Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi WS-65513 65 in.... blinking light
The led light on the front of the tv just blinks my e-mail address is sagen@aol.com thank you
  • 927 Answers
If you are still having this problem, the tv has a bad DM board there are four caps on that have gone bad. It is cheaper to have the board repaired then replacing . Call a local factory authorized dealer, it should cost around $400.00 to repair.
Posted on Apr 03, 2008
Front panel light just blinks
Hi Sharon,
Blinking of the LED at the front panel has an equivalent error code to give an idea what's going wrong to the set. Please check if there's a pattern of blinks, number of blinks separated with a pause or if the led blinks green continuously.
Jdvillanueva
Jan 05, 2012 | Mitsubishi WS-65819 TV
Tv problem
can you tell in what patter does the light blinks??
Mar 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
My mitsubishi tv ws 65611 won't turn on. light keeps blinking on and off on the front panel and what is the mitsubishi customer service relation web address
the common fix for the " mitsubishi blinking green light of death " on this model is replacement of electrolytic capacitors on the "DM module board"
this is thier customer care:
telephone : 800-332-2119
E - MAIL : CustomerCare@meus.mea.com
Mar 31, 2009 | Televison & Video
Blinking timmer light mitsubishi 1080
Video instructions for repairing Mitsubishi WS-55859 HDTV:
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
You can find the parts (capacators) at Radio Shack for appx. $2/each.
Jan 18, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Aug 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Need a repair solution e-mailed
Good Day, jnjetsn;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-55513 blinking power light
The infamous flashing green LED problem is usually due to a failing or faulty DM board. I purchased the PDF manual online and was able to locate and remove the components as necessary.
If you can solder, and are semi-proficient with electronics it is 4 bad capacitors on the DM board...
Otherwise there are facilities that can repair your failed board for about 275.00 or replacement of the board is between 350.00 and 500.00 buck USD.
Good Luck with your repairs....
-Richard (MetalDad)
email: PentiumDreams@aol.com
May 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Please study the procedure at the following address.....
www.chrisandnat.com/projects/blinkingtv/blink.htm .....
use 1000mf 25v or 35v 105 degree capacitors to replace
original four 1000mf 16v..............if new ones are a little
too high,just lay them over on board........
Look it over..........let me know......................T.
Jan 07, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Green led light on for 3 seconds then off, will not power up
Blinking Problem
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
Dec 15, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
50 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
