Protools m-powered problem
My pro tool mpowered 7.3 gives me a DAE error 7401 when I bounce my project. and from that time I can not play the project without the same error message showing up. from that point I can no longer play it.
  • 1,512 Answers
Hi Reidmemusic
There are wide and varied reasons why you are getting this error, it is an indication of a plugin not responidng. Going through and disabling plugins may help you to find which one, and then reinstallation of the offending plugin should fix it. If not, then get back to me here with details of the plugin causing the problem and we shall go further
regards
Graeme
Posted on Mar 18, 2008
SOURCE:
I need an activation code for pro tools 8?
When ProTools is installed on a computer it needs to be authorized to work. This has to be done via a dongle, a socalled iLok . The authorization is done by www.ilok.com. You need a dongle with the authorized registration of ProTools on your computer to make ProTools work.
regards
Mar 09, 2014 | Digidesign MBox2 Mini with Pro Tools 8 LE
I can't hear the sound from my PC when I'm using the mixer. Its hooked up to both the computer and the speakers, but when I'm recording in pro-tools 11 I can't hear any of my playback. I have to bounc
hello. Im not too familiar with Protools (mainly because its a headache right out of the box), but MY understanding is that Protools won't recognize a lot of external audio devices. (such as behringer)
however..if you are able to record and 'see' the audio there, just not hear it, there might still be a solution, & seeing as how i never used protools, it still might just work.
First of all:
if you're using the UCA-200 external usb box connected with rca cables, then my solution SHOULD work, as it is what i did to get mine to finally do the same thing.
#1) you will need to pick up (x2) RCA-1/4 jack adapters . (radioshack, about $2 each)
#2) insert a red and white rca cable in the RIGHT side of the Mixer's CD/Tape out .....the other end of the rca cables will go into the UCA-200 INPUT.
#3) with 2 more cables in the OUTPUTs of the UCA-200, put the rca-1/4 jack adapters on both cables, insert them back into the Mixer inputs 9/10 (in the analog 1/4 instrument inputs)
#4) adjust volumes accordingly, make sure channel 9/10 isn't muted, headphone volume is up, etc..
.......if that didn't do the trick, then you will need to go into the Audio Settings menu on your computer..(or protools) and change the default playback device to your mixer (probably named Generic USB or something similar)
I really hope this helps somewhat, because i remember going through the same thing & it took a looong time to find the correct awnser.
best of luck!
*also*
check for any updated drivers for your mixer! (I personally recommend you do a Google search for Asio4all drivers, they're pretty good)
if your awnser is A), i would suggest going into your computer's Audio Settings menu, and select the mixer as your default playback device.
Nov 23, 2013 | Behringer XENYX 2442FX Mixer
Pro tools key seiral
Serial key for: ProTools 5.0 LE
s/n: CUB BIDS GIBE WARY NODS
hope it helps
Apr 26, 2012 | Avid Liquid Pro 7 for PC
Not able to get my auto tune installed right
Hi, are you using Pro Tools as a host? This may happen if you have old and/or incompatible plug-ins in the Plug-ins folder. In one case, older versions of D-Fi and Maxim caused the error message. The first step is to move your entire Plug-ins folder to the desktop (or to the Plug-ins Unused folder) and relaunch Pro Tools. The Digidesign Plug-ins folder is located in C:\Program Files\Common Files\Digidesign\DAE. If that works, then you need to go through your Plug-ins folder and determine which plug-ins are old or incompatible and either update them or remove them.
If that doesn't work, then it is best to remove Pro Tools and all PACE files completely, then reinstall Pro Tools.
Feb 02, 2009 | Antares Auto-Tune 4 TDM Production Suite
Mbox 2 and new macbook pro
my Mbox isnt being found by my mac. when i try and install protools it tells me the mbox carnt be found. i have tried different usb cables ect but nothing seems to work.
Jul 22, 2008 | Digidesign Mbox 2 Barebone
DELL Vostro 1500 causing many problems...
For using xp you must have the correct drivers. These should be available for download from the Dell support website. You may also find updating windows xp will help you may be using service pack one, so make sure all updates are done.
If you have to load drivers you should load the chipset first followed by the graphics then the sound. Check on your hardware list under system in control panel that there are no conflicts.
I hope this is helpful please rate the assistance given.
Mar 29, 2008 | Dell Vostro 1500 Notebook
I have digi design 001 and I keep getting dae error 9073 on my protools
For those hitting the -9073's, a couple of urgent needs:
1. Please explain what Editing functions you are performing that cause -9073's. BESIDES creating fades, Audiosuite, Consolidating, or TCE Trim (as these all fire off background disk-writing processes, which we've confirmed can indeed cause -9073s.)
2. Open up Task Manager and keep an eye on it to perhaps catch some unexpected background tasks during Editing.
3. Does DAE buffer 4 ease the occurrences? (It does for me on 2 rigs: MacPro quad, HD3 and Powermac G5 dual 2.7, HD3).
Note: Using the "Pause Tasks during playback" (in Task Manager menu) is one method of holding off the -9073's, but it no means to I suggest that as a total solution.
Mar 13, 2008 | Audio Players & Recorders
2488 to pro tools
There is no way to 'sync' with protools from the 2488. In order to use your 2488 tracks in protools you have to first export your tracks as wav files and move them to your computer via usb and then import them into protools.
To get Protools files into your Tascam 2488 you'll have to export your Protools files into mono wav files first. They must also have a sampling rate of 44.1KHz and can be either 16 or 24 bit. Then load these files into your 2488 via usb and import them into tracks on the 2488.
Nov 21, 2007 | Tascam 2488 Portastudio Multitrack...
119 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
