Question about Frigidaire FWS1339A Top Load Washer
TAKING APART HOW DO YOU REMOVE THE DRUM FROM THE FRIGIDAIRE FWS1339AC1 TOP LOAD WASHER?
    President:
  • Frigidaire Master
  • 2,651 Answers
Withoout asking why , heres how to remove the inner tub, simple enough. theres abolt in the top of the agitator,(pop the little cover with a screwdriver). the agitater pops off, insert a screw driver under the maintop perhaps 3 inches in from both sides and pop the clips the main top leans back. Unsnap the white cover from around the outer tub and lastly there will be (2)) 1/2inch screws screwed into asolid block at bottom of agitator, thay are locking the inner tub to the transmission shaft. note the flat spot on the transmission whish the block is resting youll need to reinstall it at same point
Posted on Mar 18, 2008
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Dryer will not turn on
if u have recently replaced the belt, the drum may have come out of the track. i suggest taking it apart and making sure the drum is seated correctly. i had to do this several times to my mothers ge electric dryer.
Nov 15, 2011 | Frigidaire FGX831CS Top Load Stacked...
Frigidaire GLWS1233A Top Load Washer is leaking from the bottom, there are no kinks in the hose, water is coming from the bottom.
there is a chance that the tub seal is broken. in orfer to check it you need to remove the front panel by taking the two screws out of the bottom the push the two clips in that are located about an inch in from either side of the washer the lid will pop up and then you can remove the front panel.
then start the washer again and look to see where the water is coming from
Sep 17, 2010 | Frigidaire GLWS1233A Top Load Washer
Need directions to remove broken drum vane in a Frigidaire Gallery Front loader washer (GLTF2940FS1).
Open the top of the machine (look behind the top for several screws to remove) and slide it back to release from the cabinet. This should give you access to the screws that hold the vane in place. Hope this helps!
Jun 28, 2010 | Frigidaire ATF6000ES Front Load Washer
Loud clunking sound during the spin cycle, washer is balanced and on 2nd floor
If you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Frigidaire GLTR1670A Front Load Washer
An old model Frigidaire top-load washer - the old "turn the dial, and pull out to start" type. Drum won't agitate - what, if anything, can I do?
Remove the front panel and inspect the drive belt. It is probably worn out and or stretched.
The Frigidaire style you have does not take overloading very well.
Also check the lid switch for continuity. It must be good for agitation to occur.
Nov 01, 2009 | Frigidaire FWS1339A Top Load Washer
(front load ATF6000ES) is constantly leaking detergent
the loose vane cant affect leaking first open the drawer look on the back Left side of the drawer push down on the tab and remove the drawer take it apart and clean it well top and bottom clean the inside of the drawer hsg and look for cracks on the top panel remove the two screws at the back and remove the panel reassemble the drawer assembly put detergent in it start the washer take a flashlight and look for leaks
Mar 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
Front load dryer
Remove the front panel to get to it. Once you get the front panel off it is easy to remove the drum and replace the element. First remove the top then the front then you have it.
Dec 19, 2007 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Frigidaire FWS1339A Top Load Washer Logo
300 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
