Question about Dacor Epicure 30" Double Wall Oven, Stainless Steel - E0230SCH Electric
Cleaning the air vents
What is the best way to clean the air vents in the ovens? I haven't found a vacuum attachment that's thin enough to fit through. Additionally, I think if I unscrew the front panel, I'm going to run into control panel problems. Any help is appreciated!
Thanks!
    President:
  • Dacor Master
  • 2,651 Answers
Clean the air vents??? building up with dust lint and such??? the vaccuum os good try using a baby bottle brush or an old toothbrush to get al trough the grooves
Posted on Mar 18, 2008
SOURCE:
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
There is always a yellowish staining on the top part of the oven door, door handle and vents after self cleaning. I've tried bleach, sos, Mr. Clean Magic pads and it barely removes it. What do you...
the yellowish "staining" is a result of a bad seal. Since it is heat changing the color of the surface, you would probably have to do some damage to remove the discoloration, either like a soft abrasive scrub or other, bleach will not fix that.
Sounds like the cleaning cycle could be too long or otherwise too hot for too long? Perhaps a wipe down with a damp cloth to the interior of the oven prior to a self clean to remove any loose material may help.. Also if there are any other vents for this oven (say under one of the burners of the stove top) make sure they are kept free and clear of any blockage of air flow..
Best regards
Ck
Mar 12, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
My gas range/oven emits a toxic smoke that burns our eyes WAY different than spilled food. The smoke comes out the right side vent rahter than the usual left side vent and only when we cook higher than...
When the oven gets dirty and you don't run the clean cycle, dirt builds up and burns away the hotter the oven gets. Run the clean cycle if you have a self clean mode on the oven. throw the metal burner and grates in the oven too. (no plastic) open a window because it will stink and it takes a few hours to run. If not, use oven cleaner then run the oven to the hottest temp for at least 1-2 hours to burn the old dirt out..
Good Luck, Bill
Jan 07, 2018 | Ovens
Have an oven i need to replace I blieeve it is 4 wires at the back of the oven with no external venting. The opening is large enough for a 27 or 30 inch oven. Is it as simple as pullout the old one...
if its electric its hard wired to your home power 220v black(hot 120v) white(neutral) red(hot 120v) green (ground) You should wire the new oven the same way as the old oven (Shut off power before any thing)Make all wire conections clean and tight with a wire nut. wrap each with ele tape.
Dec 23, 2009 | Ovens
Have a maytag super capacity plus oven i tried cleaning the oven now the door will not open and it shows f9 on the front
Had the same problem. How I fixed it, was by using a very thin, and I mean really thin, flat tip screw driver and a flash light. Unplug the stove. Use the flash light to look at the very top of the oven door. You should see in the air vent slats a silver hook. Use the screw driver to go through the vent slats and push the lock open. Now, you should be able to open your door. But we arent done yet. With the door open, plug the stove back in. Close the door and wait for the F9 to flash. Now open your door, and on the right side you should see a tiny peg sticking out on the open oven. Its for the light to come on when the oven door is open and also to let the oven know the door is ajar. Push it in and wait. The door latch circuit should reset like normal, and you will see the latch move back into its normal open position. Which resets the F9 error and allows you once again to use your oven like normal.
Dec 20, 2009 | Maytag Ovens
Do I need to vent to the outside?
Hello, No you don't need to vent outdoors, and YES all you need is a electrical supply. **I will add however, allow for an air cushion around the unit when it's installed in the wall as well as a vent or small gap with maybe a custom grill at the top. One of the most common service calls I get for self clean built in ovens is reseting or replacing safety thermostat's. Hope that helps Good Luck :)
Nov 01, 2009 | Ovens
My frigidaire ES400 gas range is giving off a sooty smell and high levels of CO that fluctuate from 23ppm - 118ppm (FD CO METER). what is the possible cause and how can it be repaired?
Air intake needs adjustment. Remove bottom drawer, there is a gas valve and the burner attached to it. Loosen small screw on the burner and turn the air baffle to let more/less air in. If not sure what you're doing - call a repairman.
Also make sure not to cover any vents on the oven bottom with foil, as some usually do.
It also can be that the burner holes need cleaning
Oct 13, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do i clean the glass window, i have grease stains on glass window. i know soap detergent will not be enough... what do recomended??
simple green. it's non-toxic and biodegradable, so it's ok to use around food, and it works graet on heavy grease. but if all else fails, use easy-off oven cleaner.
Aug 06, 2009 | Whirlpool RBS305PDS Electric Single Oven
Cleaning between double glass oven door
Without disassembling the door, you can't. the glass is sandwiched between two rather rugged metalized gaskets to create an air pocket (or vent space) to keep the outside glass cooler than the inside.
Feb 04, 2009 | Ovens
Oven won't heat.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
Dec 08, 2008 | Dacor ECS130 Epicure Electric Single Oven
Ovens Logo
117 people viewed this question
Top Dacor Ovens Experts
Tyler T
Level 1 Expert
Jaime Hernandez
Paul Bade
Are you a Dacor Oven Expert? Answer questions, earn points and help others
