Question about Danby DCD5505W Electric Dryer
Replacing bryer belt
I am trying to replace my belt for my dryer
  • Anonymous Aug 24, 2008
    I NEED TO PUT A BELT ON THE DRYER
  • 20 Answers
Part Number DB-6060532 available at marcone.com
Posted on May 23, 2010
  • somi_w May 23, 2010
    Here
    are the Danby instructions:
    INSTRUCTIONS
    TO CHANGE DRYER BELT DCD5505W-1, REMOVE THE SCREWS ACROSS THE BOTTOM OF
    THE FRONT THAT GO FROM BOTTOM UP. REMOVE
    THE TOP BY REMOVING THE 2 SCREWS HOLDING IT DOWN FROM BEHIND, PULL BACK AND
    LIFT OFF. REMOVE THE 2 SCREWS ON EACH SIDE THAT GO FROM INSIDE FORWARD THAT
    HOLD THE PLASTIC FRONT ON AND REMOVE THE PLASTIC FRONT. REMOVE THE FRONT SCREW
    FROM THE CENTER
    BRACE BAR RUNNING FRONT TO BACK ACROSS THE TOP. REMOVE THE 2 SCREWS ON EACH
    SIDE AT THE
    TOP THAT WERE REVEALED WHEN THE PLASTIC FRONT WAS REMOVED. REMOVE THE 6 SCREWS
    AROUND THE FACE JUST INSIDE THE DOOR THEN SWING THE FRONT OUT RIGHT TO LEFT. REMOVE
    THE 2 SCREWS ON EACH SIDE OF THE
    INNER BULKHEAD PANEL AND REMOVE THE PANEL. AT THIS POINT YOU CAN REPLACE THE
    BELT, IDLER, AND
    MOTOR MOUNTS.
    THE 1 EXTRA STEP THE REPLACING THE MOTOR IS TO REMOVE THE BACK AND THE
    BLOWER COVER THEN UNTHREAD THE BLOWER
    WHEEL FROM THE MOTOR SHAFT.
Change belt on dcd5505 danby dryer
Posted on Jul 03, 2008
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
Jan 01, 2016 | Hotpoint Dryers
How to replace the belt
Try this link Dryer belt replacement video or if your lint filter is in the door try this link Dryer belt replacement video
Nov 01, 2010 | Kenmore 73952 Gas Dryer
Dryer heats up and then cools down after a few minutes. I checked and cleaned lint and re-started and the dryer shut off and beeped 3 times.
its the "over heat warning alarm" check both the inlet vents and the out let vents they must be free of obstruction's the bryer must be able to breath freely,,,if this dont fix it you will need to change the thermal censor in the dryer
Jul 13, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Can i put both whites and colours in a tumble bryer?
Yes, with two caveats. 1) If you put in a dyed fabric that is leaching dye you might get stains on the whites. Anything that has been washed more than three times before should be safe enough. 2) You may end up with some dark lint on your white clothes. You may want to avoid dark clothes that produce a lot of lint, like towels or sweatshirts.
Oct 11, 2009 | Dryers
CANDY TUMBLE BRYER BELT
i changed the belt on my candy civ 100 but it wont turn on yet all the wires seem to be connected and the fuse in the plug is ok
Apr 25, 2009 | Candy Dryers
Dryer runs but wont tumble
Try checking to see if the dryer belt is broken, the dryer belt wraps around the drum and goes to a motor at the bottom of the dryer that turns the drum, if so you can usually get a replacement belt from the maker of your dryer by visiting there website.
Mar 11, 2009 | Danby DCD5505W Electric Dryer
Need Help replacing dryer belt
PUT BELT AROUND DRUM FIRST AND NOW YOU HAVE TO GET TO BACK OF DRYER ,SHOULD HAVE SMALL PANEL AND ISTALL FROM THAT SMALL REAR PANEL NOT EASY
Nov 29, 2008 | Dryers
Please CLICK HERE this will fix your problem.All the instructions are given step by step with the diagrams.
Jul 03, 2008 | Danby DCD5505W Electric Dryer
Broken belt
Hi , in replacing belt try to trace where belt way to go outside remove some bolts be sure unplug power , in putting back belt is the same way go in to install belt.
Feb 21, 2008 | GE DCSR483EA Electric Dryer
Danby DCD5505W Electric Dryer Logo
349 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
