Question about HP LaserJet 4L Printer
No power lights
HP 4L acts like the power has been turned off but it has no switch. It just stopped working. Is there a fuse or breaker?
  • 6 more comments
  • ldablo Mar 21, 2008
    My 4L went dead a few days ago. Both fuses are good. Can't find any other problem. Any suggestions?
    Thanks
  • Anonymous Jun 12, 2008
    I just rearranged my home office and when I went to set up the computer my power was gone, lights gone too. When I attempt the print command, the message comes up "printer out of paper". The paper tray is full.
    Is this the end of my reliable laserjet 4L?
  • chuckfredmei Jun 13, 2008
    When I plug the printer, it turns on first, and then turns off a few seconds later. It had been working fine for a long time. What is wrong? I would appreciate it if someone could give me any suggestions. Thank you.
  • Anonymous Jun 24, 2008
    Where is the on / off switch on the Laser Jet 4L printer?
    I have the same problem.
    pamsweb@cox.net
    thank you!
  • pamsweb Jun 25, 2008
    I went out of town. Turned my PC off & also turned the power strip off. When I turned power strip on & PC on my HP LaserJet 4L will on turn on & no lights. If their is a fuse I can't find it or understand where it is from a spec.
    Help please!! ;o) PJ
  • sheywood Jul 11, 2008
    Same problem: turned power off and on, unplugged and replugged, held down blue button several times, but still no power/lights to printer.
  • Anonymous Aug 31, 2008
    Can someone rescan the document of the troubleshooting diagram and post it again? I can not read it.
    Thanks!
  • judyr108 Nov 29, 2008
    I purchased this printer along with a computer to which it was connected and had been working. Since I brought it home it does not seem that it can turn on, nor can the computer talk with it. I can't find a standard Power On button and there are no lights or indicators... Help.
I had the same problem and here is how I fixed it. Well, it's not really fixed but I circumvented the problem. I had my 4L unplugged for months because I was using an Okidata for a while. When I plugged in the 4L it wouldn't power up anymore. It worked when I put it storage, but not now. I tried plugging it in and out so much I got to the point where I was going to toss it. No help on line, nothing in the manuals. AHhhhh!
Then on a hunch I tried this...
I plugged the thing in and let it sit for hours. Then I unplugged it. After some time (hours) I plugged it back in and let it sit for hours. Then unplugged again for hours. Then plugged back in and I saw all the lights flash for a brief moment, but then they all went off. I just kept repeating this (it will take at least a whole day or more), and eventually when I plugged it back in it came to life. At this point DON'T UNPLUG IT!
Now...I was able to duplicate this fix because I recently moved and the thing was unplugged again for a few days. Plugged it back in at my new house and guess what, yea..same problem, but I went through the same procedure and it worked again.
Now it will not be unplugged.
Posted on Jul 16, 2008
Does anyone know if there is a battery that holds any memory on this model? I've had my 4L for at least 10 years. If so, could this be a possible culprit? Thanks.. ... just guessing....
Posted on Sep 04, 2008
    Problem Solver:
  • 7 Answers
I have the same problem of the hp4l printer does not power up after being plugged into AC power. Took the printer a part and pulled the 2 fuses (125V 10A and 2.5A) out and continuity tested them OK. Be sure you put the fuses back correctly as they are different amp ratings. Didn't find anything to indicate a timer module that turns off the printer due to inactivity so I just put everything back together and it powered up fine. Prnted about 10 pages of different documents and just let it stay plugged in to my powerstrip. Power off the strip when I went to bed but the hp4sl did not repower backup. Dead again.
One more shot at taking it all a part again and while I did see the lights flash on for a 2 secs, the printer never recovered power again. I'll let it rest a day or two before I toss it. Not sure I want to spend time on going around the powersave function but since I'm retired now I still might take another crack at it.
BTW, does any one know what the reset button that on the parallel printer port connection is for? I noticed it when I was looking over the main board to see what docs that were silkscreened on the circuit board and found reset sw. It's not an easy switch to hit but when I did hit it, nothing happened.
Posted on Aug 03, 2008
    New Friend:
  • 159 Answers
Posted on Mar 18, 2008
I have a 2000 Mercury Sable wagon the air conditioner, radio antenna,dash lights and windows do not work. all went out at the same time. what is the problem? could it be a fuse or breaker?
Those are all different circuits, all unrelated, so it definitely is not a circuit breaker which is common to stand-alone circuits, like the power windows which does use a circuit breaker.
I believe it could be a maxi-fuse, one of those large fuses underneath the hood, which act as power distributors going out to many individual circuits. Your ignition switch has one or two of these maxi-fuses that distribute power through the ignition switch. And I believe there may be a maxi-fuse that sends power to the fuse panel.
So check all your fuses under the hood. Pay particular attention to the maxi-fuses. Beyond that, I don't know. A voltmeter or test light would be helpful to check for power at the fuse panel where all the fuses for your inoperable systems are located. With key in the ON position, all the fuses in your fuse panel should have power going to them. The fuse panel is where the fuses for those systems are located, including the circuit breaker for the power windows.
Apr 28, 2017 | Mercury Cars & Trucks
Which part on the HP laserjet 4L would control the power to the printer. Mine will not turn on. Has no lights showing. Will not do anything. Any help out there?
Hi this machine has a power supply unit... may have fuses you can change on it.... have you tried the fuse in the plug? powersupply unit avaialable on line, may be cheaper to replace the printer though.
Apr 05, 2010 | HP LaserJet 4L Printer
HP 4L stopped printing. Red light flashes
May be some ilegal process, May be paper not in tray, find it
Dec 10, 2009 | HP LaserJet 4L Printer
I have an HP 4L and while there is power to the printer I have no lights and of course it does not work.
replace the dc controller board (turn printer upside down and remove the bottom of printer ,thats the power board.
Sep 12, 2009 | HP LaserJet 4L Printer
HP 4L laser printer - no power indicators showing -
there is not a fuse in the printers main board but i can say that there is circuit breaker on the board like fuse only instead of fuse there is a ic that ic has to be replaced if major damage the cost may vary other wise the ic is just under 1$ THATS IS.IF ANY ENGINEER DOES HE WILL CHARGE HIS SERVICE FOR THAT.BUT CALLING A ENGINEER IS ADVISABLE AS HE WILL ALSO CHECK OUT ANY OTHER PART GOING TO BE SHORT IN NEAR BY COMING DAYS.
Mar 02, 2009 | HP LaserJet 4L Printer
Hp laser jet 4L problem
try holding the "online" button down when turning on the printer release when you get "cold reset" message
Jun 26, 2008 | HP LaserJet 4 plus Printer
LASER JET 4L PRINTER PROBLEM
Dear pamswab.
there is an interrnal fuse in the printer you most open it and found the power bourd the fuse there
HP Laser Jet 4L - No Power
it's possible that the power switch alone just needs cleaning. Take it apart down to seeing the copper contacts and then polish the copper contacts with emory cloth.
Sep 09, 2007 | HP LaserJet 4L Printer
HP LaserJet 4L Printer Logo
584 people viewed this question
Seeker5211
Seeker5211
