I want to mount my frontloading clothes washer on a pedistal, but it is too heavy to work with. I would like to remove the counter weigh so that I can lift it more easily.How do I remove the front cover without damaging it? Is it difficult to remove and replace the rubber collar?
    President:
  • Washing Mach... Master
  • 2,651 Answers
NO NO NO dont remove the counter weights. get some help, you need to lay machine over and install the pedistal under machine first, then stand the machine up CAREFULLY lay machine over on back
Posted on Mar 18, 2008
Washing machine starts washing then stops mid cycle
The clothes become very heavy once water is added. Please try remove some of the clothes to reduce weight Karen. Thank you and let us know if this helps? Leave feedback
Jul 12, 2016 | Russell Hobbs RH1042 Frontload Washing...
Code ul
I move all the clothes around in the washer, leaving the center exposed. Sometimes it's just that a heavy towel or sweater has weighed one side down.
Dec 13, 2011 | Maytag Bravos MTW6600T Top Load Washer
Grease looking stains on clothing after washing in front load washer. Not on all clothing just certain items. Normally notice it on darker colored clothing.
that is leftover soad and down that is building up inbetween the inner and outer tub .....
frontload washer tend to wash in cold an d luke warm water down and most softner detergents are mader from animal fat means it not getting washed away so it cakes up and eventualy this cake deosit get heavy enouhk and fall and fet redeposited on yoour clothes ..... make sure you are using high efficiency soap and run a clean cycle every month with the hotest water cycle with a afrresh tablet for front load washers
Jan 24, 2011 | GE WSXH208A Front Load Washer
How do you remove top of new washer so dryer will sit on top?
There should be 2 screws at the rear of the top section. Remove those screws and pull the top backward and it should come off.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
I need pedsteal brackets for my Lg washer
the side brackets/screws/manual should've been included. some of the new pedistals no longer use side brackets though. contact lg with pedistal model# located in drawer and research further.
May 07, 2009 | LG WM-2277HW Front Load Washer
How to remove pedistal from machines
lay the machine on its back. unbolt the base. 4 bolts. then set the duet back up. Its pretty easy to do but it takes two people to man handle the unit because it is so heavy. Please leave feedback if this helped.
David
Jan 14, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
I have a Whirlpool front load washer wfw8400tw02. I have had 2 service calls to checkout the out of balance condition. The first tech moved a drain hose inside the machine. The second one tried leveling...
being level is not quite as important as being solid on floor or on solid floor..if on a pedistal remove bottom drawer and be sure all mounting screws are tight ..with drawer adj all legs up until they are up tobottom of pedistal ck washer by trying to rock if movement detected adj FRONT feet only as much as needed to reduce motion ..same applies without pedistal if is a noise issue more than an unbalance issue suspect shocks supporting tub try removing bottom panel and being careful allow unit to run and try with one hand to isolate which shock..changed 1 friday
Dec 08, 2008 | Whirlpool Washing Machines
Pedistal
Make sure the dryer is mounted high enough for you to open the lid and it is not too high that you can't get clothes in & out. Apart from that enjoy the extra space :)
Jul 27, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
