Question about Cameras
LCD not functioning - Cameras
  • shudder Mar 23, 2008
    The camera is a Canon A540. It had been working fine. One day when I tried to use it the LCD display was not functioning. Pressing display did not fix it. If I put the mode switch in the download position the LCD functions normally and I can see the images normally.All of the function data displays on the LCD but no image.
    Genius:
  • 1,913 Answers
Hi
check your image;s file type either jpg or tiff and also check their resolution.
Posted on Mar 23, 2008
  • kishor khatri
    kishor khatri Mar 23, 2008
    hi your lcd supports jpg file format
  • 790 Answers
Hello shudder ,
Try leaving the battery out for 10 minutes. Try also removing the external memory. Turn on and off the camera with and without the external memory.
  • Cameras Master
  • 19,396 Answers
Lcd ribbon cable may be out of place which is make and model?
Posted on Mar 18, 2008
  • Ginko
    Ginko Mar 18, 2008
    Check first that the camera shutter is opening and the cap in front of the objective had been removed.
    Also remove camera battery and put them back in place, so that in this way you reset your camera
    If the above does not work the lcd cable may be out of place, or the display to be changed
    regards
SOURCE:
I have my G60 laptop connect to an LCD projector. I wanted to turn off the screen on the laptop and hit Function F4 which i have done in the past and it took the picture off of the LCD projector and now...
Disconnect the cable that is connecting the laptop to the projector. Sometimes this will happen if the projector or device you're connecting your laptop to does not support the current resolution that the laptop is displaying. Reconnect the cable and try using Function F4. If that does not work then disconnect the cable from laptop to projector, reboot the laptop then repeat connecting it to the projector and pressing Function F4.
Feb 23, 2011 | HP G60-120US Laptop
How do make the flash work?
Good day, click the link below and download manual. hope it will help to your problem.
users manual
thank you.
Jul 26, 2010 | Vivitar ViviCam 8025 Digital Camera
LCD on my 2001 gl1800 doesn't show radio function and tune knob doesn't work
the LCD has several other functions that work right? So the radio fuses may need replacing.Also try to press and hold the radio - audio button for a few seconds and test for other radio band function,like wx or am and fm2.
Apr 02, 2010 | 2003 Honda GL 1800 Gold Wing ABS
LCD backlight not functioning.
dear, chek the brightness of ur cell if its is full and ur LCD lght is not functioning so open ur cell and press the LCD strip properly if problem presist so change ur LCD.take care bye
Mar 03, 2010 | Nokia 1680 Phone Unlocked FREE 1GB
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
No LCD connectivity
Hello, I am using a Viewsonic lcd projector with my new Acer Aspire One. I did not have connectivity off the bat. Here's what I did: 1. Downloaded driver (unsigned, not the signed version worked - ie not os-specific) for the lcd projector to the Acer. Restart Acer. 2. With lcd projector connected to Acer, toggle function key & F5. But then, continue holding down the function key. A screen pops up with icons for laptop, laptop/monitor, dual monitor, and lcd projector. You continue to hold down the function key and then press the F5 key to move to the desired device. I had to repeat the same process to restore my Acer screen to the original proportion when not using lcd projector. I'm not sure if both steps 1 and 2 are necessary, but I did it simultaneously, so I'm not sure of the origin of success.
May 22, 2009 | Acer Aspire One PC Notebook
Ilo LCD screen Burn
Replace - not repairable
Feb 29, 2008 | iLO (2 GB) MP3 Player
No display on lcd screen
Hai First check other functions, If all the functions ok then LCD ribbon cable may be defective, replace LCD ribbon cable. best of luck udupi Prathiksha Electronics Bangalore
Mar 10, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Zire 71 collected moisture
The digitizer function reads from the input of the LCD touch screen, so I would say LCD.
Dec 22, 2006 | Palm Zire 71 Handheld
Cameras Logo
32 people viewed this question
Top Cameras Experts
Ekse
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
