I have set up a home network using the Linksys wireless G router. I have networked one laptop to the network with no problem. A second laptop I am trying to connect just will not work. I need help, please.
    Guru:
  • 377 Answers
Hi dear
try this way....
  1. Before you attempt to use any Wi-Fi network, find out what the SSID, Channel, Mode and WEP key are. Some Wi-Fi locations do not require a WEP key. Many Wi-Fi providers have this information on their web site or when you purchase access you will be provided the information.
  2. Ensure you have a firewall program installed and running. This will protect your data.
  3. Start up your laptop and once booted, look for the Wi-Fi network icon in the bottom right of the screen.
  4. Click on the Wifi Connection icon on bottom right of screen and you should see a window that indicates connection, strength and duration. Click on the Properties tab.
  6. The next window will show the type of networking card installed. Click on the Wireless Networks tab.
  8. Once the Wireless Network Connection Properties window is open you will have two options depending on how you set up your laptop.
    • If you do not see any networks listed in Preferred or Available networks, you will have to manually add the SSID. Click on Add. You will have to enter the SSID and WEP key (if required). Click OK and you should then see the network you just added in the Available networks box.
    • If you see the correct SSID showing in the Available Networks, then you need to click on Configure in order to enter the WEP key if that is required.
  9. In the next window, enter the SSID for the Wi-Fi network you want to access. Make sure you do not have CAPS lock or NUM lock while entering the information. If a network key is required, click on "Data Encryption and then enter the Network key you have been provided with. Again make sure you do not have CAPS or NUM lock on. Click OK when entered. If you have entered the key incorrectly a message will pop up and you will need to re-enter the key.
  10. Next go to Start - and where it says Connect To click on that and you should see choices like in the graphic below. Click on Wireless Network Connection and it shI have set up a - 34b0a7b.jpg/li>
There are occasions when the connection doesn't work, in these cases check your firewall software and make sure it allows you to connect to the Wi-Fi network. To check this, disable your firewall software and check the connection again. If you can connect with the firewall program disabled, you change your settings. If your firewall program is not the problem check the SSID and WEP key information that you entered. Both of these are case sensitive. If you had obtained SSID information from the Internet, check with someone in the establishment to see if the SSID has been changed.
oke post in me back
i hope this usefull for you
thanks
cropp
Posted on Mar 18, 2008
SOURCE:
How can I get the router IP of my Linksys 2.4GHz broadband router?
The Linksys G router gives you both wired and wireless connections over a broadband Internet connect to create a local area network. The Linksys router is compatible with wireless G and B devices, through the 2.4-GHz wireless band. The wireless speed is at 54 megabytes per second and you can get 100 megabytes per second with a wired connection. You have to set up the wireless configuration on the Linksys before using it on your network.
Plug the router's power cable into an electrical outlet. Attach an Ethernet cable into the Internet port on the back of the router. Connect the other end into your broadband modem. Connect your computer to the Linksys G using another Ethernet cable. This Ethernet cable can go into any of the wired router ports. Open your Internet browser. Type "192.168.1.1" in the address bar and hit "Enter." This is your router's IP address and the home of its Web configuration page. Click "Wireless." Click "Manual." Alter your SSID, also known as your network name. You can change this name to any value that you want. You can also change the wireless channel if you are in an area with many wireless connections that may interfere. Click "Save Changes." Click "Wireless Security." Choose an encryption method to encrypt your wireless transmissions. WPA or WPA2 are common security protocols you can use in wireless networks. Input a network key, also known as the network password. Click "Save Changes."
Setting Up WPA Wireless Security on a Linksys Wireless Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=3696 Wireless G-Broadband Router support http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G b> b> Changing the Wireless Network's Name (SSID) on a Linksys Router http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&vw=1&articleid=4037
Mar 27, 2013 | Linksys Wireless-G Broadband Router
How do i find network key for lynksys network
To connect to your wireless router, the router's wirelesssettings needs to be configured with the SSID, encryption etc. and also thewireless cards in all the laptops/computers needs to be configured with theserouter's wireless settings. Then the laptops/desktop computers can communicatewith your wireless router.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Mar 03, 2012 | Cisco Linksys Wireless N Home Router...
We just added a second laptop to our home network and in setting up the laptop for wireless it asked for a pin number for our linksys wireless router but the pin number is not on the unit and we don't have...
Yes this is very straight forward
open internet explorer on your computer which is connected to wireless router.
browse to your gateway address. The default for linksys is usually http://192.168.1.1
then it will ask for username and password
linksys default username: (leave this blank)
linksys default password: admin
if that doesn't work try username: admin
password: admin
Once logged into console you should be able to see wireless security settings
Click on that and it will take you through to a page with your security settings on there you will see a wireless key or network key or wireless passphrase.
simply make a note of the key as its written. (If the password is masked or *********** out ) which is the case on some of the newer linksys devices you can simply overtype the password with a new one, bear in mind that you will have to then update any clients that normally connect to the wireless network with the new password. So thats all computers, laptops, DS's Wii's Playstations & Xbox's.
******I'd STRONGLY recommend you DO NOT change the wireless password / security key over wireless you should always do it using an RJ45 ETHERNET cable connected to your computer and the router. *********
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 15, 2010 | Linksys Wireless-G WRT54G Router
Cannot get a second computer on my secure wireless network
Have you set the properties on the second computer to match the security expected by the router? Since one computer works I would compare the settings for the network connection and set the second computer to the same.
Mar 15, 2009 | Linksys Wireless-G WRT54GS Router...
Changing router settings from 802.11G to mixed w/802.11B
Switching the wireless mode is easy, and, if you choose "mixed," the other computers in your home can continue to use the G mode unaffected. How you adjust the mode depends on the brand of router. Since Linksys is the most common, here is how it works on a Linksys router:
1) Open your web browser (IE, Mozilla, etc.)
2) Type the web address 192.168.1.1 (default for Linksys routers).
3) You should be asked for a username and password. The default for Linksys is username "admin" and password "admin" OR username "admin" and password [blank].
4) You should then see the Linksys setup screen. The tabs across the top include Setup, Wireless, Security, etc. Click on Wireless.
5) Pull down the menu next to "Wireless Network Mode" (which shold be set to "G -Only" and choose "Mixed." Then click "Save Settings."
This should allow your B-capacle Palm to use the network without a password while still allowing your encryption-capable computers to use the G mode.
I hope this helps - please let me know if I can be of any further assistance.
H2H
Dec 14, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Connection Issue
Hello There. What error message are you getting when you try to connect?
It would be better if you check the settings of your router. YOu need to hardwire the computer to the router via an ethernet cable. By default, you may access the router via http://192.168.1.1 using your web browser. No username, type admin on the password.
First, you may check the number of DHCP users that can connect to your router. On the setup page, Make sure that the No. of clients/DHCP users is set to 50(by default).
Second, go to the wireless tab then take note of your network name if you are connecting to the correct network. Under the wireless tab, click wireless security tab, verify that you are using the correct KEY.
If you are, remove your preferred networks on the computers then try to reconnect.
Hope this helps.
Aug 06, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G (WRT54GS (EU/LA/UK))
I have had that issue quite often and found that when you are using a router with DSL, the DSL modem and Router IP has a conflict because they are the same number. I suggest looking into a D-Link wireless router for use with DSL.
Mar 17, 2008 | Linksys Wireless-G WRT54GS Router...
Open Questions:
Computers & Internet Logo
77 people viewed this question
Ekse
Alun Cox
