Question about Panasonic PT-53WX42 53" Rear Projection Television
Streaks I have a 53 inch panasonic pt-53wx42f. The light colors streak lightly across the screen to the right especially if there are dark colors on the screen.
Does anyone know what the above fix might cost? Also is it worth it or should I just live with the tearing and replace the set eventually?
Posted on Apr 09, 2008
  • 934 Answers
It's called tearing and it's likely in the HV circuit, possibly the FBT or splitter. Won't go into any greater detail than that, other than to say it's time to call the technician. Voltages in that circuit can make you VERY dead...
Bill
SOURCE:
Television is a Tosiba DLP 72HM195
your tv needs a y-load board its like a grafix card as computers have due to overheating the board components are affected this is a manufacturing fault it tends to happen with samsung aswell
Feb 22, 2012 | Toshiba 72HM195 72" HDTV
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Hello, I have a 53-inch Panasonic PT-53WX42F TV, and it refuses to turn on. No picture, no sound. All it does is the tiny red power light blinks 3 times repeatedly. Can I fix this myself? What parts do I...
    Thats a convergence failure when the led blinks 3 times. Your model uses the PT47WX42 convergence repair kit available from www.tvrepairworld.com the kit contains the parts and the CD with instructions for the repair.
    Jul 16, 2010 | Panasonic PT-53WX42 53" Rear Projection...
    Dark shadow-like vertical streaks thru LCD screen (Sharp)
    Hi, I have a Sony Grand Wega LCD Projection TV that has a blotted gray streak across the front of the screen. I only use a damp cloth to clean the window and that doesn't seem to help. It really shows up on light pictures and is unnoticed when the picture is a little darker. What can I do to fix this problem???
    Aug 19, 2009 | Philips 32PF5531D 32 in. LCD Television
    Two blue streaks across the screen
    sounds like the blue convergence or the Blue CRT needs a coolant change. If the picture apaers 3d its the Convergence. If the color seem abnormal or not true tones its the CRT coolant
    Jul 13, 2009 | Panasonic PT-47WX49 47" Rear Projection...
    PANASONIC CT-27D30B
    Maybe the vertical IC output are damaged you need to replace him
    Sep 19, 2008 | Panasonic CT-27G14 27" TV
    PT-47WX, Blue streaks across the screen?
    It is not a bulb. It is a picture tube. If there are thin blue lines across the entire screen, not just the edges, and the picture itself looks too blue, it means that the blue picture tube is being driven too hard. This could be because the blue screen voltage is too high, the boost voltage on the blue picture tube is too low, or the video output is leaky or shorted. If the picture has what looks like blue arcs and double images on one or more sides of the picture, it means that one of your convergence IC's has burned out and needs to be replaced. These are things that should be tested and serviced by a qualified tech, so allow an experienced tech to handle it for you.
    Sep 07, 2007 | Panasonic PT-47WX49 47" Rear Projection...
    Panasonic PT-53WX42 53" Rear Projection Television Logo
    80 people viewed this question
    Top Panasonic Televison & Video Experts
     Grubhead
    Grubhead
    Demonic-2011
    Demonic-2011
    Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
