https://www.amazon.com > Video-Projector-Remote-Co...
Tekswamp remote features comfortable, easy to reach buttons in a compact, rectangular body, convenient for everyday use and transportation.
Compatible Devices: Video Projector
Batteries: ‎2 AAA batteries required
Brand: Tekswamp
Number of Batteries: 2 AAA batteries required
Rating: 1 · ‎1 review · ‎US$19.99 · ‎In stock
Have you tried changing the power cord? Has it been damaged or fried?Has the internal onboard fuse blown?check the lamp and dust filter and that everything looks how it should and clean and normal.
If your Remote desn't work then first check your battery and then try it again. After trying again if same thing happen then changes it and place new battery.
When you connect a source to the projector, the unit will match the resolution input to it. As long as you don't exceed the max resolution, which is considerable, the unit will display it. Go into the menu and select auto-image to have the projector give you the best quality image. Hope I helped you!---Rick
That S-video cable...if it is longer than 1 meter you will get a poor picture. Get an component cable and connect your players thru that, that will improve thepicture 1000 times, belive me
This is the connectors back on your Acer
1 x RGB D-Sub 15pin 1 x Composite 1 x S-Video 1 x Component
And the component connector is way the best of them, its better that all of the together..if i may say so
l6. After you install a new lamp, select the lamp Usage icon and press and hold
the "Power On" button on the remote control for ten seconds to reset the
lamp time clock to zero.
NOTE: If resetting the lamp clock back to zero after 2100 hours of service,
press the "Power Off" (not "Power On") button on the remote control for ten
seconds
I have the same projector and after I thought it is faulty, I finally solved the problem by putting a signal on the input. With out the signal the unit will only switch the bulb on and the menu wont be available.
Hope this help
