Question about LG Shine KE970 Cellular Phone
Pairing Problems (phone 2 phone)
My LG will not pair with any cell phone. It worked when I got it last week - then it quit.
    Brigadier General:
  • 7,752 Answers
Try master reset the phone and see if that helps correct the issue.
Posted on Apr 06, 2008
6ya staff
SOURCE:
I am having problems pairing my LG Chocolate Touch Cellular Phone with the platronics explorer 230. What is the pairing code.
In the headset, try to enter into the pairing mode ( keep hold the power button few sec).
On your cell phone, look for your bluetooth device menu. try to lookup devices.
when the cell phone finds the headset, press the code 0000 ( four zero's..).
Then, remember to keep to enable automatic connection, in order to not have to enter the code next time you use the headset.
Mar 03, 2011 | Plantronics Explorer 230 Bluetooth Headset
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
Lg 8700 can not get to pair with any blue toogh device ,my phone has no other devices added
You Need To Type In A 4 Digit PassCode To Get Through To Another BlueTooth Device. Pairing Bluetooth Phones Is Kind Of Complicated. If You Are Pairing 2 Phones... Here Are The Steps:
1.) Find The Other Phone By Searching For It On BlueTooth
2.) Select The Device/Phone You Want To Pair With
3.) Enter The Last 4 Digits Of The Phone Your Trying To Pair With's Phone Number
4.) The Other Phone Should Be Asked If It Wants To Pair With Your Phone, Say Yes
5.) Type In The Last 4 Digits Again Of The Phone Your Trying To Pair With's Phone Number, Except This Time ON The Phone You Are Trying To Pair With
6.) You Should Get A Paired Successful
Pairing With Any Other BlueTooth Enabled Device:
1.) Search Through BlueTooth For The BlueTooth Enabled Device You Want To Pair To
2.) Select The Device You Want To Pair With
3.) Read The Instruction Manual That Came With The BlueTooth Device You Are Trying To Pair With, You Should Find A Pair Key In There Somewhere
4.) Enter The Passkey You Found (OR Already Know) And You Should Be Ready To Go
If All Else Fails, The BlueTooth Is Obviously Broken On Your Phone... Exchange It For A New One
Jan 30, 2010 | LG VX-8700 Cellular Phone
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Pairing problems
Make sure your phone is blue tooth enabled ad that both are in pairing mode.
Jun 01, 2009 | Motorola Mobility HS850 Consumer Headset
Motorola s9 mic does not work
try removing the S9 bluetooth device from phone, then re-adding and pairing again. this worked for me (I have an LG Voyager that I use with the Motorola S9). Mic stopped working after 2 weeks and removing the BT device and repairing did the trick.
Mar 11, 2009 | Motorola Mobility MOTOROKR S9 Wireless...
Bluetooth pairing code
The default pairing code for most bluetooth devices is 0000.
Try this to see if it works.
Thanks for using Fixya
Dec 14, 2008 | LG Shine CU720 Cellular Phone
Default code for bluetooh pairing.
the most popular ones are 1234, 0000, 8888. If this doesnt do it then consult the user manual.
Nov 27, 2008 | LG enV VX9900 Cellular Phone
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Jan 11, 2008 | Motorola Mobility Bluetooth...
Passkey
The passkey is 0000
Dec 25, 2007 | LG HBM-550 Wireless Headset
LG Shine KE970 Cellular Phone Logo
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
