Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
Help
By SKETCHY1 on Mar 18, 2008
well i have a jazz JDC25 and i lost the insruction manual and i dont no how to use it can u help me
digital camera
Same Problem
Jan 07, 2009
-   My Jazz JDC25 camera wont let me install it to my computer to download my pictures and without it the camera is of no use to me.......Help!-   Babygirl1243
Dec 12, 2008
-   My pictures are blurry - I have a hand icon showing - what's up and how do I fix it? -   meatwork
Apr 12, 2008
-   How do I change the date?-   Guest
Best Solution
posted on Mar 18, 2008
Helpful)
Candyhelp
Rank: Wiz
Rating: 80%, 151 votes
  • The first time you use the camera, or if the batteries have been removed or dead for an extended period, you should enter the date and time. The date and time will help you organize, locate, and identify your images later.
  • Always check camera settings on the control panel and in the viewfinder. Notice how many pictures you can take at the current settings and the status of the battery charge. Also, learn what the icons mean because it's not at all unusual to change a setting, then forget you have done so.
  • If an image is being stored when you turn the camera off, the image will be completely stored before the camera powers down.
  • Most shutter buttons have two stages. When you press it halfway down, the camera sets focus and exposure. When you press it all the way down, you take the picture. To capture action shots, hold the button halfway down while focused on the scene. When you then press the button the rest of the way, the camera shoots immediately because focus and exposure have already been calculated. On some cameras you can also press the shutter button all the way down in one action, but there will be a delay before the photo is taken and it may be out of focus.
  • If the viewfinder appears blurry, see if the camera has an diopter adjustment that makes it sharper.
  • To take pictures, hold the camera in your right hand and support the camera or lens with your left. Don't block the flash, autofocus port, or lens.
  • As you take photos, they are first stored in the camera's internal memory called a "buffer". When the buffer is full you'll have to wait until one or more of the images has been transferred to the memory card before taking any more pictures.
  • Don't open the battery or memory card access covers while an image is being saved. Doing so can not only damage the image being saved, it can also damage the card.
  • Some cameras will briefly display the image you just took as it is being saved. Usually you can turn this feature on or off.
  • You can usually adjust the brightness of the monitor. Make it brighter in bright light and dimmer in dim light.
  • Many cameras have a tripod socket so you can attach it to a tripod when you want sharper pictures.
  • Take as many shots of a given scene as you can think of; changing positions, distances, and angles. You may be surprised later at what works and what doesn't.
  • When done shooting, turn the camera off.
  • Was this helpful?
    Yes
    No
    1 person thought this was helpful
    Solution #2
    posted on Jan 21, 2009
    Not Rated)
    yadira_s_9
    Rank: Apprentice
    Rating: 0%, 0 votes
    Yo cuando tomo las fotos en la noche no se mira nada y no tiene una luz para alumbrar que puedo hacer por en el dia no puedo toma foto o filmar por que no se mira nada en el interior de la casa
    Was this helpful?
    Yes
    No
    Popular Solutions for Digital Cameras
    Questions and Unsolved Problems for Digital Cameras
    Answer
    Quantaray 18-200MM NEED INFORMATION ABOUT LENS PERFORANCE ... for canon EOS XTI
    Answer
    I need help getting instruction manual for me ViveCam # XO24. Thanksgiving is this Thursday and I... (More)
    Answer
    Looking to replace a broken battery door on my Olympus FE-210 Digital Camera. Can you help?
    Answer
    How can I see the subject of a photo in the lcd screen. I need to use the viewfinder now.
    Answer
    i dont have cdrom drive how can i connect my pentax 50l to pc
    Describe your problem:
    Select a Category:
    Ask our Experts
    Solve Your Problem Now!
    Chat Live with an Expert
    Chat Now
    Browse popular Problems
    More Common Problems
    Most Common Problems for:
    For Digital Cameras:
    Top Digital Camera Experts
    Rank: Guru Guru
    Solutions: 898
    Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
    Ask Me
    Find more Digital Camera Experts
    Top Camera & Camcorder Repair
    (214) 951-9731
    Digital Camera repair and sales,trade,salvage.
    Mikes digital camera repair
    (915) 239-6199
    CamerasAndParts.Com Specializes in the Service /...
    CamerasAndParts.com
    Chat Now
    X
    Continue
    When the original poster rates a solution that was given to his own problem, that rating is locked!
    X
    Are you sure the solution content is Inappropriate?
    Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
    Insert Link
    Insert Image
    Insert You-Tube clip
    Insert List
    Insert List
    Spell Check
    What is this?
    Select
