Orion subwoofer repair
I have an orion hcca 10d.2 subwoofer, and one of the sets of two ohm voice coils seems to be blown. I am trying to find someone who can fix his sub with the quality parts it was originally built with. The sub looks brand new, and has very little play time on it. Orion wont repair it, and the service department didnt recomend anyone.
  • 2 more comments
  • cdawg619 Mar 18, 2008
    I am in Santa Fe, New Mexico.
  • terryj573 Sep 02, 2008
    orion did send me a repair address
    same problem
    thought orion was GOOD
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    st1\:*{behavior:url(#ieooui) }
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    Tri-State
    Loudspeaker Re-Cone Pittsburgh, PA 724-375-9203 Dennis
    Speaker
    Works Tulsa, OK 800-526-8879 Dave Miller
    Regnar
    Speaker Re-Cone New York, NY 631-289-6559 Joe
    Richard
    So Electronics Phoenix, AZ
    480-452-9736 Richard
    a/d/s/ Repair Center
    for Discontinued Home / Architectural Electronics Only
    (Only repairs Home/ Architectural
    Electronics – NO AUTOMOTIVE)
    Company Name Location Phone Contact
    Cosmophonic
    Sound
    New
    York
    , NY 212-734-0459 Tom
    1622
    First Avenue
    New York, NY 10028
    Please
    note that Directed Electronics does not have any authorized repair centers.
    This information is provided solely as a courtesy. Directed Electronics Inc. is
    not responsible for any claims or other issues arising from transactions
    between the recipients of this referral and the independent repair facilities listed.
    Directed had not researched these facilities in regards to the work or service
    history, Directed advises that the term "buyer beware" be applied
    during transaction.
  • smigletat Feb 19, 2009
    What type of High Temperatures adhesives do I need to use to put all the soft parts together on my Soundstream XXX 15?
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi there, where abouts in the world are you?
  • 1,512 Answers
A good spekaer repair guy could at least pull the cone out of he basket and have a look to see why the voice coil went open circuit. Sometimes they can be repaired. sometimes the entire voice coil can be replaced. Spider wires fatiguing are often the main culprit that make drivers with long extension to fail. Sometimes they are secured to the cone with contact adhesive, that it itself can corrode the braided spider wire causing it to go open.
I am sorry mate, but the only contacts I have in New Mexico that I found through your yellow pages, and because I know little about them, I cannot offer you a reliable refferal. I suggest you go(ring) to a decent proper HiFi store in your area. They will most certainly know of a specialist bloke that can do the work for you.
I know I cannot fix you problem over the internet(if you lived in Brisbane, Australia I would do it personally:)) but a FixYa rating would be great for my time to evaluate your problem and offer advice. Ring around a bit... I am sure you will find someone to repair the original driver. Good luck.
regards
Graeme
Posted on Mar 21, 2008
Your speaker probably has no replacement parts available, Depends on how old it is.Chances are that it was made overseas. The older Orions that were made in the states were repairable.The off shore stuff is not, because there are no parts available. I wish it was as simple as cutting out the cone, but it isn`t. We have to re-use the old cone/surround because there are no new surrounds available with the same dimensions.Chances are the spider is not available either. Add to that fact that if the surround is rubber, not foam, the adhesives cannot be disolved with M.E.K..I`ve been reconing for 25 years, but without parts, we have nothing to rebuild. Sorry. Dave Miller, Speakerworks
Posted on May 09, 2009
SOURCE:
What is the Specs for Digital starsound 12" ssw-f1-1242?
Starsound 12" 2000w Subwoofer
- 700rms
- stamped slim steel basket
- dual 4ohm 2" ASV voice coil
- 40 oz magnet structure
- rubber gasket ring
- silver push terminal
Not that good of quality speakers. You would be lucky if they lasted a couple months pushing 700 watts rms.
Jul 06, 2014 | Orion HCCA 12D Car Speaker
IS ORION HCCAD5000 AMP ENOUGH FOR 2 ORION HCCA10.2!
No. These subs are rated at 1500 RMS each. So you need an amp that will produce at least 3000 watts RMS at 2 ohm load or if you wire each sub to a separate amp down to 1 ohm...then you will need an amp that will produce at least 1500 RMS. Those subs can handle more than they are rated though.
Sep 19, 2012 | Orion HCCA 10.2 Car Subwoofer
I have a orion hcca 12.4, dvc 4 ohm sub, can I put a dvc 2 ohm recone kit on it even though its a 4 ohm dvc sub?
In most cases yes as long as coil and all are the same ive changed my HCCA orions from 2 ohm to 1.
Dec 15, 2011 | Orion Car Audio & Video
I have a 10.2 Orion Hcca subwoofer 4 ohm and wanted to know if I can put each coil to each channel its a Brutus 1200 watt 2 channel amp model 1210d is it safe for my woofer and how much rms wattage I'm...
You would need to know what power your amplifier supplies at 4 ohms. In reality, you would be better off bridging the amplifer and wiring your sub in parallel to a 2 ohm load. This would allow you to pull the most power out of the amplifier. It would be safe to do a voice coil to each channel on a 2 channel amp. However, if you happen to have a 4 voice coil sub and attempted to put two 2 channel amps to it, you would have to make sure your amps are leveled. No easy feat. The variance you could have with that could damage the voice coils. But luckily, that's not your case.
Sep 09, 2011 | Orion HCCA 10.2 Car Subwoofer
Specs for orion 12" hcca
* Sensitivity: 84 dB
* RMS Power Range : 2000 Watts
* Peak Power Handling: 4000 Watts
* Impedance: 2 Ohm
* Diameter: 12 Inch
Features
* 4" Copper Wound Voice Coil on an Aluminum Former, High temperature PAARC (Polyester Amide, Amide Resin Coated)
* Continuous power handling will be 1500W (under rated)
* Burp power in excess of 5000W
* X-Max estimated at 30mm (total travel 4" peak to peak)
* Field Replaceable Cone / Voice coil / Spider Assembly
* Dual Flat Conex Spiders with Loop/Stitched Tinsel Leads
* Tall, wide, balanced, Foam (high density expanded polyester foam) surround for linear controlled long excursion using a Tri-Radius symmetrical edge design optimized on non-linear FEA
* Enhanced voice coil cooling system (forced convection ? aluminum heat sinking ? shorting rings to reduce inductive heating)
* Dimensions (in) 11.9 x 10.7
Jan 04, 2011 | Orion HCCA 12D Car Speaker
How do i run a dvc sub with 2 mono amps? I have 2
each amp has + and - and will go to one of the voice coils , for the other voice coil use - to + FROM THE OTHER AMP , SET GAINS TO FULL COUNTERCLOCKWISE SO U NCAN LEVEL MATCH AMPS TO HEAD UNIT . REASON ONE VC IS WIRED "OUT OF PHASE IS SO THE CONES PUSH AND PULL WITH EACHOTHER
Oct 25, 2009 | Car Audio & Video
My Orion d-5000 amp which is wired to an Orion hcca 12.2 sub cuts out at high volumes , it's wired with 0 guage wires
Your speaker is a dual 2ohm sub. If you have both voice coils wired Parallel that will drop the ohm load to 1, which the amp can not handle. You need to wire the voice coils in series. Treat each voice coil as a speaker.
Jun 30, 2009 | Orion HCCA-D5000 Car Audio Amplifier
Orion hcca 250 digital reference & orion XTR 12" 500w dual subs
If you have one sub dual voice coil, just paralel the sub and conect to brigde amp. Simple...
Mar 02, 2009 | Orion HCCA-D5000 Car Audio Amplifier
652 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
