Question about E-Machines eMachines Desktop PC
Ram upgrades I am upgrading 2 e-machines computers with Ram. My question is what order to fill the slots with memory. The first machine is a T4200 which has 3 slots in it and holds a 1.5 gb max. I am adding 2 sticks of 512 mb each to the factory installed 256 mb. Assuming the current stick is in slot 1, do I now put in a 512 each in slots 1 & 2, then place the 256 in slot 3? The second machine is a T3624 with 2 slots and a 2 gb max. I am replacing the current 256mb stick with one each at 1gb & 512mb. Does the 1gb go where the current 256 is?
    Sergeant:
    Champion:
  • 304 Answers
Hello there,
Although these are all types of double data rate (DDR) memory, the varying numbers refer to the different speeds of memory your computer was designed for. Crucial no longer carries PC2100 (DDR266) memory, but PC2700 (DDR333) memory and PC3200 (DDR400) are backward-compatible with PC2100.
Memory is designed to be backward-compatible, so generally speaking, you can safely add faster memory to a computer that was designed to run slower memory. However, your system will operate at the speed of the slowest module or system component (the "lowest common denominator" effect).
One thing to keep in mind is that the memory does need to be the same type-for example, SDRAM cannot be mixed with DDR, and DDR cannot be mixed with DDR2. We recommend that you use the Crucial Memory Advisor™ or System Scanner tools to find the right memory for your computer.
Yours truly,
Jack d.
>>>>>>eof
Posted on Mar 18, 2008
  • 27 Answers
Assuming the empty slots are for memory then just add the 2 new sticks to empty locations and leave the original one in place. The order shouldn't matter, just the overall combined amount. With the t4200 you should get a total spec of about 1.25gb depending on the operating system.
With the t3624 you'll have to pull the exhisting stick to free up a slot for one of your new ones. You'll have about 1.5gb once you're done with the install.Again, overall ram total is what counts, not the order.
Just play it safe and make sure you're correct on the locations and memory type/capacity. Check out Crucial.com and run a free system scan for your memory type and capacity. Belarc Advisor is a good program too. Good luck..
    Genius:
  • 1,226 Answers
Hello!
in T4200 since the maximum ram is 1.5 gb you can do that inserting the -2-512mb and 1-256. however this will create error later. It is advisable that you must insert same capacity in each slot and same specs and manufacture's date to avoid further issue sooner. means that if you use 256mb. it should be 3-256m and if u use 512 it should be 3-512mb. but anyway ucan use 1-256 and 2-512.
same is through T3624 -there is no problem with where to insert the 1gb and 512 u can test it one by one. do not insert simultaneously ..one after another. means that when you insert one memory you switch on the computer for test and shutdown and insert another if the first test is successfull.
melnavz
  • Anonymous Mar 18, 2008
    It's your turn amsandlas, im just telling you the truth.
    thanks for using fixya, melnavz
  • 807 Answers
Does'nt matter which goes where as long as they are all compatible with the motherboard.
SOURCE:
How do you access the memory slots on an acer aspire z3731
Memory Sockets or Slots are the place where memory RAM modules are inserted in the motherboard. The Acer Aspire Z3731 has 4 (4 banks of 1) memory expansion slots. A memory bank is a group of memory expansion sockets, a bank must be completely filled with memory modules of the same size and type in order for the system to recognize and address the memory. i.e. :
2 sockets (2 banks of 1) This indicates that there are 2 memory slots. These are divided into 2 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
3 sockets (3 banks of 1) This indicates that there are 3 memory slots. These are divided into 3 banks, and each bank consists of one memory slot. So you can add memory one piece at a time for the system to use.
4 sockets (2 banks of 2) This indicates that there are 4 memory slots. These are divided into 2 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
8 sockets (4 banks of 2) This indicates that there are 8 memory slots. These are divided into 4 banks, and each bank consists of two memory slots. So you must add memory two pieces at a time (they must be the same size and type of memory) in order for the system to benefit from the upgrade.
12 sockets (3 banks of 4) This indicates that there are 12 memory slots. These are divided into 3 banks, and each bank consists of four memory slots. So you must add memory four pieces at a time (and they must be the same size and type of memory) in order for the system to benefit from the upgrade.
Mar 09, 2012 | Acer Aspire All-in-One Desktop PC - Silver...
I am having hp 530 laptop with intel core duo inside,512mb RAM,80 gb hard disk.I want to upgrade my processor,ramand hard disk. can i do it ? upto what limit ?
Unfortunately I would have to say no, you won't be able to upgrade the processor. I located a user manual at
http://h18000.www1.hp.com/products/quickspecs/12722_na/12722_na.PDF
According to specifications you can increase the Ram to 2 MB and the hard drive should be a 120GB hard driver Sata
System Memory 1024-MB 533/667-MHz DDR2 SDRAM in one slot
Two SODIMM slots; supported memory 2048 MB2
Operates at a maximum of 533-MHz with 667-MHz memory
Hard Drive 120-GB3 5400 rpm SMART SATA
The processor will be limited to what the motherboard can support and it was designed for that 1.6 Ghz processor. Unfortunately it is very difficult to upgrade processors in laptop machines. I do have to ask how old this machine is. The specification indicates MegaBytes of ram and this is actually very little Ram in today's computing world. Most machines support at least 2 gigaBytes of Ram to start with.
Nov 20, 2010 | HP 530 Notebook PC
We purchased a hp touchsmart 600 with 4 gb of ram and ordered an additional 4 gb for a total of 8 gb of ram. We got (2) 2 gig but there are only slots for 2 memory sticks. We sent them back and now we have...
First find out if 4Gb sticks of the right type are available for your machine, and that the machine supports that much RAM. Then make sure you carefully order 2 x 4Gb sticks.
Jul 19, 2010 | Computers & Internet
Hp touchsmart 600 memory upgrade. We have ordered (2) 4 gb memory upgrades for this machine. As far as we can tell the machine only has two slots for memory upgrades and the most recent items sent were (2)...
Maximum RAM supported by this system is 2x4GB PC3-10600 200 pin, DDR3 SO-DIMMs modules.
2x2GB is standard factory RAM. Call back the seller and get a replacement(2x4GB).
Lenovo 3000 y410 graphic card upgrade?
Lenovo Y410 System RAM can handle up to 2GB of memory. Since the machine has 2 slots for RAM and you already have 1GB preinstalled with the computer all you need to purchase is another stick of 1GB RAM.
There is no chance of upgrading Graphics card since it doesnt have a video card slot and the preinstalled VCARD is onboard.
Should you have any other questions just please leave a comment.
Cheers~
Jul 14, 2010 | Lenovo 3000 Y410 Notebook
What is compatible with my emahcines w3050 in upgrading my video memory. What limits are on my machine?
HDMI? Oh, then you would be talking about a graphics card like this one,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5071689&CatId=318
HIS Radeon HD4670 IceQ
1) AGP 8X graphics card
2) Has a VGA, DVI, and HDMI port
3) 1GB of GDDR3 ram memory
4) 128bit interface
5) 320 Stream Processors
6) Core Clock is 750MHz at maximum capability
7) Memory Clock is 1746MHZ at maximum capability
It doesn't matter that your computer system ram memory is DDR Sdram. The GDDR3 graphics ram memory operates independent of the system ram memory.
Information about graphics, graphics cards, and graphics card terminology,
A) http://www.brighthub.com/video-games/pc/articles/984.aspx
B) http://computer.howstuffworks.com/graphics-card.htm
Mar 20, 2010 | E-Machines W3050 PC Desktop
My dell dimension 9100 only has 2 memory slots, should it not have 4?
Some motherboards have 4 slots, but they are usually high end computers for gamers and graphical applications, your computer is a mid range which means it will only have 2 memory slots for ram upgrades, if you playing games on this pc it is advisable to also upgrade the graphics card.
Feb 04, 2010 | Dell Dimension 9100 PC Desktop
Ram upgrade
you need to make sure the ram is compatable, it looks like an old machine so chances are its using sdram pc100,
check the ram your trying to make sure its not pc133. let me know what each piece of ram has on its sticker
Mar 23, 2009 | Dell OptiPlex GX200 PC Desktop
Memory
no it does not support ddr2 ram.
goto this link for mor ingormation.
http://support.gateway.com/s/PC/R/3724/4365sp3.shtml
good luck
Jul 09, 2008 | Gateway 504GR PC Desktop
Ram upgrade
In most cases if you put of not thesame capacity in any computer later will create further problems. it can damage the other memory or both and the worse is when also the motherboard will also damage.
That is why im telling you this. Please prevent inserting memory of two or three different capacity. You should not do that.
You should select etheir use all 256mb or all 512mb or all 1gb.
in the T4200 since max. is 1.5gb, either use 3-512mb if can carry the maximum if not , then use only 2-512mb.
in T3624 since max is 2GB. You can try 2-1gb if can carry the maximum if not, use only 1-1gb.
Note:
You can use or inserting at different capacity but is at your own risk. "
Ps. does no matter either you put smaller or bigger in first slot.
Mar 18, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
91 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
