Question about Creative Labs Zen Micro MP3 Player
Recovery problem how do you get out of recovery mode
  • tyson12355 Mar 18, 2008
    tyegtfhuyvjuytmtuk
My player is creative zen(v) I am unable to connect and unable to charge it to play
Posted on Mar 27, 2011
    President:
  • 4,402 Answers
Stuck in recovery mode Zen v
Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All)
Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware
Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
I actually had this exact problem a little while ago with my Zen Sleek-- Booting straight to the Recovery menu, and only getting a generic "Harddisk problem" error screen any time I would try to do anything.
I decided to open it up to check out the hard drive to see what kind I would need so I could try replacing it. The data plug that attaches to the hard drive itself was partially unplugged. So, I pushed it back in all the way, put it all back together again, and turned it on just to see if something different might happen. (I had it set in my mind that the hard drive failed and I would need a new one, so I didn't expect anything different to happen) And to my surprise, it worked just like new again.
Before you go off and invest in a new hard drive, I suggest opening it up and make sure that plug is in all the way. Since you'll be opening it up in any case, it wouldn't hurt.
Posted on Mar 20, 2008
4 Suggested Answers
  • 19 Answers
SOURCE: Creative Zen Touch stuck in "recovery mode"
for anyone else who still have unusable devices and the device is not there for the firmware but it is for anything else do this:
1. Plug in the player.
2. Goto device manager remove it's drivers and remove USB Roots (dont worry they'll all reload)
3. Reboot and unplug the player.
4. After windows loads goto add/remove programs and uninstall windows media player. Select downgrade.
5. If it asks you to reboot do so.
6. Then locate c:\program files\creative and just manually delete the folder you can put it back on if you wish later but it's useless and outdated junk.
Now reboot. Plug the device in and install the firmware.
If this works as good for me as anyone else lemme know.
Dan
Posted on Mar 13, 2008
SOURCE: recovery mode
it still wont work i dont no what to do and i need my mp3 player
Posted on Jun 26, 2008
  • 9 Answers
SOURCE: Getting out of recovery mode
I have the sleek photo and mine bugged out yesterday. It would go to the splash screen and then go blank and just sit there. Nothing would respond. I tried reset, reboot and other things too. My pc also would not recognize the player. To make a long story short, I tried other suggestions I found on the web. They didn't work and my player would now only go to a garbled splash screen and go right to the recovery screen.
I had the new firmware, but I couldn't use it because the pc wouldn't detect the goofy player. Then I ran across a site that mentioned that Windows Media Player can cause player recognition problems. I removed both WMP (mine was 11) and WMP runtime using the add/remove programs option on the control panel. I restarted the pc and BAM! the player was now recognized. I ran the new firmware application and the player works fine now. The key for me was getting rid of WMP and the WMP runtime.
Posted on Aug 19, 2008
Iphone logo moves back and forth, cannot get to Itunes
Try putting your iPhone in recovery mode.
follow the link to see all the information you need.
Succes! How to Put iPhone into Recovery Mode
Oct 08, 2014 | Apple iPhone 3GS Black (16 GB)
Iphone stuck on itunes recovery mode
Your device stucks in DFU mode, you can try some 3rd party ios data recovery tool to exit recovery mode. Follow this guide to have a try DFU Mode How to Enter and Exit DFU Mode of Your iOS Device
Aug 12, 2014 | Apple iPhone 3G
Macbook Air trackpad moving by itself
Boot the computer into recovery mode and see if the track pad is still moving around by itself.
Hold down the OPTION key when turning on the computer, and select the Recovery icon to boot into recovery mode.
Here is a link that will guide you throw it in detail How to Boot Into Lions Recovery Mode
The purpose of booting into recovery mode is to see if the track pad is still acting up. If the track pad is operating normal in recovery mode, then it might indicate an issue with your operating system. If the trackpad is still having issues in recovery mode, it would indicate that your trackpad issue is a hardware issue and it will require you to take it into Apple for further diagnosis.
Hope this helps!
Feb 13, 2014 | Apple MacBook Air
Phone 4s will not shut off, keeps rebooting
You will want to try to put the device into recovery mode and perform a restore. You can follow Apple troubleshooting article HT1808 to walk you through putting the device into recovery mode. NOTE: Check for any backups before you put device into recovery mode as you will not be able to backup once it is in recovery mode. If the device has been jailbroken and recovery mode does not fix the issue the hardware has been damaged by corruption and should be replaced.
Aug 11, 2013 | Apple iPhone 4S
Recovery mode with out using the power button
An iPod Touch's "Recovery Mode" is for alleviating major operating system issues.
Recovery Mode rolls back your iPod's operating system, stripping problematic updates and downloads from the unit.
The goal of this total system recovery is to revert the iPod to a stable, usable version.
Before you use Recovery Mode, exhaust other troubleshooting methods.
In some cases, Recovery Mode is triggered automatically after a failed system update or system restore.
When it goes into Recovery Mode automatically, you cannot use your iPod until you complete the recovery process.
You can get your iPod Touch out of Recovery Mode using Apple's free iTunes software.
Turn on your computer and open iTunes.
If you are prompted to download any new iTunes updates, install the updates before proceeding.
Plug an iPod USB cable into your computer.
Do not plug the other end into your iPod Touch yet.
Turn off your iPod Touch. If the iPod Touch is already shut down, skip this step.
Press and hold the Home button on your iPod Touch, and plug the other end of the USB cable into your iPod Touch.
Release the Home button after you see a white USB icon and the iTunes logo appear on your iPod Touch's screen.
At this time, a pop-up should appear on your computer screen, explaining that the software has detected an iPod in Recovery Mode.
Click "OK."
Click on the iPod Touch from underneath the "Devices" heading on the left-hand side of your screen.
Click on the "Home" tab, and then click "Restore."
Once it's restored, your iPod Touch goes out of Recovery Mode and you can start using it again.
The restoration process takes a few minutes.
Do not disconnect your iPod Touch until a prompt appears, letting you know the system restored successfully.
iOS: Unable to update or restore
http://support.apple.com/kb/HT1808
Jul 31, 2013 | Apple iPod touch
How do i get to recovery mode
Apart from the messy key combination, you can enter into recovery mode with help of android app onto your device. Just download "Quick boot" from Google play store and install it.
Open the downloaded app, you will see 4 options, Reboot, Recovery, Boot-loader, and Power Off. Just tap Recovery and your device will reboot in recovery mode automatically.
Apr 23, 2013 | Computers & Internet
Iphone 4 restrictions passcode recovery
Entering iPhone Recovery mode to bypass the passcode. The ever best and easiest way to enter and exit iPhone recovery mode is to use Tenorshare ReiBoot. It is free tool to put your iPhone into or out of recovery mode with one click.
Mar 30, 2013 | Cell Phones
Help please tell how to exit recovery mode
How to Fix an iPod Touch Stuck in Recovery Mode With a Free Program
An iPod Touch's "Recovery Mode" is for alleviating major operating system issues. Recovery Mode rolls back your iPod's operating system, stripping problematic updates and downloads from the unit. The goal of this total system recovery is to revert the iPod to a stable, usable version. Before you use Recovery Mode, exhaust other troubleshooting methods. In some cases, Recovery Mode is triggered automatically after a failed system update or system restore. When it goes into Recovery Mode automatically, you cannot use your iPod until you complete the recovery process. You can get your iPod Touch out of Recovery Mode using Apple's free iTunes software.
Things You'll Need
-Apple iTunes-USB cable
Instructions
1 Turn on your computer and open iTunes. If you are prompted to download any new iTunes updates, install the updates before proceeding.
2 Plug an iPod USB cable into your computer. Do not plug the other end into your iPod Touch yet.
3 Turn off your iPod Touch. If the iPod Touch is already shut down, skip this step.
4 Press and hold the Home button on your iPod Touch, and plug the other end of the USB cable into your iPod Touch.
5 Release the Home button after you see a white USB icon and the iTunes logo appear on your iPod Touch's screen. At this time, a pop-up should appear on your computer screen, explaining that the software has detected an iPod in Recovery Mode.
6 Click "OK."
7 Click on the iPod Touch from underneath the "Devices" heading on the left-hand side of your screen.
8 Click on the "Home" tab, and then click "Restore." Once it's restored, your iPod Touch goes out of Recovery Mode and you can start using it again. The restoration process takes a few minutes. Do not disconnect your iPod Touch until a prompt appears, letting you know the system restored successfully.
Dec 24, 2011 | Apple iPhone Audio Players & Recorders
Recovery mode
plug the player into a computer that has zen software and it should then come back out of recovery mode , try to stop player playing when you are finished with it so it doesnt keep going to recovery mode
Mar 10, 2008 | Creative Labs Zen Micro MP3 Player
Recovery mode
Recovery mode won't help you unless you have the recovery files to go with it. Most likely you will need to re-install the firmware on to the device. Download this "recovery tool" from the SanDisk website and run it with your device connected in recovery mode. Make sure you select "format" when prompted. Tool is here; http://sandisk.com/assets/file/downloads/firmware/e200fw01.00.12.exe Recovery mode - power off device. Slide "hold" switch into hold position. Press and hold "record" button and then connect to PC.(keep record button pressed until after connected to pc) Hope this helps.
Sep 04, 2007 | SanDisk Sansa E280 MP3 Player
Creative Labs Zen Micro MP3 Player Logo
89 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
