Question about Dishwashers
Dishwasher woes I used muratic acid (32 oz) in my dishwashers normal cycle to removescaling from the element. Looks great but runs poorly now. Doesn'tclean dishes as well as before. I use a rinse agent but still seeingspots and dried debris left on dishes. Example: peanut butter streaksstill left on knives. All moving parts seem to function properly so i'm at a loss.
    President:
  • 2,651 Answers
Muratic acid???? i would have advised a food safe product like vinegear. fill to top rack with 4 glasses in each corner and run for a min to see if they fill up with water to confirm htt wateris actually spraying all around the unit, whats the make and manufacture?
Posted on Mar 20, 2008
How is the china and crystal wash cycle different from the regular cycle on my GE Triton XL dishwasher? Can I use regular dishwasher soap on my china and crystal?
Most dishwashers that employ this setting use a lower temperature for the water and also they do not use the element to dry the dishes, they are air dried. China and crystal are very sensitive to changes in temperature and can crack easily. They should always be washed by hand however if you have to use the dishwasher make sure you have a mild detergent. No bleach or acid should be contained. If it says citrus anything it has acid in it. Also use half the amount of detergent regardless of its strength. Hope this helps. Good Luck!
Jul 19, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
Tip
Flashing or blinking green clean light 7 times?
This dishwasher looks for a temperature rise of the water during a heating cycle if it fails to see this rise for multiple cycles it may shut down and blink the clean light 7 times.
The failure can be wide ranging here are a few things to check before resetting the control.
-The unit not being level so both door switches do not make contact
- The sump plugged up so water is not pumping across the heater (see sump clean out below)
- Not enough water filling the dishwasher
- The heat element is not working
To reset the control use this key dance within 5 seconds press:
HEATED DRY, NORMAL, HEATED DRY, NORMAL
This will cause you to enter the diagnosis cycle once this is finished or you hit cancel the control should be unlocked and ready to use.
Here is a link for instructions on sump clean out
Poor cleaning or noisy Whirlpool KitchenAid or Kenmore
General Dishwasher washability
White powder hard water calcium residue
on Apr 25, 2010 | Maytag MDB8959AW Builtin Dishwasher
I need to get rid of hard water scales inside the dishwasher
One of the safest and least expensive ways to remove scale is to run the EMPTY dishwasher through a cycle using 1/2 cup of white vinegar. If all the scale is not removed during one cycle, then repeat the process.
I hope this gets rid of your problem. If it does, please come back to fixya and rate my solution!
Jun 29, 2011 | Dishwashers
I would like to clean off the calcium deposits that are in the dishwasher. How can I do this or what product should I use.
there are few things you can do to remove the calcium deposits.....
Change the detergent you use. Powdered dishwasher detergent is more efficient in removing grease and oil than gels. Decreasing the gunk left on surfaces may help slow lime scale buildup.
Put a quart of vinegar or lemon juice in the bottom of an empty dishwasher and run it up to the "dry" cycle once a month to keep up with accumulating scale. Extended exposure to mild acid and hot water dissolves most scale.
Clean circulator arms with vinegar or lemon juice and a vegetable brush or toothbrush. Let the acid sit on the scale before scrubbing. Use a needle or hat pin to pierce clogged holes, then rinse by running a cycle with vinegar.
Use plain salt or baking soda to scour surfaces with a sponge or rag. Rinse with boiling water or run a cycle with an empty dishwasher. Do not run the dry cycle.
  • 2 Put a quart of vinegar or lemon juice in the bottom of an empty dishwasher and run it up to the "dry" cycle once a month to keep up with accumulating scale. Extended exposure to mild acid and hot water dissolves most scale.
  • 3 Clean circulator arms with vinegar or lemon juice and a vegetable brush or toothbrush. Let the acid sit on the scale before scrubbing. Use a needle or hat pin to pierce clogged holes, then rinse by running a cycle with vinegar.
  • 4 Use plain salt or baking soda to scour surfaces with a sponge or rag. Rinse with boiling water or run a cycle with an empty dishwasher. Do not run the dry cycle.
  • Read more: How to Remove Lime Deposits in Dishwashers | eHow.com http://www.ehow.com/how_5611602_remove-lime-deposits-dishwashers.html#ixzz0wtABvYq2
    Aug 17, 2010 | Hobart 24 in. LXIH-3 Built-in Dishwasher
    I have just moved into a resale home{two years old} and the bosch dishwasher has a terrible odor what do i do?
    Works for me, empty the dishwasher of any dishes, silverware, pot or pans, get (2) jars of "Tang" orange drink. Use (1) jar to fill the soap dispenser and poor the rest into the bottom of the dishwasher.
    Run the dishwasher through a normal wash cycle with no heat/dryer time.
    Run a second time if necessary. The orange juice acid will dissolve the build up in the dishwasher and rinse it away. It also smells good when your done.
    For regular maintenance, repeat once every 3 months or so. It will not harm the dishwasher and will keep the interior components fresh and clean.
    Good luck.
    Oct 23, 2009 | Bosch Dishwashers
    Dishwasher leaves soap in dispenser.
    Hi Dirty Dish gang.
    After having 2 appliance repairmen here, I now have the latest scoop on our dishwasher problems, $200 later!
    Los Angeles IS currently having hard water issues. Also, all the new cleaning gels etc. are actually a cause of our dishwasher problems.
    So, here is what we need to do:
    1. Use Cascade POWDER detergent only.  Make sure is is just "plain" no "scented" or "complete"  or gel, etc. (I have tried a phosphate free powder and gel and this is a cause of our problem as well!) 2. Use Jet Dry in the dispenser (set it to a 2-3 opening) 3. Make sure water is at least 120 degrees 4. Only run dishwasher on "normal" setting.  All others just run it longer, hence causing more water stains. 5. Do not pre-wash dishes! You can knock of chunks with a "non" soapy brush, but don't rinse (the oils actually help to clean the dishes) 6.  Do not wash sponges in dishwasher.
    Acid Wash: The repairman just gave my washer an Acid Wash today. It says it is an acid derived from lemon, I got mine from Carters appliance in Torrance, CA for about $19. I am to run a normal cycle with the above mentioned Cascade after this "acid cycle" is finished.
    If you are still having problems:
    Monthly maintenance: Glass Magic: Buy a box of Glass Magic (near the Cascade)  Use 1 Tbsb in main detergent compartment of dishwasher along with the Cascade, till washer starts working again. White Vinegar: You can run an empty dishwasher with white vinegar once a month.  Fill a bowl with 2 cups vinegar and place on bottom rack.  Then run as a normal cycle...this allows vinegar to disperse slowly.
    So far it seems to be working.  Good luck.
    Nov 07, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
    Build-up terribly on heating element
    Get a gallon of muratic acid at the lumber yard, let the dishwasher fill with water and then add about 2 cups of acid then turn on the d/w and let it mix for a few seconds. then turn it off for about 15 minutes and then restart and let it complete the cycle. after a few days repeat the process. this should clean it up nicely. this is good for cleaning drains also. dont breath the fumes from the acid. dont pour into a stainless steel sink as it will cause discolorazition.
    Feb 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
    Dishwasher trips RCD electrics
    fault is probably heating element but you need a megga to test it. other disconnect element, tape up wires then check on wash cycle. be carefull!!
    Mar 20, 2007 | Electrolux 23 in. ESL624 Built-in...
    Dishwashers Logo
    104 people viewed this question
    Top Dishwashers Experts
