Question about Panasonic PT-53WX42 53" Rear Projection Television
3 blinks i know nothing about repairing those..how much do u think a tv guy is gonna charge me to change those out?
  • Panasonic Master
  • 8,617 Answers
Between 200 and 400 maybe more, depends on the integrity of the repairman.
Posted on Mar 18, 2008
SOURCE:
Panasonic tcp42x1 non stop blinking no powerup
It sounds that the main digital board has the fault. Non stop blinks of standby LED indicates that there is no serial clock, serial data flow. In other words, Bus circuit is blocked. This bus is generated from the main system control IC on the main board. As you know, there is no repair to this main board. Only replacement can be done as card basis.
Jul 07, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
I had the sears repairman out to look at my mitsubishi WS 55511 rear projection tv. My TV will turn on for about 5 seconds and then shuts off. He felt it was the convergence IC (I think this is the part...
Is it this STR-F6628 or the G? And 23 is horizontal deflection, but that means it could be in this circuit, you have to check shorts, if it's the For G I have them.
Feb 17, 2011 | Televison & Video
JVC LT-32P679 Blinking Power Light, Automatic Shutoff
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
Mar 17, 2009 | JVC LT-32P679 32 in. LCD TV
Mitz ws-55859 tv
Was the symptom a steady blinking green led/ If so you most likely need just the DM repair kit thats 35.00 and comes with the instructions on CD and the replacement capacitors that repairs the DM module. I can post a link for the repair kit if you would like?
Jun 24, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Charging of the casio exilim battery
Blinking light means charging error. Call tech support and they will replace battery for you for free.
Nov 22, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
No picture, just went off while watching tv
The pink lines in the set happened when the first time it blew out. It is called a burn in on the inside surface of the picture tubes. Not the fault of the TV repair guy. This is the fault of Toshiba. This set has known to have this happen and you should contact toshiba and request that they replace all three tubes for you at no cost. You should also stop using these repair guys who cannot fix a simple vertical problem. Find out who is authorized for Toshiba in your area and call them. They will know, or should know the problems that happens with this model number and take care of them once and for all. Good Luck
Nov 06, 2007 | Toshiba 51H84 51" Rear Projection...
Repair shop says Flyback Transformer needs replacement
If you know what you are doing, and you have a good (de)solderstation, you can repaire it yourself, but you don't know if it for sure the transformer. since you did not find the problem yourself, suppose you replace the transformer and your TV does not work !? Even when you repair it yourself, the repair guy shall charge you the cost for his time (I don't know the exact english word for his time checking the TV). And I suppose there is a warranty for his repair. So...
Sep 11, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Comes on for about 3 seconds and then shuts off!
I have the same problem: It seems the high voltage trasnformer blew which in turn casued the pin cushion?? to blow. It then shuts the tv off to prevent more damage to it. Gonna be about $500 with service charges to get it fixed!
Sep 09, 2005 | Panasonic PT-47WXC43 47" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
26 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
