunately for you, the upgrade is not compatible with the TI83PLUS
May 10, 2010 | Texas Instruments TI-84 Plus Calculator
How do you install games onto the casio class pad 300 plus?
you need the installing cd that comes with the package install the add-in application thingy.... connect your classpad to the computer run the add-in application on the computer... hope this helps all =D
Jan 15, 2008 | Casio ClassPad 300 Calculator
Casio Classpad 300 plus
I bought a classpad 300 plus but I dont know how to operate it. I saw some books for classpad 300 and I really want to buy some. However everytime I try to buy, there is always a classpad that goes with the books . Can I buy books for classpad with out buying a calculator anymore?
Sep 13, 2007 | Casio ClassPad 300 Calculator
Casio classpad 300 plus
install FA-CP1 from disk
COnnect the calc
go to handheld assitant
click install add-ins
choose the game
*games an be found at planet casio, always end in .cpa*
Apr 03, 2007 | Casio ClassPad 300 Calculator
Casio ClassPad 300 Calculator Logo
348 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
