Question about HP iPAQ rx1950 Pocket PC
How do I send my pictures to the memory card?
Have a 4mg card and can not seem to send my pictures to it from the std iPAQ memory. Appreciate your help. Great site - glad you are out there!
  • HP Master
  • 13,434 Answers
Hey, one way is to connect your pda into your pc and use windows explorer to find your picuters and move them to the sd card. Or you can try useing the build in file explorer to locate your images, select the ones you want, press and hold the selection, press copy. navigate into the sd card and press edit - Paste.
Posted on Mar 18, 2008
SOURCE:
My new camera does not work. i have taken approx 4 or 5 pictures on it and then i put a 4mg card in the camera and now it at top of screen internal memory is full. i took the card out and it still says...
Hello Donna
Thank you for using FIXYA!!
OK, the problem is most likely that the internal storage(NOT the memory card) is full, hence only 4-5 photos. What you need to do is to remove the memory card from the camera, then connect the camera to the computer via the USB cable.
Once you have connected the camera, copy the photos from the camera to your computer, once you have done the copy process, you need to delete the photos off the camera.
If you have competed the above instructions, you can insert the memory card into the camera and the problem should be resolved.
Please do no hesitate to let me know if you do not understand, or have any questions, i will gladly help.
Kind regards
Lock123
Feb 20, 2011 | Cameras
My hp ipaq hx 2790 don't read the memory cards
Are the memory cards of similar size to what you have used before? Some large capacity ones cannot be used. Have you used a memory card before in this device so you know it was working?
Jan 08, 2009 | HP iPAQ HX2790 Pocket PC
Sansa scandisk fuze 4mg wheel will not rotate continued
connect your player to the the pc and double click on MY COMPUTER and then you will see a external memory icon beside your cd/dvd drive.Just right click on it and click on format.
Aug 22, 2008 | Audio Players & Recorders
HP ipaq with navtec gps software and sd card fails
Ok, nice job Robert,
I'm posting your solution here to remove it from the unsolved problems list.
Solution by Robert:
This problem was finally resolved as a corrupted map file on the SD memory card in the hp ipaq 5550. Solution was to reformat the memory card using fat32 memory format. I used a SD memory card slot on my laptop and right click the drive letter and select format to format the memory card. After that, I reloaded map files to the memory card and all was OK. Note that previously I had loaded map files on the memory card successfully but that was not good enough. A reformat of the memory card was apparently needed.
I had also previously tried a hard full reset of the ipaq by pressing and holding the lower two buttons (calendar and itask) while holding in the reset button with the stylus for 5 seconds and resynced my contacts and reloaded the gps software, but this was to no avail. Try the re-format.
Jun 22, 2008 | HP iPAQ H5550 Pocket PC
SD card slot stopped working
Really maybe you don't know a lot of fixya in the philippines. Try to send your device here in Dipolog City.
Nov 20, 2007 | HP iPAQ H2215 Pocket PC
HP ipaq rx3715
Have you tried other SD cards?  The box is uncheck for default install folder?  Maybe update the device.
Oct 13, 2007 | HP iPAQ RX3715 Pocket PC
Critical component is either missing or cannot start
Have you tried a soft reset or hard reset yet P ? How about a ROM update ? Seem like one of your applications on the Ipaq is having a conflict so try to remove them 1 by 1 and pinpoint the exact culprit Did you have the programs installed on the main Ipaq memory or a SD card if you have one ?
Sep 11, 2005 | HP iPAQ RX3100 Pocket PC
Today wallpaper
The screen size is 240x240 so you will need to reduce your picture to that size. You can put the pictures on the storage card, or other storage and then you can go into the your today screen settings and pick the storage area with the pictures in it.
Sep 08, 2005 | HP iPAQ hw6500 Pocket PC
File Transfer
Use file explore option in Activesyn or just use a SD card reader to transfer music, pictures, etc. to the card. It's much faster & easier.
Sep 08, 2005 | HP iPAQ HX4705 Pocket PC
Storage Memory
memory card isn't really memory it's more like a disk drive. it's not like when you add memory to a PC and the new memory is automatically used. To make use of this card you need to transfer some of your larger files to the card.... You can move files from within the ipaq... Click and hold on file. Select Copy Click and hold Select Cut Navigate with File Explorer to the SD card.... Open File Explorer Select My device Now select SD Card You can create a new folder or select an existing folder Click on Edit at bottom of screeen. Select Paste. You can also move files directly from PC to Storage card...... While IPAQ is connected, go to My Computer, then double-click on Mobile Device, then double-click on Pocket PC. Now you will see your Storage Card, and you can use this just like a folder on your PC. You can create folders within it. You can click and drag files to it or to any of it's folders.
Sep 07, 2005 | HP iPAQ H4150 Pocket PC
HP iPAQ rx1950 Pocket PC Logo
26 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
