Question about Amana DLE330RAW Electric Dryer
Amana Dryer I have a Amana dryer s/n either LK15980 2 or PLE8217W2, those are the only nombers I saw on it, it did say Heavy Duty Dryer, any who... It has a three prong hook up, and my wall outlet is a 4 prong. The terminal block is not color coded, it just has a 3 metal pieces that are gold / silver / gold. Then there is a little green wire screwed down off to the side. The old 3 wire plug that I took off is not color coded either. I bought a 4 prong cord, and I just need to know what color goes were and what about that little green wire. PLEASE HELP!
  • Karen Diaz
    Karen Diaz Jan 10, 2009
    trying to hook up the 4 wires. don't know which 1 goes where
The red wire goes to the right hand side and the black goes the the left. The white wire goes connected to the middle. The green wire is the tricky part. There are two gree wires in this washer apart from the one on the cord. Disconnect the green wire closest to the other three wires and join it with the green wire on the four prong cord and screw it back in. That's all.
Posted on Oct 20, 2008
    President:
  • Amana Master
  • 2,651 Answers
There should be instructions on the cord that you purchased. if not here it is, on your dryer, the 3 prongs are L1-N-L2.. and the green is a ground L1 line 1, L2 line 2, and N nuetral. L1 and L2 dont make a diff. as long as the whie(nuetral) is in middle terminal and the green screws to hte ground screw
Posted on Mar 18, 2008
AMANA HEAVY DUTY DRYER model #NDG2335AWW
m ost likely one of the rear drum support rollers is bad. the part number is 37001042.
Mar 21, 2012 | Amana NDG7800AW Gas Dryer
Hello, my dryer isn't really drying my clothes.it turns on but not normal sound when it goes on.
Hello there and thank you for choosing fixya
Here is a list of things that normally go wrong and need to be checked with a meter ok tbirdfan1_85.jpg
Apr 24, 2011 | Amana AMA714840 14" Cut Off & Crosscut...
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
My Amana Heavy Duty Dryer will not heat up. It tumbles but it doesnt warm up. WE have cleaned out the the machine and the vent to the outside.
You didn't state if it is a gas or electric dryer. If gas the igniter element is bad, if electric the heating coils need replaced. Goodluck Google burdfrenzy
Nov 26, 2010 | Amana Dryers
Belt worn out - need to find the model number: amana heavy duty gas dryer - limited edition
you gave the model number it's NDE6800AYW,the belt part number is 33002535 and it's around 25 bucks
Jul 31, 2010 | Amana NDE6800AYW Electric Dryer
My Amana heavy duty dryer will not get hot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 05, 2010 | Amana NDE6800AYW Electric Dryer
I have the heavy duty 4 cycle Amana dryer. When I turn it on it is very loud and stops after about 20 minutes. It smells really hot so maybe it's overheating? But why?
sounds like motor bearings are failing. causes motor to overheat and cut out on motor protector. I'm afraid a new motor is in order.
Jun 15, 2010 | Amana DLE330RAW Electric Dryer
I have a gas Amana Heavy duty dryer LG5309w it starts and after 5 minutes it shuts off...any suggestions?
If the dryer has a sensor dry function, look inside the drum and locate the moisture detector. It'll probably look like two metals bare. Clean it real good with rubbing alcohol. If that doesn't fix your problem you'll need to work on the dryer.
Oct 16, 2009 | Amana DLE330RAW Electric Dryer
Amana dryer
If you have voltage across the heating element and it does not heat, replace the element. If you have no voltage, trace it back to the thermostat and control board.
Oct 02, 2017 | Dryers
Amana DLE330RAW Electric Dryer Logo
276 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
