Question about Compaq Armada M700 Notebook
Laptop shuts down
My M700 will boot and after running a while it will shut down. Sometime it may run for 20 minutes and sometime it will run for a few minutes. I've taken the battery out and it still does it.
  • Anonymous Mar 22, 2008
    My Armada M700 Shutsdown after 20min. I already replaced the processor fan but still the processor is over-heating. The processor is built-in 750MHz. Everytime it shutdown, i always check the processors heatsink & found-out very hot! I put new sillicon paste on processors HSF but still overheating. What's maybe the best solution for this? Thanks in advance to all...
    Guru:
  • 377 Answers
Hi dear
test running in safe mode
or you can check your processor temperatur
oke
Posted on Mar 19, 2008
    New Friend:
  • 136 Answers
Check the timer setting and set it to always on
Posted on Mar 18, 2008
SOURCE:
IT WILL STaRT , RUN FOR 1 MINute AND SHUT OFF BUT WAS rUNNING WITH COVER OFF BUT NOW HAS STOPPED THAT IT WILL RUN FOR 20 SEcONDS AND SHUT OFF
What would cause 1995 Chevy blazer to run for 20 minutes ...
answers.angieslist.com > Auto > Auto Repair & Service
Mar 30, 2014 - For example, can you start the car cold, it will warm for 20 minutes, and shut ... While not a car, my Motorcycle (also fuel injected) would run for a little bit and shut off. The issue ... Answered 1 year ago by WoWHomeSolutions.
Car starts and it shuts off/loses power - CarGurus
www.cargurus.com > Questions > Audi > A4
CarGurusJun 20, 2013 - Car starts and it shuts off/loses power - I have a 2003 Audi A4 Turbo.93K on it. ... \n check out these few options 1. loose or faulty electrical connections at, .... After drying it for a few minutes and cleaning with a dry cotton cloth, I have ... you can't fill your car while its running the gas tank is a vacum while its ...
Car starts then dies in a few seconds - CarGurus
www.cargurus.com > Questions > Ford > Crown Victoria
CarGurusFeb 3, 2014 - Car was running fine, and then engine stops. ... 1 out of 1 people think this is helpful. ... my car will start run for a second an shut off . ... under load, dies,starts 15 minutes later, runs fine then stumbles and dies again 3 answers.
Chevrolet Silverado 1500 Questions - Engine Shutting off ...
www.cargurus.com > Questions > Chevrolet > Silverado 1500
CarGurusMay 20, 2015 - Engine Shutting off after about 10-20 seconds on 2004 Silverado ...When the engine is hot, two things occur: (1) thermal effect on .... my 2000 chevy silverado just randomly die then it will start back up idle .... It will run fine for 15minutes. ... run down behind or beside the powersteering pump, that the car will ...
Jan 06, 2016 | Cars & Trucks
Wipers do not shut off all the time on delay they sometime run regular and won't shut off for as much as 45 minutes
ask around other owners but i think your switch is falty 9 years old not much of a job to fix 1 hour 2 if you know nothing about it
Apr 27, 2012 | 2003 GMC Yukon XL
Laptop shuts down after 20 or 30 minutes with one
Please refer to manual and run system restore to system default settings as if it was from the package.
Cheers.
Jan 24, 2010 | Dell Inspiron® 1501 (N11157) PC Notebook
Laptop shuts down at random times it sometime shut dowm within 5 minutes i use or can stay on allday but now it shuts down within like 20 minutes of use.please help
I THINK ANY VIRUS MAY BE IN YOUR SYSTEM. PLEASE FULL SCAN YOUR COMPUTER THROUGH A GOOD ANTIVIRUS. IF PROBLEM REMAINS SAME THEN YOU HAVE TO CHOOSE FORMAT WINDOW AND THEN REINSTALL WINDOW.
Sep 30, 2009 | Sony VAIO VGN-AR630E Notebook
When i on the system, the fan is not rolling, sometime when on and boot upto the the window evironment, its shut itself down. what could be the possible problem with them
Please Check CPU making any noise or not.
remove the CPU side door and check Fan is rotating on Processor if not it may not rotate due to heavy dust inside. ( clean it and refix it)
Check SMPS Fan is rotating or not..
If fans or not rotating Heat Builds up then computer shuts down itself.
If both fans are working...Just Open BIOS window by press DEL button continuosly while startup and wait for 2 to 3 minutes If the computer shuts down Itself in BIOS Window also then we can confirm issue with Hardware.
If Computer not shutting down in BIOS Window then issue with Operating System Boot files corrupted.
While Turn ON the system press F8 to enter in Safe Mode.
Open command prompt by clicking on
Start >. RUN >> type cmd >> then press enter.
now type chkdsk /f
now press Y
then reboot PC it fixes the Boot files error then your PC works perfectly.
If you still exp same issue let meknow..
Feb 18, 2009 | HP Pavilion dv6000z Notebook
T23 Thinkpad turns off during boot after restart
My guess would be ;-
A power supply problem with the battery and/or power adapter
The most likely one.
The CPU is overheating and shutting down and if you wait a while and it will power it up again, it will then run for a while and shut down again.
This can be caused by a faulty fan (its not spinning and needs to be replaced) or the vents are clogged with dust (needs to be cleaned and you may need to remove the fan assembly to do this).
Jan 27, 2009 | IBM ThinkPad T23 2647 Notebook
Touch pad is on fire!
same laptop but intel core 2 duo, and I got the same problem , my touch pad is very hot sometime and I have the cooling fan underneath the laptop it's help! and after that like couple weeks later my laptop was death it wasn't boot the vista. it shown the options like 1. fix the ..... 2. start normally.
when I choose No.1, the screen turn BLANK all day and nothing changed and I power shut down and choose No.2, then it boot!! But the programs were not boot well and stuck like not completed. SO what's wrong with it???
Aug 04, 2008 | Toshiba Satellite A135-S2386 Notebook
IBM Think Pad T22 auto -shut down a few minutes
Try running it without the battery. Sometimes an IBM battery can develop a short and cause this. If it still does it without the battery, I'm afraid it's the power management chip on the motherboard, and the motherboard will need to be replaced.
Jul 10, 2008 | IBM ThinkPad T22 2647 Notebook
Shutting down without warning
dear darios
its not normal that the fan stop.
plz check your powersupply unit.
Jun 17, 2008 | Compaq Armada M700 Notebook
Compaq Armada M700 Notebook Logo
122 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
