A/c problems trouble shooting
If you dont change the filter on the a c unit for 6 months will it cause a leak or just freeze up?
    Master:
  • 518 Answers
Depends on how often it runs. Ice formation due to lack of air flow can certainly cause damage and cause a leak.
Geno
Posted on Mar 18, 2008
SOURCE:
Goodman/Amana air handler freezing up and not cooling home. What could be causing it?
There are two things that cause freeze up's...
Low air flow...
Low freon...
First check the filters, the blower , and the air vents to make sure that the air handler unit can move enough air...not enough air across the coil, the coil gets too cold, ice forms....
The low freon problem will require professional assistance...
For the system to be low there needs to be a leak...the leak must be found and repaired or the fix will only be temporary...
To do this the system refrigerant must be recovered, the leak fixed and then the system vacuumed and recharged...
One other thing....outdoor air temperatures under say 65 F can also cause freezing.... but I am assuming that you are above that if you are running your A/C system.
AirConditioner Trouble - Review the Possibilities
heatman101
May 25, 2011 | Amana Heating & Cooling
My AC unit leaks an inordinate amount of water into the apartment. Most of the times it happens when the humidity is high. I have to put rags inder the unit to absorb the water & change the rag after...
Check your air filter, the unit may be freezing up because of not getting enough air...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 06, 2010 | Emerson Quiet Kool 10NW16K Air Conditioner
My ac unit keeps freezing up on the pipes and keeps leaking water everywhere. what could it be the problem.
If you own indoor pets you will want to change the return air filters monthly like religously. You may also need to have the A-Coil other wise none as the evaporator coil cleaned manually. It is located inside the air handling unit inside the house somewhere. It could be restricting the air flow across the coil with daner and dust and/or deris. Sometimes it can be difficult to clean but with care and lots of elbow grease it can usually be done. Be careful not to bend the fins! Once this is completed and the unit still freezes up! Then you can be sure it is low on refrigerant 90% of the time! Cleaning the A-Coils is something you should do or have done anually!
Aug 06, 2010 | Goodman CLQ36AR49 Air Conditioner
Had a gas line leak. I had it fixed. Also exhaust problem, can be fixed in 6 months. Great car, 253,000 miles on it. Never had a tuneup in 5 yrs, runs like a top.
at least change your air filter , which is important , spark plugs check , oil and filter is normal , check your belts , timing belt too need to check too .Do not want that break down and then have to repair it , it will cost more
Aug 02, 2010 | 1991 Honda Accord
Coil freezes over.i un plugged the freeze control because the ac kept shutting down befor it cooled down.
That should only be a temporary fix...if you let it like that the coil could freeze completely over causing major water damage...
The most likely causes are a plugged air filter or an under charged condition...the under charge is a sympton of a refrigerant leak...just adding refrigerant sill only solve the problem for a short time...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 25, 2010 | Fedders X Chassis A6X06F2A Air Conditioner
WHY IS THE AIR CONDITON FREEZING ON THE INSIDE AND OUTSIDE
Usually that means that the unit is low in charge but other things like a plugged filter, bad blower, or orfice, exspansion valve problems can also cause that...
heatman101
Jul 21, 2010 | Weather King 10AJA4801AH Air Conditioner
Haier ac unit keeps freezing in the front where the filter i located how do i prevent this
Freezing is a bad sign... but dont give up yet...
these are the signs that will cause freeze up...
dirty filter
t'sat not shuting off
cooling a room too big for the unit
settings at max but room is still hot
and the worst case... a/c leaking freon..
the leaking part is bad cause if you get someone to put it back in next year (or sooner) you have to call em back to recharge it again...
if everything checks out then it is the leaking freon... throw away...
what you pay $100 or so???
hope this was helpful
Apr 05, 2010 | Haier Mechanical Air Conditioner HWF05XC7
GE Profile Refrigerator leaks
How long have the filter been inside the refrigerator, if 3-6 months that is usually the life of the filter and it is time for replacing, it is common for the filter to leak once it has reach it life expectency
Dec 13, 2009 | GE Profile PSW26P Stainless Steel Side by...
After changing coil on a/c unit, it still has a leak!
a leak, other then in the a-c itself, should have been found when a vacuum was pulled on the system before it was recharged, also the dryer should have been replaced at this time, since the system was open.
Aug 03, 2009 | Heating & Cooling
Freezer not freezing
what yo9u need to look at is the defrost relat thats is on te control board in the back of the refrigerato and make sure that its soldered on real good, also when you turn the uit on and off soes the controll display anything, thats how to trouble shoot the unit
Mar 11, 2009 | Samsung RS2534 Side by Side Refrigerator
Heating & Cooling Logo
176 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
