0392. Check this code. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily. http://remotesearch.blogspot.com/ http://electronicshelponline.blogspot.com/ http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
hi,
Try the following codes
if you have four digit universal remote then codes are
0054, 0030, 0020, 0096
If you are using three digit universal remote then codes are
054,030,020,096
ok
with most combo's try the VCR codes and then also program the tv code for the volume controls
if you are missing the programming instructions go to the RS website - support
You will need one that is designed for a TV/VCR combo. Go to this link they have universals that are for TV/VCR combos i am pretty sure they have one that will work. http://servicemanuals.vstore.ca/
We have a Sylvania 6313CB TV/VCR combo. I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books. So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked. This was a $6.00 universal remote named "One For All" we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on
Pushed the "VCR" button and light blinked once
Pushed and held the "set" button until it blinked twice
Released the "set" button and entered the numbers "0000"
Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
