Question about Xerox DocuMate 252 Path-Through Scanner
Incomplete feed My scanner worked like a charm for the past year. I moved and reconnected it recently. Now it does not feed the page through completely, leaving about 1/2 inch of paper in the rollers. It does not complete the scan or feed the second page. Did I do something in the move?
  • lovering810 Nov 12, 2008
    Although the scanner worked perfectly well for the first while I had it, it now hangs up on the seemingly smallest thing - there's no cause I can find of the paper jams, it just seems the rollers spontaneously decide to forego traction, and the scanner insists that there is something horribly wrong.  To add insult to injury, every time this happens, despite the option to "try again", the file disappears!  Any suggestions?
    New Friend:
  • 136 Answers
Try correcting the page width and make sure one page goes through at a time also you can press the bottom of the paper and it will feed better
Posted on Mar 18, 2008
Have a pellet stove that has been working perfect for years, then last night it shut itself off and when I opened door there was this black tar on everything inside and the windows were also black. I had...
Several of things come to mind: Have you changed the type (Brand) of pellets, recently?
Have you had your chimney (stack) cleaned in the past year? Is the fresh air intake functioning properly? Is the auger feeding to much or to little pellets?
Changing brand of pellets - Not all wood pellets are made the same. If you recently changed brands, you will need to tweak your stove to handle this new brand. This will affect how the auger feeds.
If you chimney (stack) hasn't been cleaned in the past 12 months, it may be partially clogged with creosote and not drawing properly and it is liquefying and running back down the chimney and not allowing for a clean burn. And could cause a chimney fire.
Fresh air intake: If that's not functioning properly, you're getting incomplete combustion. Which will cause the black tar looking substance you described. Couple that with changing brands of pellets and you have a problem.
The above are the first things that came to mind. I hope it steers you in the right direction to troubleshoot the problem. Please let me know.
Mar 28, 2011 | Heating & Cooling
Scanner not feeding on lexmark x7170. paper feeds halfway in them reports error/clear paper jam in scanner document feeder.
I have the same all-in-one printer and have just recently, the unit is a few years old, started having the same problem. I found that that if I make double sure the pages are evenly stacked and very carefully placed in the feeder tray, the problem is less common. It doesn't work everytime but ar least I get my faxes through on the first attempt 75% of the time.
Nov 10, 2010 | Lexmark X7170 All-In-One InkJet Printer
Canon DR-5010C, only feeding 1 page at a time!
If you have it set to certain paper weights or manual feed that is all you will get. Change the settings from the printer monitor back to normal weight paper or text not high quality graphics and it should feed again.
Aug 10, 2009 | Canon DR-5010C Path-Through Scanner
Scanner pulls page in to just past the bottom sensor lever
Please ensure that the rollers are clean and within its life span. (Rollers wear out and need to changed after 250,000 pages or as recommended by mfr). FAn the pages before scanning, Ensure the edge is trim with no folds or bends. The griniding noise is because the scanner has picked up more than one page.
S. Mohan. India
May 29, 2009 | Canon DR 3080C Path-Through Scanner
Laserjet 3050 scanner error 6
  1. Disconnect power
  2. Open the scanner section (you need torx)
  3. Move the scan unit halfway the transport rail
  4. Close the scanner section
  5. Reconnect power
I recently had this problem and I solved it this way.
Mar 06, 2009 | HP LaserJet 3050 All-In-One Printer
Epson Sx200- Paper wont feed
Just a thought,as I had a similar problem.The instructions are abysmal,but it may be worth having a look where you feed the paper in and squeezing the grey plastic gizmo,and moving it to the left to allow the paper to enter the feed properly.
Dec 26, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Targus AMW15US wireless mouse
First are the batteries good?
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Dec 16, 2008 | Targus AMW15US Mouse
Canoscan 9950F won't scan, says scanner locked, but it isn't
I was surprised by the same problem this morning. First time I've had a problem with in years. Checked the lock... it was already unlocked. I solved the problem by unhooking the USB cable from the hub, restarting my Mac (seems to be the key), replugging the cable and restarting the scanner. Worked like a charm. Hope it works for you!
Nov 19, 2008 | Canon CanoScan 9950F Flatbed Scanner
I620-auto feeding multiple sheet
I opened the hood on the machine, and between the first two intake rollers on the bottom, there is a small rubber strip. This strip comes packaged with a sticky yellow tape to protect the rubber. When it was installed, no one removed this tape. After doing so, the machine feeds great. Hope this helps someone else who may be experiencing a similar feed issue.
Jul 16, 2008 | Kodak I620 SHTFEDSCAN Path-Through Scanner
My copier won't print.
Are you sure that your scanner bulb is working. You may hear the scanner moving but the bulb may be burned out which will cause you to get blank pages.
Inkworks
May 13, 2008 | HP PSC 1210 All-In-One InkJet Printer
Xerox DocuMate 252 Path-Through Scanner Logo
254 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
