Question about Dual XDVD8181 Car Video Player
Ipod wont come up
I have the xdvd710 and i also have 5th generation nano and when i plug it in the screen comes up and it saya the amount of songs there are and connecting but nothing appears on the list. Does anyone have an answer ?
  • Anonymous Mar 19, 2008
    I have the exact same problem, according to the dual manual this version is not supported. I know the head unit is older than the latest nano version so that is probably why.
The problem is that your iPod adapter does not have a authentication chip in it. Apple decided to go a new route with the new iPods. They now require a authentication chip if you want to get audio and video out of the iPod using the dock connector. So you won't be able to hook up your iPod to your system using your current equipment. You can either hope that the maker of your equipment comes out with a new iPod cable that has a authentication chip (they have to pay Apple for this so if the company is cheap then you are probably out of luck) or just stick with your older 5G/5.5G iPod.
Posted on Jul 16, 2008
6ya staff
SOURCE:
Memory loss on ipod
The ipod nanos the smallest product in the Apple iPod line. The fourth generation Nano comes in two different capacities, each capable of holding thousands of songs.
    Capacities
  1. The fourth generation iPod Nano comes in 8 GB and 16 GB models. The 8 GB version can hold 2,000 songs, and the 16 GB version can hold 4,000 songs.
  2. Tips
  3. Song capacity estimates are based on music encoded in Apple's proprietary format at a standard, average bitrate. The higher the bitrate, the better the quality. Songs deviating from Apple's standard (for example, CD-quality music or high bitrate MP3s) will use more disk space.
  4. History
  5. Nano's predecessor, the iPod Mini, was released on January 6, 2004, and was available with a 4 GB hard drive. The Nano was first released on September 7, 2005, and was the first iPod to use flash memory. It was first available in 2 GB and 4 GB versions. The fourth generation Nano was released on September 9, 2008.
  6. Size
  7. The fourth generation iPod Nano is 3.6" tall and 1.5" wide.
  8. Video
  9. The third generation Nano, released on September 5, 2007, was the first Nano to feature video playback. Storing videos on Nano can dramatically reduce the amount of songs it can hold.
Nov 24, 2009 | Apple iPod nano
I have an ipod nano 2nd generation. i plug it into the computer and itunes comes up. i had like 392 songs on it and it just deleted when i plugged it in. now i cant even get songs to go on it.
You will need to reset your iPod to factory settings. Plug in your iPod and when iTunes launches, click on the icon for your Nano. There will be a button there saying "Restore iPod to Orginal Settings". Click it and iTunes will automatically do what is necessary. After that completes, you should be able to move songs onto it again.
Jul 05, 2009 | Audio Players & Recorders
Ipod nano can't read or play songs
Did you use iTunes to put the songs on? This is totally essential to being able to see the songs on your iPod. download iTunes here
Oct 24, 2008 | Apple iPod nano 3rd Generation
Ipod nano
Plug your IPod into the dock or cable. Do a restore or you IPod to get it back to factory settings. Download some songs into it. Make sure that your connection is good and if you use a dock, make sure that is properly seated.
If it continues you may want to replace the cable.
Jul 11, 2008 | Apple iPod nano 3rd Generation
IPod Nano wont play music trasferred from ipod mini
what download are you using ? as it seems that the songs are in a diferant format which ipod can,t under stand
Jan 08, 2008 | Apple iPod nano 3rd Generation
Wont update songs
To reset an iPod with a Click Wheel, including: ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano2.jpg ipodnano.jpg ipodphoto.gif ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Dec 16, 2007 | Apple iPod MA446LL/A MP3 Player
My Ipod Nano Won't Respond
The problem may be battery charge. Leave it plugged into the computer for 6 hours, and then try it. If this does not work, the best thing to do may be to call apple for further help.
Nov 17, 2007 | Apple iPod nano
Dual XDVD8181 Car Video Player Logo
188 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
