Question about Nikon COOLPIX L3 Digital Camera
Nikon coolpix s70 lens error, need help. - Nikon COOLPIX L3 Digital Camera
    President:
  • 1,871 Answers
Hello :
It is a pretty major problem for the Coolpix it seems. The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system. It could have been something as small as a bump while it was being carried in your pocket. The problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that Nikon says happened during usage.
Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Nikon first and see what they have to say about cost of repairs. Other people say that once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
I hope this will help .
PLEASE DON'T FORGET TO RATE !
Posted on Apr 09, 2010
5 Suggested Answers
guru_dev
  • 315 Answers
SOURCE: Nikon Coolpix camera it beep once
Please try the fix provided by me under: http://www.fixya.com/support/t917064-nikon_coolpix_s10_lens_error
Posted on Jul 19, 2009
  • 102366 Answers
SOURCE: hi i have lens error with my nikon coolpix
Sadly, the camera needs service.
Posted on Dec 29, 2009
  • 11967 Answers
SOURCE: nikon coolpix s60 is giving lens error, pls i need
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 29, 2010
lock123
  • 6831 Answers
SOURCE: Lens error on Nikon Coolpix p5100
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
How do I correct lens cover error?
nikon coolpix s52 lens cover error Questions & Answers ...
www.fixya.com > Forum > Tags
Nikon COOLPIX S51 Digital Camera When I turn the camera on the lens cover willnot slide open. The screen displays a message that say "Lens Cover Error!
Nikon COOLPIX S52 Digital Camera - Fixya
www.fixya.com/support/p926575-nikon_coolpix_s52_digital_camera
Recent Nikon COOLPIX S52 Digital Camera questions, problems & answers. Free expert DIY tips, support, ... How do I correct lens cover error? Nikon COOLPIX.
Fixing a nikon S52 camera lens cover?? PLEASE HELP!!!? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Apr 4, 2011 - ... broke my lens cover on my nikon coolpix s52. when i try to turn it on it says Lens cover error and has a ... Can i fix it myself? What would be the approximate cost of repairs? ... How to fix Nikon Coolpix L6 digital camera lens?
Lens Error message ' Nikon Knowledgebase
Aug 31, 2015 | Nikon COOLPIX S52 Digital Camera
Nikon coolpix s70 has blurry pictures even after resetting to default settings. Camera has not been damaged or dropped.
Hi you have lens unit defective. Even if you didn't damaged and dropped, its appearance problem is the lens unit, you can bring to your local repair shop. It is quite easy problem. some point they could save part, but time is money. they would want to change the part. your part from nikon usa is very expensive, but from ebay it is very cheap. It is used but it would be reliable in most case. http://cgi.ebay.com/Camera-LENS-ZOOM-UNIT-Nikon-Coolpix-S70-BLACK-/180672085419?pt=Digital_Camera_Accessories&hash=item2a10e53dab#ht_500wt_1156 If you buy and bring it with camera to your local repair shop, they would charge less labor then you bring camera only. repair shop would consider that you know what it is going on. Thanks and kindly! ( labor they would charge around $25 to 75 depend on what they want to charge)
Jun 02, 2011 | Nikon COOLPIX S70 Digital Camera
When turning on the camera it makes a fast tapping sound and then comes up lens error. Now this happened after i accidentally dropped my camera. Its an S70
When the camera gets dropped it causes all kinds of problems, from your description the lens has been damaged and is seized. To have this repaired would not be cost effective, cheaper to replace.
Apr 15, 2011 | Nikon COOLPIX S70 Digital Camera
Something has happened to my camera and now when i turn it on the screen is black and it says : Lens error , how do i fix it ?
From Nikon's website regarding this problem:
http://instrument-support.nikonusa.com/app/answers/detail/a_id/15978/~/lens-error-message
"Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
  1. One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
  2. Remove and recharge and/or replace the battery. If the error does not clear up right away, leave the battery out of the camera overnight, and try again the next day.
If the above tips do not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras."
Feb 28, 2011 | Nikon COOLPIX S70 Digital Camera
Lens will not open
Try pushing the lens gently inside then side to side. It should zoom right out when turned on. It happened to my S70 coz when my kids played with it dropped it.
May 23, 2009 | Nikon COOLPIX S60 Digital Camera
Nikon COOLPIX L3 Digital Camera Logo
2,895 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
