Question about Sony KP-51WS520 51" Rear Projection HDTV-Ready Television
Sony KP-51WS520 51" Rear Projection Colors have been over saturated for awhile...selecting vivid seemed to help. But now I am getting a ghosting effect on most words, always to the right.If I go to convergence, colors are lined up but ghosting is still there. I have a service manual. I'm a 25 year copy machine tech that doesn't mind digging in but not familiar with Rear projection TV's. Any ideas or info is greatly appreciated.
  • Sony Master
  • 3,459 Answers
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,PioneerSony KP-51WS520 51 - 2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2010
SOURCE:
Sony kp 51ws510 rear projection has blue ghosting lines
Have you tried calibrating the colour guns , as this usualy cures the ghosting
Aug 04, 2012 | Sony KP-51WS510 51" Rear Projection...
The picture is blurry or you can see the outlines or ghosting of the 3 colors
Convergence circuit failure. The Sony type 1 convergence repair kit is the correct kit for your model and symptom. Its available from www.tvrepairworld.com and includes the parts and the CD with repair instructions.
Oct 21, 2010 | Sony KP-51HW40 51" Rear Projection...
My sony KP-51WS500 is having ghosting problems with kind of 3D image with the three colors showing seperate image lines. How do I fix this and what is the cost.
Shop cost u about $300.Ur convergence is dead,U know how to solders.?Buy a convergence kit to repair.Tries websites. Tv repair World.com,Tv repair Kits.
Dec 12, 2009 | Sony KP-51WS500 51" Rear Projection...
Colors seperate and picture bent
THIS is a convergens problum .pls. prees menu key and see convergence menu select and see cross line on center the screen select one by one colour line to meching and cross line is white see the pictur is ok.
Oct 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My colors wont stay converged
put a convergence repair kit in the set that will usually repair the Issue. You can get the Sony convergence repair kit which works with your model at the following link. The kits contain the replacement parts and complete instructions www.tvrepairkits.net
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
Sony kp-57wv600
hola al problema lo debes tener en los transistores de color que estan en en la plaqueta donde va el socalo debes tener alguno desoldado
Sep 24, 2008 | Sony KP-57WV600 57" Rear Projection...
GHOST IMAGE ON KP-43T90
this problem is caused by the pal 50 - 60 meg problem, the sony runs at 50 megs, if you have a 60 input from an hdmi lead you will get ghosting
Mar 05, 2008 | Sony KP-43T90 43" Rear Projection...
Convergence and picture problem.
convergence ic's
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Jan 07, 2008 | Sony KP-57WV600 57" Rear Projection...
Sony KP-51WS520 51" Rear Projection HDTV-Ready Television Logo
244 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
