Squeaky Washer We bought a MaYtag washer Dec. 07. The machine squeaks in the wash cycle. What can we do?
    President:
  • Washing Mach... Master
  • 2,651 Answers
You can call a repair guy, you should have a 1 yr warr. no?
Posted on Mar 18, 2008
  • Ron Coons
    Ron Coons Mar 18, 2008
    didnt mean to be cynical but why should you worry about trying to figure out
SOURCE:
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
LG front loader washer squeaks when drum is rotated manually
Possibly front boot seal give it a spry with sillicon spray.
Apr 27, 2014 | LG WM1814CW Front Load Washer
Kenmore 970-C42062-00 washer drum squeaky and bangs
The bearing may be shot. A common problem with front loaders. At 10 years of age, the machine has replacement in its future.
Apr 27, 2017 | Kenmore Front Load Washer
I have a brand new Maytag Bravos MCT top loaded washer. It makes a squeaky noise when agitator is cleaning. The squeak is getting louder and I've probably only used the washer a dozen times. We checked...
I had this one come up on a washer I had professionally installed for a client. When I looked into it I found there were shipping blocks made of squeaky Styrofoam the installers left in place. Only made the noise when it was full of water and working hard shifting back and forth in agitation. It said right in installation instructions to take the shipping blocks out too.
Feb 20, 2011 | Maytag Dependable Clean Top MAV5920EWW Top...
MAV-3 top load washer makes loud squeaky noise during the wash cycle.
Is it a constant squeak or does it go squeak-squeak - squeak as it agitates? It is a squeak that is intermittant then usually your brake is losing its hold. You will need a technician to do this job. It requires special tools that they should have. I repeat a technician should do this job. You can seriously hurt yourself attempting this repair. Also see if the inner tup is turning as it agitates, if it is then it i definately the brake. But one more time do not try this repair it is a dangerous repair that should be left to technicians. There is a spring that is under heavy compression that requires a tool to release it.
Dec 28, 2010 | Maytag MAV6200 Top Load Washer
Maytag washer squeaks when spin cycle stops
We have a Maytag Performa G3300 that we bought on 8/13/2001. It still works great, but on 2/25/10 it stopped heating. We found that by removing the front panel and vacuuming the accumulated lint on the inside of the dryer and the door, the problem was resolved. There were no parts to replace, just vacuuming.
Jan 18, 2010 | Maytag Performa PAV2200
The squeaking noise is when the washer is spinng like a squeaky belt
no belts in a washer just a tramsmision it could be going out
Dec 13, 2009 | Maytag MAV3855A Top Load Washer
Maytag legacy series washer top load-squeaky during wash and rinse
very possible if squeaks in agitation top springs that hold tub needs greased under spring & plastic shield under spring. had same problem on big front loaders whirlpool
Aug 31, 2008 | Maytag MAH2400A Front Load Washer
We bought a Maytag Washer Dec. 07. The machine started to squeak shortly after the purchase. I was hoping it will go away, but it is not. Each time I use the washer we can hear the squeak through the whole...
The brake pad is squeaking in the brake drum. Like when the brakes on your car get glazed. It's annoying, but it won't affect the operation. Call the store where you purchased it and set up service to have it repaired. If the tech they send doesn't have a brake tool, or seems clueless, have them send a different tech. Be sure they replace the parts - not just scuff up the pads and drum already in there - Maytag's buying!
Unfortunately, there's no guarantee this will permanently take care of the situation. I have noticed that doing larger loads actually helps condition the brake seating surfaces when the parts are new.
Mar 12, 2008 | Washing Machines
Squeaky Washing Machine
There are many possibilities but a common one is a worn out idler wheel. 6b657f1.jpg
Jan 11, 2008 | Star Speed Queen AWS53NW 26" Top-Load...
Washing Machines Logo
126 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
