Question about Sony STR-DE545 Receiver
Sony str-de-545 5.1 channel
Replacing subwoofer input jack on receiver. is it hard?
  • 1,512 Answers
Hi there, Is the socket actually broken, or is it just playing up. It may just need some dry solder joints reflowed to fix it. If you are lucky, this may be done without a full strip down.
If you need to replace it, you will have to pull the board out of the unit, or at least the back panel completely off to get access to the soldering of the socket to replace it. This is not a difficult job, but often requires almost complete disassembly of the amp to do so. Time consuming...yes. It is something that unless you have some confidence at dismantling and reassembly gear, I would suggest that you refer it to a repair man. Good luck, I am happy to answer any more questions you may have.
regards
Graeme
Posted on Mar 18, 2008
SOURCE:
The 1/4" headphone jack broke on my Sony STR-DE 485 receiver. How do I replace it and what it the part number?
1-683-763-11 is the p/n for the headphone board. Should be easy to replace. Just unplug the old one, take take the screws out, and put the new one in.
Mar 30, 2013 | Sony STR-DE485 Receiver
I have a sony str de 325 receiver....what sub woofer will go with it and where do you plug it into the receiver?? Thanks
You will need a powered sub, one that has a built in amp. It will also need speaker terminal type inputs. Use the B channel to send signal to the woofer. Since the audio from the B channel is full range, use the crossover on the sub to determine which frequencies you want to hear. I would start at 100Hz and go up and down from there. Use the gain to adjust the volume in relation to the other speakers. The sub volume will be affected by the master volume.
Please rate if this helpful
Apr 05, 2011 | Sony STR-DE325 Receiver
How can I use digital media port adapter TDM-iP50 with an older Sony STR DE 425 receiver's RCA inputs? Is there a conversion cable--dm port to RCA?
The dm port Can't you just pull the audio from the iPod from its analog headphone jack with an adapter? They're common and cheap.
Dec 29, 2010 | Sony STR-DE425 Receiver
Can I connect a active subwoofer to my SONY STR-DE597 Powerful 6.1 channel AV Receiver
Yes, it only supports an Active Subwoofer. That's what the Sub Pre-Out is for.
Your sub will take that input, possibly split to two RCA connectors, and its internal amplifier will do the rest. Its own manual will give the specifics.
Feb 07, 2010 | Sony STR-DE597 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
5.1 Surround sound not working
Maybe the surround processor is having a bad day... My kenwood would do similar and a reset was necessary to correct. Have you tried resetting the system? On my Sony STR DE 597 this is accomplished by powering off. Then while holding the 2 channel button down (front face plate) power on. A reset message is displayed. Your model may be similar but check your manual or download the PDF of the manual from Sony's support website. Hope this helps
Sep 05, 2009 | Sony STR-DE685 Receiver
Sony-DG820 Subwoofer
The powered subwoofer should be connected to the black subwoofer output near the bottom of the receiver in just about the center. A subwoofer uses line level signals and has its own amplifier, Good chance that you wiped out a channel. Put the wiring back the way it was, and IF the channel was not directly connected to the speaker terminals, MAYBE, JUST MAYBE it will still work.
Chances are slim...
Apr 27, 2017 | Sony STR-DG820 Receiver
No voice audio
Have you selected coax mode with the input button?. If so you may need to play around with the setup buttons. Can't give anymore advice as I've lost my manual. Good luck
Dec 26, 2008 | Sony STR-DE585 Receiver
Sony str-de-545 a/v receiver
Just answered that question for you in another post, but here it is again in case you miss it.
regards
Graeme
Mar 18, 2008 | Sony STR-DE545 Receiver
Sony STR-DE545 Receiver Logo
225 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
