Question about Edirol PCR-30 EDRPCR30 Keyboard
Replacing Key Contacts
My Edirol Keyboard was purchased recently and when it was setup only a few of the keys worked - i was told it was a problem with the key contacts and if i replaced them it should work fine. I have been sent the key contacts but could you please explain how to replace the existing ones correctly?
Thanks
  • 1 more comment
  • Anonymous Jul 06, 2008
    Since a few weeks some keys are malfunctioning when hitting on full velocity. Is this a softwarething or a hardware damage thing ??
  • klitwestwood Dec 10, 2008
    used mine 3 times then stored it for 6 months.15 keys now not working.is there a brand name for this graphite stuff plzz or maybe a link.cant seem to find it.
    steve
  • C?simo Alba
    C?simo Alba Apr 06, 2009
    Thanks a lot Theisovian. Followed your instructions and fixed my PCR-80 using graphite powder. It works perfectly now! :)))
I have a PCR-30 here that has developed several dead keys over the years.  I took the thing apart to clean the contacts and see if I could improve things -- unfortunately, it had the opposite effect, and I was left with only a few keys that *did* work.
I have since found a solution though, and now have a fully-functioning keyboard once again!
You'll need a tube of pure, dry graphite powder (only a couple of bucks from your local auto-supply shop), a tiny craft paintbrush, and a willingness to take your toy apart :)
Open the PCR up, and remove the springs holding the keys on.  I used a slotted screwdriver to jam into each spring, and lift it off the hooks.  I'd suggest keeping the keys in order to make it easier to put back together.
Now pull off the grey rubber contact sheets.  Clean out any dust that's under there, but don't be too abrasive or use chemicals.  We want to keep the existing contact material intact.
Put a little graphite powder in a small dish.  You won't need much.  It may seem a little clumpy, but it's actually extremely fine.  So fine, in fact, that if you smear it on your fingers it feels greasy, despite being completely dry.
Dab your brush in there to break it up, and get the brush well-impregnated.  Paint some powder on each of the contact surfaces both on the board side, and on the back of the grey rubber sheet.  Be careful not to connect the spaces between the contacts on the board... graphite is highly conductive, and you don't want an always-on key.
As you smear each contact with graphite, you'll notice it become a little shinier if you look at an angle.  You'll also get powder spattered around places, but don't worry.  Just blow off the excess.
Once you've done all of the contacts, place the rubber sheets back on (this can be kind of a pain, getting all the pegs back in the holes.  Hook it up and give it a test (just use your fingers to push the rubber pads), and repeat the process for any keys that still aren't working.
Once they're all back to 100%, replace the keys and reassemble.  You're good to go!
-Ben
Posted on Jul 27, 2008
Alternative solution DYI for Edirol PCR-50
Theisovian
had suggested using powdered graphite, but I just took an ordinary pencil and carefully coated the contacts.
Fixed the problem.
FYI pencil 'lead' is actually made of graphite.
Posted on Jun 27, 2010
Solution 3
I contacted Roland in the UK to see if they'd fix my PCR-50 which was displaying the same symptoms. They said they wouldn't repair it but would send me the replacement key contact parts. These cost around £12 and are replaceable without technical knowledge just a bit of time and patience as it involves removing each key and spring one by one.
All in all it took me about an hour to do this with my dad helping me and now my keyboard works again. You need to unscrew the top of the keyboard, unscrew the keyboard itself from the frame and then remove the springs and keys. Once they're all off (and laid out in order so you can put it back together) you just peel off the old rubber key contact sheets and push the new ones in to the holes (there are specific rubber lugs to go in here). Then the keys go back on the way you took them off (I found it easier to do the black ones first and the whites afterwards).
I'm happy not to have to spend another £100 or so on a new keyboard.
Posted on Mar 22, 2009
Im having the same type of issues.. though a little different, I'm running the keyboard through USB only. All of the controllers work just fine.. though non of the keys work... is that to be expected? excuse my lack of knowledge, but it never hurts to ask...
Thank you for any information. I greatly appreciate it =P
Posted on Jun 27, 2009
Contact Roland (323) 890-3700
They know they have a problem and will fix for free (you pay shipping to them) by replacing the keyboard assmbly. According to them... this new KB assbly will not create the same problem
Posted on Feb 17, 2009
I contacted ROLAND in Belgium. Be polite, short and consise so you don't waste their time. I hoped they had a fixed procedure for this on their site however marketing folks would have that easy solving solution blocked in no time ... typical ...
Posted on Mar 27, 2009
SOURCE:
Windows 7 64 can not install the driver
Windows 7 64Bit requires signed drivers. Try looking on vendor's website otherwise I am afraid you need to either get a new controller or disable this requirement (not supported by MS)
Jun 07, 2012 | Edirol PCR-M30 32 key USB MIDI Keyboard...
My pc is showing "Setup Entry Key Detected" and its not starting when restarted and just showing the bios settings screen. Please help me out for this problem.
Setup entry key could be "DEL / F2 / Enter" depending on BIOS manufacturer. So, the key might have pressed/stuck/short circuited in keyboard. You can try plugging off the keyboard for the start. Some BIOS need keyboard to boot. Anyway, if you're not seeing the BIOS Config after plugging out keyboard, the keyboard key is the problem here. Try swapping with another one or hit those keys for few times. Good luck.
Aug 27, 2010 | Computers & Internet
Edirol PCR-50 wont output any data for most keyboard keys
Yes people it can be fixed by yourself at home, cheaply and easily. I’ve got an Edirol pcr-80 & prc-a30. Both have had intermittent key troubles and keys that just don’t work anymore or low/high level compared to other keys. These problems seem to start after a year or so. I’ve paid hundreds of dollars getting them fixed until I tried this on a whim. The contacts under the keys are a carbon-based contact so cleaning them with metho/alcohol just dries out this carbon. Some people say cleaning them with a pencil easier helps and it can do slightly but not properly. What you need is “Graphite Powder”. (Link for a picture of a appropriate product – just cut and paste it in your Internet heading bar, or Google image search graphite powder…)
http://images.google.com.au/images?hl=en&source=imghp&biw=1024&bih=1080&q=graphite+powder&gbv=2&aq=f&aqi=g1&aql=&oq=&gs_rfai=
Graphite powder is a dry fine powder that is conductive and perfect for the job. You can purchase at any locksmith – maybe a good hardware store, and it is sold as “non liquid lubricant for locks and machinery.”
All you need to do is unscrew the case, remove the springs that hold the keys in, remove the keys. (White keys first then black keys. Keep in order.) Peel off the rubber strip under the keys and turn over so you can see the little carbon nipples that touch the circuit board. (2 for each key) Pour a little power out on a sheet of paper and use a cotton tip bud to apply a little powder to these. Now apply a little to the carbon contacts on the circuit board where the little nipples touch. Do all this with your midi keyboard plugged in to your computer/synth etc so you can hear how you’re going with getting contact before you put it all back together. You might get a key or two going off when doing this because the graphite power is making a continuous contact across the circuit board. Just blow/lightly wipe away excess to stop this but you want to leave all the contact points evenly (if slightly) coated. Try touching the rubber strip contacts with the circuit board contacts to see if you can get a sound. This can be a bit tricky to line up and get an even contact. This sorts its self out when everything is back together.
Now put back the rubber strip. I used I tiny screwdriver to help push the rubber guide back in the holes on the circuit board. Now put the keys back (black first – with the short springs then white keys with the longer springs) screw the case back together and let me know how you went.
This I think will dry up again in time but if you get a good bit of use out of it you can just do it again… For free…
Garthy.
May 29, 2010 | Edirol PCR-50 Keyboard
Edirol Midi Keyboard Controller PC-50 Many notes no longer sounding. Can't get into keyboard to check contacts
Well, you have to get into the keyboard. There will be screws or latches that hold the case together.
SOMETIMES screws are hidden beneath stuck on rubber feet.
SOMETIMES plastic latches are where there are slots... have to be careful as they can break if you don't open them right.
WORST are latches along the sides that you have to pry open... knowing where they are is key.
You will probably find that the keys consist of conductive rubber "pills" that are in silicone rubber domes that the keys press against finger-like circuit traces on a board under the keys.
Clean BOTH the pills and the traces with 99% isoprophyl alcohol and a Q-tip.
Dec 11, 2009 | Music
Question about liquid damaged dell inspiron 1545 keyboard
Just buy a new keyboard, should take care of the problem. You can buy a new key board on ebay for $10-13$. If you have any questions regarding keyboard installation, let me know. I can help.
Oct 01, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
The i key won't work
Faulty keys on keyboards are very difficult to fix, usually you need to replace the keyboard.
You can try removing the key and if you can get to the rubber membrane switch you may be able to use a cotton bud with electronic cleaning fluid cleaner on the contacts. Replacing the key could be difficult with the small plastic hinge components.
If you are lucky place the key over the plastic hinge and pressing down till it clicks into place.
If it works you are in luck, if you are unlucky it may not work at all, then you need to buy a replacement keyboard or use a USB keyboard with your laptop.
Jun 28, 2009 | Sony VAIO PCG-K25 Notebook
Toshiba Satellite: Keyboard quits working after a while
How about replacing the keyboard? Perhaps, something was spilled on the keyboard in the past.
May 07, 2009 | Toshiba Satellite M45-S265 Notebook
Notes don't stop even after I release the key
The keyboard  is not sending a note off instruction after the key is released. Try checking midi preferences in reason.If your using a Mac check that the edirol is present by launching Audio MIDI Setup utility located in the utilities folder. You can download the latest Mac driver from Roland below: EDIROL PCR-300 32-key MIDI Keyboard Controller :: Download
Jan 18, 2009 | Propellerhead Reason 4.0 - Windows and Mac...
The Print key is not working
it depends what system you are running cetain programs and windows operating systems dont accept this shortcut
try going into controll panel clik keyboard and make sure hot keys are on
the only other reason is if you have eny other wireless functions running these can disrupt the signal from the keyboard to the computer turn off all wireless items and try agen
if none of these work try replacing the keyboard as it should work as long as hotkeys are on and the operating system you have accepts this function
Oct 18, 2007 | Microsoft Wireless Optical Desktop Pro...
Edirol PCR-30 EDRPCR30 Keyboard Logo
5,412 people viewed this question
Top Edirol Computers & Internet Experts
Ben Armstrong
Steve Allison
Steve Allison
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
