Question about DXG Technology DXG-608 Digital Camera
My digital camera is stuck on a loading screan when i switch from no flash to flash it never gets off the load screan
  • 2 more comments
  • bobenator Mar 18, 2008
    it still wont work for any of the flash options it only works on no flash and i need flash
  • polymers Mar 19, 2009
    I have the same problem...it just arose this past week. Two weeks ago I did not have any problems...now when I try and turn on the flash, I just get the hour glass. IF you find a solution, please post.
  • alexandbj Apr 10, 2009
    Mine's stuck on the "hourglass", too, unless I have it set to NO FLASH. I don't have a cable to connect to my PC, as one user suggested. Help!
  • polymers May 11, 2010
    The camera is loading as long as any flash is selected. THe only time the camera will not do this is when the camera is set to "off". I thought maybe I had a battery problem, so I completely depleted the battery and recharged. Still have the same problem
    Problem Solver:
  • 5 Answers
I found a way to fix this. I used my USB cable, hooked it up to my PC, then powered up the camera. I then selected flash. It took about a minute, but it worked. Now when it is unplugged the flash is working again
Posted on Apr 07, 2009
    New Friend:
  • 136 Answers
Try using a different flash level
Posted on Mar 18, 2008
Garmin nuvi 270 won't turn on
Stuck at the loading maps screen is often caused by a corrupted map or flash drive. The drive must be accessed in order to restore the corrupted map file or flash drive. More information can be found here:
SHARCNET USA Out of Warranty GPS Digital Camera Repair Center
Apr 26, 2014 | Garmin NUVI 270 GPS Receiver
Flash stuck
It sounds like the flash up switch is stuck closed so that even though the flash is down the camera thinks it is up.
Slide a business card under the left side (the rewind side if you are old enough to remember film cameras) of the flash when it is down to free the latch and remove the two screws on the bottom of the flash so you can pop off the cover. You can then see the switch on the release side of the flash at the pivot. The flash up switch contact that looks like a crooked finger should be above the post. Gently reposition it and check the action of the switch by manually freeing the latch.
Be very careful. There may be over 300 volts across the two wires that are soldered to the flash tube. If you touch them you will get a nasty shock.
May 07, 2013 | Nikon D3100 Digital Camera
There are black spots on the viewer screan. What is the fix?
I dont know wheather the black do t is coming in your picture also (after down loading you can seee) if yes you hace to clean your ccd/filter etc. If the dot not coming into you picture then you have to clean ur LCD.CONSULT A CAMERA DOCTOR.
Feb 12, 2013 | Samsung DualView TL205 / PL100 Digital...
I am getting this message on my EOS 450d, (camera's built in flash pop up was obstructed turn the power switch to off and on again). I have done this several times the flash wont pop up - can you please...
Sometimes the pop-up flash on the EOS range of cameras can get stuck. The EOS family have a very tiny micro switch under one blade of the flash hot-shoe.
Get a toothpick and manually pop the switch. It should clear your error, too.
Good Luck.
Mar 28, 2011 | Canon EOS 450D Digital Camera
Err message on D70 and clock flashes
D70..err display...problem with the loader section switch,rotating while loading is open,so get it repaired.
Mar 07, 2010 | Nikon D70s Digital Camera
How to down load macrmedi flash from internet?
You can download Adobe Macromedia Flash Player here >>>>>>
http://get.adobe.com/flashplayer/
Regards.
Jul 29, 2009 | Sony Handycam DCR-HC36 Mini DV Digital...
Problem with slr camera flash obstruction
The problem is in the flash pop up switch. It is probably jammed in or there is some kind of substance on it causing it to stick. You can find it by manually popping up your flash. You should then see a little black spring loaded post on the release button side of the flash. Check to see that it is not stuck in in any way. If so that is why you are getting error 5. To repair you can try a qtip an a little rubbing alcohol. Otherwise you will need a technician to do it.
Dec 04, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Problem with loading cassette
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 13, 2007 | Canon Optura 200MC Mini DV Digital...
DXG Technology DXG-608 Digital Camera Logo
96 people viewed this question
Top DXG Technology Cameras Experts
Jerry Greenberg
Jerry Greenberg
John Anderson
John Anderson
Are you a DXG Technology Camera Expert? Answer questions, earn points and help others
