NOT CLEANING SILVER WARE OR DISHER PROPER - Washing Machines
  • Anonymous Mar 09, 2009
    not cleaning dishss
    New Friend:
  • 136 Answers
Clean inside with a load of vinegar
Posted on Mar 18, 2008
Why won't my Saeco Odea Giro descale?
Might need some urn cleaner to do a proper job. Scale is dry chemicals that you want remove so use the proper cleaning agent.
Aug 09, 2014 | Saeco Odea Giro Espresso Maker -...
Our Maytag MDB8600AWS uses a lot of energy. I use the disher 1 to 2 times a week. My last electric bill was $200.00 more and the usage was the dishwasher. We installed the disher in late Dec 2010. We...
Are you using a high clean setting? We had one that had "pot scrubber" as a setting and it used a lot of electricity.Look to see if there is a low power setting using less heat. In general they do use a lot of energy.
Feb 03, 2018 | Maytag 24 in. MDB8600AWS Jetclean II...
Standing water in botton of disher washer
It could be as easy as cleaning the screen in the bottom of your machine. Also it would be good to clean underneath while you have it apart. That should solve your problem.
Jan 08, 2010 | Frigidaire Dishwashers
My disher is not cleaning properly. It leaves
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
34taqg
Nov 27, 2009 | Bosch 24 in. SHX46A05UC Built-In...
CLEANING LITE IS FLASHING OFF AND ON THE DISHER WON'T TURN ON.CAN'T GET THE TO TURN OFF
This may help in your situation. The following link explains how you may be able to clear the blinking clean light problem:
http://www.fixya.com/support/r417123-blinking_clean_light_kenmore_whirlpool
Now...keep in mind all dish washers are not alike and have different panel options. If you do not have the same set up as I have referenced, the tech sheet for your dishwasher will explain. The tech sheet is located behind the lower toe panel under the door and lists the proper sequence of buttons to push for diagnostics and troubleshooting.
NOTE: Sometimes the tech sheet is located behind the inner door panel. You will need to remove the screws securing the inner panel to access it if this is the case. Make sure you turn off the main power breaker before doing so.
Sometimes this can be a momentary glitch in operation. However, if the problem keeps reoccuring the number of flashes is an indication of which circuit is causing your problem. Again, refer to your tech sheet to determine this.
If you have any questions, please let me know. I hope this helps you solve your problem.
Sep 11, 2009 | Dishwashers
My psp wont play games or movies
do you have custom firm ware. if not try cleaning laser with qtip & alcohol if still a problem try updating firm ware still not working needs servicing either drive is bad or firm ware has a bad sector
May 08, 2009 | Sony PlayStation Portable (PSP) Console
Dishwasher will not fill with water
make sure you have the door lock on,also make sure there was not a knock ring on the disher washer side,did you remove the disher hose and check to see if hose is clear and disher hole is clear?let me know-mike
Jun 15, 2008 | Sears 24 in. 14181 Built-in Dishwasher
Dishwashwer not cleaning properly
You can try one of the cleaners sold for this purpose like glisten, dishwasher magic or jetdry dishwasher cleaner. It may not be getting enough water due to the fill valve clogging up. You can check this by small amounts of water slowly with a cup in the wash cycle and quickly opening the door to see if the upper sprayarm is turning. If more water helps you need to replace the valve.
Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
