Question about Nikon COOLPIX L3 Digital Camera
Lens error i brought my camera to the beach and sand got on the camera. i got a majority of the sand out, but the camera continues to say "lens error". help!!
  • smith_kamesh Mar 23, 2009
    i took my camera to the beach and a little sand got on it in my beach bag. i cleaned it but it still acts weird. it comes on but a few seconds later in just goes back off. what do i do?..i thought about using one of those air things that you use to clean a keyboard... is that a bad idea?
  • 797 Answers
The very smallest piece of sand will jam any digital camera lens. You should be extremely careful to never allow sand to get anywhere near any digital camera. The gears are very small, thus the smallest piece of debris will do a lot of damage. To remove all the sand in the gear train is a time consuming effort. It has to be completely taken apart to do it right. You will need a good magnifing lens as well. That may also affect the ccd and alignment. Sometimes it it worth it.
Posted on Mar 18, 2008
SOURCE:
The lens makes funnny noises and will not go back into the camera. a lens error message also comes up on the screen. I have used it on a beach recently, so could it be to do with sand getting trapped? any...
It is quite likely that sand or some other particle got lodged in the lens mechanism. You can take it to a camera store that services cameras and have them clean it.
Jul 29, 2011 | Nikon COOLPIX S230 Digital Camera
Lens error.....restart camera. Tried over and over again. Nothing works. HELP!
Went to the beach yesterday, by the end of the night my camera gave me this error: "lens error, restart camera". The lens would no longer come out.
I figured sand got stuck within the lens, so I did the following:
1. Turn camera up-side-down (with lens facing down)
2. Gently tap the sides of the camera (to loosen particles in lens)
3. Turn camera on
4. The lens will eventually come out
5. Gently tap the sides of the lens
6. Turn camera off (continue tapping side of lens as it retracts)
I turned the camera on and off a couple of times to ensure I removed all sand particles from the camera.
Now the camera works...thank god....
thanks.
Apr 11, 2011 | Canon PowerShot SX10 IS Digital Camera
I just had my camera closed and in a bag, unfortunately the bag had some sand in it from the beach, and now I'm getting the lens problem warning sign! Does interaction with sand while the camera is...
Really bad news.
The sand can caus lens and internal problems since there are moving parts which have grease on them.
Repair is recommended.
You can sell the camera on a site such as Ebay as a used for parts camera.
You can consider repair.
Cost will be a determining factor here.
Sep 07, 2010 | Nikon Coolpix S210 Digital Camera
Camera lens will not come out all the way, and the screen says to turn camera on and off again. and absolutely nothing happens.
I brought my cybershot 7.2 to the beach, and stupid me did not have it in a proper camera case, and I am sure that a grain or two of sand got into the zoom lens. I used a sewing needle to no avail to try to probe this out, and in the end all I did was use my fingernail to help pull the zoom lens out, when turning the camera on, this worked perfectly after a few try's and the camera is now functioning as good as new.
The grain(s) of sand were obviously preventing the motor from opening the zoom lens.
Hope this helps.
Steve
Oct 10, 2009 | Sony Cyber-shot DSC-W70 Digital Camera
Lens Error
As a camera repairman, I can tell you that even replacing parts, you will never get all the sand out and it will most likely continue to give you problems.Sell it for parts on ebay and buy a working one.
Aug 29, 2009 | Nikon Coolpix S210 Digital Camera
Lens error was at beach no sand but yet when turned on it says lens error
Anyone who has ever been near the beach knows that as soon as you are within 100ft of the sand you will feel sand in between your toes even with your sneakers and socks on. That's because sand is in the air and contaminates everything. Therefore, if you value your camera, mp3 player, radio, cellular phone PDA, or laptop computer, DO NOT TAKE IT anywhere near the beach. Solution: use an air compressor. Blow air & dust through the hose first. Use clean air to blow out extended lens area. Open and close lens and blow out several times. Firmly jolt the camera into the palm of your hand to dislodge the dirt particle. Use more air. You may notice sratches on the side of the lens cylinder that were created by the particles of sand. 99% pure isopropyl alcohol (91% if you're in a pinch is available at any drug store) can also be used on a Q tip and swabbed around the lens barrel cylinder. Make sure you use a few CLEAN Q tips on the lens. Now go buy a disposible camera and $10 mp3 player for the beach and leave the $200+ camera and IPOD at home or at the hotel room. Now you'll surely have a wonderful time at the beach.
Jul 28, 2009 | GE A730 Digital Camera
Lens error. restart the camera
Did you drop your camera? the lens mechanism might be jammed,Did you brought it from the beach? It might have some dust or sand particles inside the lens. Have You changed the batteries? It can also be caused by poor battery.Please recharge battery or change new alkaline batteries. this website might also help you.
Dec 13, 2008 | Canon PowerShot A710 IS Digital Camera
NIKON L15 LENS ERROR
Lens errors, must be fixed by a camera repair shop. They are usually caused by impact of the lens with an object or sand from a beach. Repair estimates range from $50 to $100. Get a new camera if it is closer to $100. Suggest a internal zoom lens like the Fuji Z10fd.
Mar 19, 2008 | Nikon Coolpix P1 Digital Camera
Does it need regular cleaning?
Sand generally has no effect on the electronic side of the camera, however it will definitely can cause problems with the mechanical aspect of the camera such as the zoom lens. this can be removed with a can of compressed air.
Suntan lotion likewise should not be any problem except for smudges on the housing/casing and especially bad for the lens. Additionally, the lotion would help the sand adhere to crevices and nooks of the camera. Wiping should get you just fine.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Feb 17, 2008 | Canon PowerShot SD600 Digital Camera
Lens error, restart camera
Your Camera is full of sand and you can try blowing it out and banging it out. But I'd say it's time for a new camera. Regards Thestreeker
Sep 18, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Nikon COOLPIX L3 Digital Camera Logo
213 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
pictureman4u
Are you a Nikon Camera Expert? Answer questions, earn points and help others
