Question about Panasonic PT-AX100U-EC DLP Projector
Panasonic PT-AX100U-EC need assistance i usually keep my projector on standby mode. the problem is when i press the power button, it switches off by itself just after 3 to 4 minutes. so i wait for it to cool the fan and go back to stanby mode. then when i press the power button again, it doesn't turn on. i have to turn the main switch off and on again to have it power up again. jay
  • 11 more comments
  • Rickydoo Mar 23, 2008
    I have the same problem. I'm assuming it needs a new bulb. I tried sweeping off the air filter, this didn't help.
  • Anonymous Mar 25, 2008
    Got the same problem.
    Tried cleaning the air-filter and replacing the bulb. No luck.
  • Anonymous Apr 03, 2008
    The projector i have will turn off a minuite or two after i turnded it on, i tried agan several times again and waited for about an hour, what do i do?
  • lineman1 Apr 13, 2008
    I Have the problem with projector turning off 3-4 minutes after start
    up, thought it was the bulb. Replaced the bulb and found a spring,small
    plastic gear and washer rattling around in the projector. I read on the
    net some problems with the iris control, are these the parts from it?
    projector still shuts off after changing bulb and in order to re-start
    I have to unplug it and replug it in to get it to start again.
  • Anonymous Sep 25, 2008
    i have the same problem, tried the filters, tried reseting the lamp time to 0, and no luck
  • dlatlanta Nov 17, 2008
    Same problem. We have to manual shut off the power to restrart the projector. It started off once and know we have to do it three times sometimes more before it stays on for hours without a problem.
  • dhmillertime Nov 20, 2008
    my projector switches off after about 2 min. I have to turn main power off then on to turn the power back on. then same thing happens. I thought maybe it was the fans but they appear to be working fine. No debris in the filter or anything. my best bet is a problem with the thermostat or something.
  • IFE Mon Nov 28, 2008
    ".........i usually keep my projector on standby mode. the problem is when i press the power button, it switches off by itself just after 3 to 4 minutes. so i wait for it to cool the fan and go back to stanby mode. then when i press the power button again, it doesn't turn on. i have to turn the main switch off and on again to have it power up again........"
    I have had a simular problem though, I can not get the projector to run at all for more than 2 min.
    I also cleaned the filter, to no avail. I do notice that before the projectoer shuts down the fan slows considerably.
  • Anonymous Feb 06, 2009
    same problem
    shuts off aftre few minutes
    need to disconnect main switch to active
    whne activate agian it works fine till next time that i use it
    any ideas how to solve?
  • avis1234 Feb 06, 2009
    same problem any idea?
  • Anonymous Mar 06, 2009
    Well...guess what? I have the nasty iris problem as well. I only have 1532 hours on the PT-AX100u unit. Still has the original bulb. The probably has been diagnosed as the sticking iris. Here's the catch: warranty ran out in November 2008. Panasonic has offered to replace the $35 iris unit...BUT...they want me to pay Heartland another $130 to diagnose and fix the problem, followed by an additional $130 (approx.) for "shipping and handling." What a scam! I know that I am just 3 months out of warranty, but frankly, this is a well known pre-existing problem with this projector that should have been addressed prior to my purchase. Any reputable manufacturer would take care of this problem. Currently, I am almost 3 weeks into "negotiations" with Panansonc...if they would ever find the time to call me back! In other words, since I watch my TV rarely, then I am being punished since my warranty ran out before the IRIS could malfunction. This is crazy. I would not recommend anyone purchasing another Panasonic projector at this point. I really do like the unit and the picture, but the service, follow-up, and reliability of this unit have proven to be a dissapointment. For me, the $260 they want for the repair is not an issue. The issue is a matter of prinicipal at this point. I you are in the market for a projector, look for a company that has a history of excellent warranty and customer service. Everything else will work itself out for ya. There are lots of companies out there that would love to have your business. I'll let you know what happens...if they ever call me back.
  • Anonymous Mar 07, 2009
    I've had this model projector now for over two years. I've put up with the bulb having fits of "flicker" issues in BOTH eco and normal modes on and off for months at a time in some cases (bulb is now at 1782 hours) and just when I was thinking the flicker thing was getting so bad I was ready to try a replacement bulb (up from $280 to $307 minimum from the last time I looked at what they were going for; most places want a lot more which to me is ABSURD for a flipping BULB that only lasts maybe 2 years at best when the entire projector now goes for under $1000). But in the past 3 days, the dreaded iris problem has suddenly surfaced, which if unchecked makes the whole bulb replacement idea a complete waste of money. Given my projector is long out of warranty (over 24 months now), I guess I might try oiling the shaft myself as someone apparently successfully did in a bid to save having to buy a brand new projector or pay hundreds of dollars to fix what is so obviously a LEMON DESIGN in terms of reliability (nearly ALL units have BOTH defects and Panasonic has no good solutions for EITHER problem long-term. They just throw another bulb at it and hope it doesn't intermittently short (causes flicker) and figure the grease will take awhile to dry out on the cams. Lovely projector. Lovely company. It's my last Panasonic projector/tv EVER. $1600 is a LOT of money to get only 2 years out of a glorified tv set. My last Panasonic HDTV was a CRT model from around 1998 and it still works fine! Compare that to this 2007 era projector that barely lasted two years and had on and off flickering issues nearly all along (I think it started about 10 days after the 90 day bulb warranty was up; it's almost like they have those numbers planned to the day). What poor manufacturing. I'm starting to think Panasonic is the GM of projector makers....
  • teffers Apr 03, 2009
    I HAD the same "stuck iris" issue with my AX200.
    A couple dabs of oil and I'm back in business.
    Much thanx T
  • 3 Answers
I just repaired mine with some oil for the iris assembly.
The problem is the iris is either slow to respond or doesn't respond to it's controller. The cam should snap back to it's resting point and move freely. It needs to be re-oiled. Mine would move but sluggishly like it was sticky. There are TWO pivot shafts to oil. One on top and one on the bottom. The bottom one can be accessed by removing the bulb. You can see the bottom cam while the bulb is installed. This is a good point to test the iris movement at.
You need to have some mechanical ability. If you don't think you can do this then don't.
First remove the bottom bulb cover. Now get a flashlight. Look in the area that bulb is pointing towards. In the left corner of the side towards the front of the unit where the lens is, you will see a brownish cam. It has a spring around it.
Take a small screwdriver and move it to it's extent like a wheel. Let go and it should quickly return to where it was. It virtually snaps back to it's resting point. Do this several times. 5-6 If at any time it returns sluggishly then it needs to be oiled. 3 in 1 oil works great.
This takes time. I used a small jewelers screw driver to deliver the oil. As you oil it move the cam back and forth to work the oil to the shaft. Standing the unit on edge after you put the oil in the gap helps the oil get to the shaft.
If it now starts to snap back put the bulb cover back on and try the unit. If after 5-6 movements it still does not snap back each time then the actual motor shaft needs to be oiled as well.
Take the top off. There are several screws and one on the back. All have an arrow marking them. The cover is caught around the lens assembly. You have to be a little bit violent to get it off. After the cover is removed, you have to really look for the upper iris cam. It is under the large multi pin connector with brown wires on the main main display board. There is a small perforated metal cover under this connector.
After bending the cover up you will see the linear motor that drives the iris. There is a small flex cable going to it. You need to oil it's shaft. Use the same procedure to oil it as the cam under the unit. After oiling this shaft the iris should now snap back to rest every time. That's it.
Posted on Jan 04, 2009
  • 1 more comment
  • maxpleasure Dec 21, 2010
    shrike0064 is 100 % accurate in what he suggests . I had to oil both cams and now finally it works. THANK YOU!
  • MARCELO COSTA-FERREIRA
    MARCELO COSTA-FERREIRA Apr 19, 2014
    http://www.fixya.com/support/t451897-pan...
    Fantastic! I want to thank you so much for this information. My projector had the same defect and I could fix. I'm in Brazil and almost buy a new lamp, which costs a fortune here, unnecessarily. Thank you!
    Problem Solver:
  • 8 Answers
Thanks everyone for this helpful problem/solution thread. Especially thanks to shrike for the detailed textual explanation and thanks to pgram for the youtube suggestion (I'm a visual person, so that helped a lot)). After having this problem (start project with the remote or front panel, it would turn itself off after a few minutes, turn the main I/O power switch off and then back on, turn on the projector again and then repeat and repeat and repeat as necessary) for about 11+ months now (starting at about only 500 projector hours), I finally decided to search the net for a do-it-yourself solution. Between this thread, one other and the youtube video, it was more than enough to easily solve my problem. I simply unplugged/unhooked my projector, placed it upside down on a towel, unscrewed the two screws holding in the light bulb panel cover and removed the cover. Right there, easy to get to, is the brown iris lever assembly. I first tested the iris lever by rotating it and releasing. My lever returned to its original position so extremely slowly! As advised, I used a Q-Tip and 3-in-1 oil. I soaked the Q-Tip and tried to coat as many moving parts as I could. Wa-La, my iris lever now springs back instantly. I never had to lube the upper pivot shaft that shrike mentioned, only the easy to get to lower one. I put the cover back on, hooked the projector back up and, sure enough, it works first time, every time. I also used to have this problem that when my house HVAC cycled on, my projector would turn off! This problem is solved as well.
Here is the youtube video link. Please note that his iris moves perfectly fine even before he applies the lubricant (yours will be much slower if you have the iris problem) and I also recommend lubricating a lot more of the moving parts than just the pivot arm he lubes.
http://www.youtube.com/watch?v=6jGwB05_gdk
Again, thanks everyone. This saves me the $300 repair price I was quoted (mad! >:-[ ) or the $1,000 it would cost for a new PT-AX200U.
- Josh
P.S. When I first contacted projectorpeople (many months ago) about my problem, I was told that Panasonic was aware of the iris problem and had extended their warranty for this reason. I called Panasonic to make arrangements and was told they had just withdrew the extended warranty two weeks prior. :o(
Posted on Sep 21, 2009
    New Friend:
I have the PT AX 100U with 964 original hours. After reading the above threads, it was clear that I had the sticking iris problem. I watched ptatohed's video under solution 3 above and decided, after I called Heartland to check on the repair price ($180 cash and carry), to try this first. I wanted to also lubricate the top iris pivot as well, but I did not want to remove the entire top cover and other thing to get to the to pivot.
It turns out that if you remove the lamp assembly, (follow the lamp replacement instructions), and place the projector on its front, you can see the top iris pivot. (The bottom pivot is easily seen with the lamp in place.) I used a 2/0 artist brush and bent the ferule into a corkscrew shape. I also tried a "U" shaped brush but the mild cork screw shape seemed to work better.Panasonic PT-AX100U-EC - 274d05a.jpg It could easily place a very small amount of 3 in 1 oil on the top pivot. if you can play the game "Operation" you can place the oil on the top pivot without getting any oil on anything else.
I repeated this process 3 times for the top and bottom pivot arms waiting about 5 minutes between applications. I worked the arms back and forth with a q tip to let the oil move down the shafts. After about 15 minutes the sluggish rotation became free and quick. I replaced it in its ceiling nest and so far works like new. None of the power down problems that it had been having.
It will be interesting to see how long it lasts. This is a little bit disappointing as the product was obviously under enginered, but right now the price is right for this repair, (free and took about 30 minutes).
Good luck all and thanks for the help!!
Posted on Jan 26, 2010
I replaced the iris. I used the replacement part from partstore.com. The Panasonic part # is TXZEN01VKD3, replaced by TENC0169. http://www.partstore.com/PartSearch....01VKD3&x=0&y=0
It took me about 3 hours, taking detailed pictures along the way. I have since gone in there again and it takes me about 35 minutes now that I know what I am doing. I have pictures, but no detailed instructions. It's pretty hairy and I have experience repairing some stuff, but not a professional. I wore a static wrist strap as well.
Posted on Jan 19, 2010
Go to youtube.com. There is an easy do it yourself fix for this. 5 minutes, 1 q-tip. Really.
Posted on Apr 06, 2009
I used WD-40 with a Q-Tip to clean it/unstick it and then put a few drops of 3-in-1 on with a eyeglass screwdriver and everything is fine again here also. It took less than 30 minutes including taking it down from the ceiling mount and putting it back up. I don't know how long the new lubicrant will last, but it's been several weeks so far without issue and it's not much bother to lube it up again as long as it's not too short a length of time. I still have dimming issues with the bulb in both eco and normal modes, though. I'm hoping a new bulb will solve that, but given it's so common I could easily get another bad one (maybe it's something internal as well?)
Posted on Apr 07, 2009
    New Friend:
  • 4 Answers
I have the ultimate problem solution to this problem. With the Panasonic Projector. Please call Port City Audio & Video via Jordan Thomas @ 910 538 2754. or e mail @ [email protected] I own a custom A/V business in the eastern NC area. Thanks
- Jordan Port City A/V
Posted on Dec 07, 2009
The problem sounds like the "stuck iris" issue that has plagued this particular model. I found out about it when I received the AX100u as a loaner for my AX200U that is in for service. The loaner worked fine the first day but when I went to turn it on the next day it would shut itself off for a few minutes. I pulled my wiring apart until I researched it on the web. Here is a link that sheds light on the problem. What happens is the unit fails a power up self test when the iris can't open fully and shuts itself down. It seems the unit has to be sent in to have the iris replaced.
Hope this helps!
Gregg
Posted on Dec 04, 2008
Hi.. call panasonic.. this is a well known problem with this model. it has to do with the iris getting stuck. so, they have extended the warranty for this particular problem to 18 months,  Bottom line is, send it in, it will be sent back to you the following week all fixed... we just did it, and are so relieved!
Posted on Nov 28, 2008
    New Friend:
I just finished dealing with this issue, and I have to say it was a fairly easy process. The absolute worst part was taking off and replacing the top cover. I first tried lubricating the lower iris cam, but had to remove the cover to lubricate the top cam. To be honest after I removed the cover I used a screw driver to move the top cam around a bit, I then plugged in the unit and fired it up. The iris seemed to pop right back in to place and the unit started working like new again. I lubricated the cam, and then replaced the top cover which was a bit of a headache. I returned the unit back to it resting place in my home theater and the picture looks better than ever. The best part is saving $200 - $300 on sending it in for a fairly simple repair.
Posted on Mar 23, 2010
Http://www.bigscreenforums.com/forum_topic.cfm?which=6977&p=last
Posted on Jul 19, 2008
Call Panasonic and send you projector to a repair center, the problem is the iris and should be replaced
6ya staff
SOURCE:
Viewsonic projector Pro 8200 will not start / get out of standby mode
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | ViewSonic Office Equipment & Supplies
How do you cool down the system after a presentation?
hi,
To cool down the projector after use just press the Standby button and leave it in standby mode. The projector itself will cool down and will shut down itself. Only after this remove the power.
ok
Mar 19, 2011 | Sharp PG-A20X Multimedia Projector
Why does the projector keep going to standby mode?
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes.
1. Insert the power cord plug into the wall outlet and then
press the MAIN POWER switch.
2. Press the POWER button so that a picture is projected onto
the screen.
3. Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
4. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
5. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, "LAMP RUNTIME
RESET." is displayed and select OK.
6. Turn off the power.
This will reset the cumulative usage time for the lamp
unit to zero.
Mar 12, 2011 | Panasonic PT-AX100U-EC DLP Projector
Miss operation to launch "Control
When the control panel lock ON of the projector so that the projector can be operated only with the REMOTE CONTROL.
If you loos your remote control then keeping the POWER key on the projector control panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you press and hold the MENU key for about10 second when the power is on the lock will be released and "panel key lock" is automatically set to "OFF"
Feb 23, 2011 | Sony VPL-CX70 Multimedia Projector
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
I have a NEC mt1055 and the unit just had new bulb put in here and it has the power and standby light come on and the fan doesn't turn on here and the standby light is yellow and status is red
The NEC’s work on a reducing time basis, they count the hours that they have been operational and refer to this as the life of the bulb – 1600 hours. When the 1600 hours has been reached the projector shuts itself down into standby mode never to be restarted even after changing the bulb / filters. This is because the unit needs to be reset, which needs to be done as follows (not included in any of the bulb replacement instructions):-
  • Plug Projector in so it is in standby mode – Orange light lit, Red status light lit (not flashing)
  • Using the remote control, hold down the power off button for 30-45 seconds
  • This will reset the status button, removing the red light
  • Power up the projector and select Menu
  • Select Projector Options
  • Select Set-up – a number of tabs will appear called pages
  • Arrow across the pages (MT850 is Page 5) until an option called “RESET LAMP HOURS” is shown
  • Move onto this option and press enter on the projector itself, confirm that you want to reset the counter
  • Projector is now back to life
This works for all NEC projectors, the page number may be different though where the “RESET LAMP HOURS” option resides.
Oct 07, 2009 | NEC MT850, MT1050, MT1055, MT1056...
NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
Dec 10, 2008 | NEC LT 240K Multimedia Projector
Reset Lamp Hours Timer
This works on a couple different Toshiba models -- might work on yours...
Make sure the main power switch is OFF. Hold the "ON", "MENU", and "INPUT" buttons at the same time and turn the main power switch on. Keep them held until the yellow power standby light comes on, then let go. It is done.
Oct 13, 2007 | Toshiba TLP S30 Multimedia Projector
Won't power off when pressing power button, just goes to standby mode
With most projectors you have to press the power button twice to confirm that you want to turn it off. When you press it the first time it waits for a bit and then turns itself back on assuming you hit the power button on accident.
Jul 23, 2007 | Compaq iPAQ MP2810 Multimedia Projector
Panasonic PT-AX100U-EC DLP Projector Logo
11,062 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Shannon Murphy
Level 1 Expert
jasbo
jasbo
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
