Question about Janome 4623 Mechanical Sewing Machine
Singer 404 sewing machine
I purchased a used singer 404 and am trying to get it working for my wife. I put new thread in the bobin and have everything threaded correctly but when I try to sew something, the stitches don't lock or sometimes it will work for a few stitches and then not work. Help would be appreciated.
MIke
I would first make sure the thread tension is adjusted properly. if this does not fix your issue, check the point on the shuttle hook and make sure it is not broken off. it should come to a needle sharp point. if the tip is broken off it may not pick up the thread from the needle properly. then double check the timing and the needle shaft depth. first, make sure your needle is fully seated and tightened down. the groove in the needle should face forward. there are two timing marks on the needle shaft. at maximum depth you should see both lines and the top line should be right at the bottom of the needle shaft bushing. then as the shaft goes back up, when the bottom line is at the bottom of the bushing the point of the shuttle hook should be right behind the needle and centered in the indentation on the back of the needle. you may need to make minor adjustments on the needle shaft depth depending on what brand and type of needles you are using.
Posted on Jul 07, 2010
  • stitch1775 Jul 07, 2010
    I believe this applies to all slant-o-matic machines. good luck and let me know how it works out.
    Stitch
    Marine Riders of Las Vegas
Top thrd snags on bobin aftr 14or15 stitches. Chnged thread, needle and bbin. Tug'd on thrd while threading, not tension.Just srvced but set a month before I sewed on it.Singer 600 Touch n Sew Slant.
Try a brand new needle. If it is still malfunctioning, most like it is out of time. You can search the internet for sewing machine timing or take it back for service.
Dec 06, 2016 | Singer Sewing Machines
How do I thread a Singer Craftmate 17C
according to the singer website your sewing machine is suppose
to use the manual for a 5817 sewing machine,,the manual is free
just click on the link
http://www.singerco.com/uploads/download/118_356508008.pdf
Nov 15, 2012 | Sewing Machines
I took out the bobin case and now when I put it back in it wont stay. The thread bunches up or the bobin case comes out of place. Any idea on how to get it to stay put?
The manual usually shows a pretty good diagram of how it should be, it snaps in place. Call singer at 1-800-4singer. Or go online at singerco.com and download a manual for free,
Sep 09, 2010 | Singer 5050 Mechanical Sewing Machine
Thread bunches from the bottom while sewing.
Hello, sewing is a part of my income and I've encountered this problem before and managed to fix it on my own, by trying out these different things. I re-threaded the machine and checked to make sure that the tension is not too loose. Check the bobin and the sack the bobin fits into, sometimes it comes loose too, click it back into place and re-do the bobin. adjust the tightness of the stiitches, I usually put it on 2 .5 - 3. Hope this helps. Good luck to all. Nefishakh@hotmail.com
Nov 16, 2008 | Singer 5050 Mechanical Sewing Machine
Singer 404-
Here's a manual for it on this site. www.ismacs.net/singer_sewing_machine_company/manuals/singer-404-singer-slant-o-matic-sewing-mac
blog.sew-classic.com/2008/10/25/singer-401-401a-403--403a--404--sewing-machine
These two sites may be of some help.
Cheryl
401A Singer
Sep 16, 2008 | Singer 7462 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
MY machine has never worked perfet liked I hoped it would. When I embroider the top thread ends up all lose and
This could be caused by many things but I would suggest that you take the machine to your local dealer for them to have a look at as the bobbin case may be the problem and they may have to replace it. If you look at the bobbin case it should be smooth all the way around - if there's rough edges then that could cause a problem. Also if the bobbin case jumps out of the socket then this is a good indication that you need to have it replaced.
Apr 26, 2008 | Singer CE-200 Quantum Futura Computerized...
I can't find my manual and cn not get the bobbin to thread correctly
you need to insert the bobbin so that when the thread pulls off it spins counter clockwise. on the side closest to you there is a notch that you slip the thread into and then pull along the side towards the back of the machine staying on the left. once you've done that you can manually turn the knob on the side to make the needle cycle down so that the upper thread will pull up the bobbin thread.
Nov 25, 2007 | Singer 6038 Mechanical Sewing Machine
Janome 4623 Mechanical Sewing Machine Logo
712 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
